ThinkPad X380 la-f421p rev 1.0
  • Markus1741
    • Sep 2020
    • 843
    • N/A
    #41
    Hello try ....
    • dqtech
      Badcaps
      • Jul 2018
      • 630
      • N/A
      #42
      Originally posted by Markus1741
      Hello try ....
      thank you sir but problem still same...shut off after few second...perhaps its not bios issue maybe
      • FalconPunch
        • Oct 2023
        • 20
        • France
        #43
        Hello, I have a Lenovo x380 with bios password and computrace ; I have followed this guide from MaxPower (Thanks for the tutorial ) : https://www.badcaps.net/forum/troubl...-ec-pwd-bypass ; Unfortunately , the method failed as there was a risk of bricking . Now , the laptop keyboard light up and down but there is no post no lenovo logo nor display. fan run one time then shut down. I think that the bios may be corrupted. Hence, i have made a copy of the corrupted bios. Can you please see make a new working bios ? Thank you.
        Lenovo X380 Yoga Laptop (ThinkPad) - Type 20LJ
        Board: LA-F421P Rev:1.0
        Machine Type Model 20LJS13H00
        System unit serial number: MP1L3FZK
        System board serial number: C1KS96X00CL​
        • hoaca388
          Badcaps
          • Jan 2022
          • 11729
          #44
          • FalconPunch
            • Oct 2023
            • 20
            • France
            #45
            Thank you for the file and help provided. Unfortunately, after writing your file on the chip, it seems to only light esc key and other function button then immediatly power off...
            • FalconPunch
              • Oct 2023
              • 20
              • France
              #46
              Update:
              Sorry for bothering , I forgot that i have a taken a photo of the bios menu with all the information before doing the shorting method to bypass password. The problem may lie between the bios chip and the EC chip. Is it possible to get a bios bin and EC bin please ? Thank you in advance
              UEFI BIOS Version: ROSET51W (1.35)
              UEFI BIOS Date (Year-Month-Day): 2022-02-09
              Embedded Controller Version: ROSHT51U (1.35)
              ME Firmware Version: 11.8.60.3561
              Machine Type Model: 20LJS13H00
              System-unit serial number: MP1L3FZK
              Asset Tag: No Asset Information
              CPU Type: Intel(R) Core(TM) i5-8250U CPU
              CPU Speed: 1.600GHz
              Installed memory: 8192MB
              UUID: 6b18ebcc-2ca7-11b2-a85c-a876d9548e7f
              MAC Address (Internal LAN): 9C 5A 44 7D 94 74
              Preinstalled OS License: SDK0J40697 WIN
              UEFI Secure Boot: On
              0A3 ID: 3305212562343
              0A2: Yes​
              Here is the same bios file that may be corrupted i posted before
              • Maxpower3
                Bad Veteran
                • Feb 2018
                • 1226
                • France
                #47
                Ec dump 1.35 ( R0SHT51W) 128Ko
                Bios cleanMe (R0SET51W) 1.35
Name:	1_35 hoaca.png
                • FalconPunch
                  • Oct 2023
                  • 20
                  • France
                  #48
                  Thank you very much Max . I will try it.
                  • FalconPunch
                    • Oct 2023
                    • 20
                    • France
                    #49
                    Ok , so for flashing the EC file , I had to use the Vertyanov programmer and connect to the EC chip by using the keyboard port ; I read the dump 3 times and saved as many file in order to have a correct copy ; I then flashed the EC chip with the file provided and made sure that the file was correctly inputted in the cheap by reading again. Unfortunately, the laptop, when power on , light capslock, escape, F1 and F4 button then powers off; i have provided here the ec dump i got from the EC chip originally
                    • Maxpower3
                      Bad Veteran
                      • Feb 2018
                      • 1226
                      • France
                      #50
                      password is marked there.
                      the files seem to correspond to the structure. I would like to have more normal information.
                      SER/USR and CON look correct too.
                      The content is almost identical apart from the 00 and FF which changes.
                      So for me the file should work.
                      Maybe at 870, half at 00 and the other half at FF. but nothing crazy
                      It's late, I'll watch more tomorrow.
                      Have you tried the bios also provided at the same time as the EC?
                      Have you seen a change in the habitual symptom?
                      • qayyum786
                        • Aug 2018
                        • 1933
                        • INDIA
                        #51
                        Update:
                        CPU Speed: 1.600GHz
                        0A2: Yes​
                        Try again
                        • qayyum786
                          • Aug 2018
                          • 1933
                          • INDIA
                          #52
                          Update:
                          CPU Speed: 1.600GHz
                          0A2: Yes
                          flash both EC & MAIN​
                          • Maxpower3
                            Bad Veteran
                            • Feb 2018
                            • 1226
                            • France
                            #53
                            @ qayyum786
                            I can't figure out where that one comes from. ??
                            The closest thing is an X280
                            • FalconPunch
                              • Oct 2023
                              • 20
                              • France
                              #54
                              Yes when i flashed the ec chip , i have flashed beforehand ther bios you have provided me. Alas, The symptoms are still the same . Take care Max and rest. Again thanks for your input
                              • FalconPunch
                                • Oct 2023
                                • 20
                                • France
                                #55
                                Ok thanks . As soon as i am on the laptop, i will flash the bios and the EC chip . I will tell you the results then.
                                • FalconPunch
                                  • Oct 2023
                                  • 20
                                  • France
                                  #56
                                  So I tested again with flashing the bios and EC chip with the files from 4MATIC; Symptoms are still the same pwer led on with some buttons lighting up then totally power off . Beforehand, I read the EC chip flashed with MaxPower file ; I noticed that the file output from the EC chip was different. The file read will be atteched .
                                  Well if the software side is not the problem , I will need to check thorougly myself the hardware part to find what causes this symptom.
                                  • irull89
                                    • Aug 2016
                                    • 7
                                    • kudus
                                    #57
                                    Re: ThinkPad X380 la-f421p rev 1.0
                                    Here's your New BIOS, try it and give me the results.
                                    Thank you very much, it worked. touchscrenn worked
                                    • hardware1
                                      • Sep 2021
                                      • 2930
                                      • N/A
                                      #58
                                      You're welcome.
                                      all donations are welcome,
                                      • FalconPunch
                                        • Oct 2023
                                        • 20
                                        • France
                                        #59
                                        Update : So I noticed that i removed pin 7 trace from the motherboard so i had to repair it . I used Bios and EC file from 4Matic : Bios boot to lenovo and the lenovo logo + there is no supervisor password (Thanks 4Matic and MaxPower ) appear but i got 2x invalid RFID serialization data with error code 0188 + 0189 and 0177 : Bad SVP data , Stop POST Leak. On top of that there is computrace enabled. I used the lenovo U1 tool to update since the system unit serial number (Which is 1S20LJS13H00MP1L3FZK) since the bios menu displayed INVALID for Machine type model , System Unit serial number and System board serial number. Problem is that upon rebooting to bios menu, the information stays as Invalid; On top of that , Computrace is enabled .
                                        Personnally, i think that computrace may prevent me from updating with the serial number; Hence , do you think that setting a supervisor password then use the DXE patcher may remove that computrace from the board , So i can update the board correct settings ??? Thanks in advance for the feedback.
                                        PS: Also UUID is set to ffffffff-ffff-ffff-ffff-ffffffffffff
                                        • Maxpower3
                                          Bad Veteran
                                          • Feb 2018
                                          • 1226
                                          • France
                                          #60
                                          why not put back your original dump. I cleaned it
                                            Lenovo ThinkPad X380 Yoga Hybrid (2-in-1) X Specification for Upgrade or Repair
                                            This specification for the Lenovo ThinkPad X380 Yoga Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the X380 Yoga boardview and X380 Yoga schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                            09-06-2024, 02:28 PM
                                            09-06-2024, 01:21 PM
                                            09-06-2024, 12:51 PM
                                            09-06-2024, 11:50 AM
