latitude 5420 board LA-k491P bios problem.
https://www.badcaps.net/donate -
plz help me , this bios eror TPM device is not detected
Dell 5420
SVT : FFNC6G3
i5 gen 11
Attached Filesif you find these attachements useful please consider making a small donation to the site
Latitude 5420
Service Tag: FFNC6G3Attached Filesif you find these attachements useful please consider making a small donation to the site
https://www.badcaps.net/donateComment
ServiceTag: 6ZKF6J3
I had used the https://github.com/chromebreakerdev/DellBIOSTools script, but it gives me an error, that the Intel signature not found.
Think i perhaps know why, wanted to read the bios file with my EZP2019 programmer and pushed the wrong button 😣 (AUTO > auto recognize the chip brand and size).Attached Filesif you find these attachements useful please consider making a small donation to the site
Corrupt backup, slow the programmer speed to 6Mhz and try again.ServiceTag: 6ZKF6J3
Think i perhaps know why, wanted to read the bios file with my EZP2019 programmer and pushed the wrong button 😣 (AUTO > auto recognize the chip brand and size).Comment
A small update regarding my situation.
I had found in topic need bios dump dell latitude 5420 cpu 11th this posting.
Someone else mentioned that the file "try 2nd outimage" worked for that person, so I have used it also.
And I can confirm, the file worked like a charme. Kudo's to qayyum786
dell latitude 5420
gdf40 la-k91p/rev:3.0
st-1RJS3K3
PASSWORD
plz unlockAttached Filesif you find these attachements useful please consider making a small donation to the site
hi tryAttached Filesif you find these attachements useful please consider making a small donation to the site
Hi guys, I have a latitude 5420 here, I've done a few but this one is proving to be an issue.
I successfully removed the admin password with the 8FC8 patcher (although it seems to change entries in more than two locations?).
I was under the impression the 8FC8 patcher only edited two strings, when I use it on this dump it edits 4.
Chip resoldered, laptop boots but NVME not detected, from a bit of reading this could be a corrupt ME region?
Can anybody help please?
I have uploaded the original locked dump, so if somebody could remove the admin password and repair the ME I would be forever grateful, thank you.
Dell Latitude 5420
ST - 90517M3Attached Filesif you find these attachements useful please consider making a small donation to the site
Hi in this bios TPM Error , dell logo hang, green, red, blue, white screens coming
Kindly anyone fix This
Dell Latitude 5420,
Service TAG-9QZF3F3,
LA-K491P REV 2.0(A01)
2021-10-15.
Thank You in advanceAttached Filesif you find these attachements useful please consider making a small donation to the site
any alternate file please,
Dell Latitude 5420,
2021-10-15.
Here I attached bios which i got from badcaps, in this bios dell logog coimg after blank display. kindly help me with thiss. in this bios TPM not Detected error kindly fix thisAttached Filesif you find these attachements useful please consider making a small donation to the site
Dell Latitude 5420
HI, COULD YOU HELP ME WITH THIS BIOS? IT SHOWS A TPM ERROR AND HAS AN ADMINISTRATOR KEY? CAN YOU HELP ME PLEASE?
BOARD MODEL: GDF40 LA-K491P REV 2.0(A01)
2020-11-16
DELL MODEL: LATITUDE 5420
ST: 4X036D3Attached Filesif you find these attachements useful please consider making a small donation to the site
I have a Dell Latitude 5420 (tested without HDD) and I’m running a diagnostic tool such as Aiken Workbench. The problem is that the tool detects the onboard LAN card, but it shows the message:"no working driver for it"
and the test result is NO Driver.
Interestingly, when I install Windows, the LAN card works perfectly fine, which confirms that the hardware itself is okay. I have tried multiple cables and diagnostic environments, but the result is the same.
For comparison, I have a BIOS dump from a working unit and another from the problematic unit. The file sizes are identical. I suspect the issue might be related to a missing or corrupted PXE/UEFI network driver module in the firmware.
My questions:- Has anyone experienced this issue before?
- What are the recommended steps to add the proper LAN driver to a diagnostic/WinPE environment, or to safely repair the firmware?
- If no solution can be found, I would appreciate it if any expert who knows how to fix this fault could contact me privately to suggest the right approach.
Thank you in advance for your help.Comment
by SathsulSo, i kinda spend significant ammount of the last couple of days trying to flash a new bios, and or unlocking the current bios password with little to no results.
The whole thing started with it being the 8fc8 bios, i found the tools to unlock that but i needed a bios dump. So i pursued that, im at a point where i dessoudered the chip, and succesfully soudered it to the ch341, dumped whatever was on it.
However, the tools supposed to unlock the 8fc8 say that there is no 8fc8 hex inside. And when i followed diffrent tutorials to just flash a new bios onto the chip i got stuck on the...-
Channel: BIOS Requests ONLY!
by TripTopHi
i have dell latitude E7270 with following symptoms:
- takes long time to restart.
- sometimes powers on and then off
- sometimes while working it just dies,
From googling online bios clean could possible resolve this?
i was able to save bios and was going to try bios clean myself but get an below error when i drop it in ME analyzer.(unsure whether this sometimes occurs or could be due to bad/corrupt bios)
As ME analyzer gave me an error i just decided to write bios with a cleaned bios from E7270 bios post.
I reinstall...-
by macabookHello everyone,
07-24-2025, 02:17 PM -
by gizahaDell latitude 5580, motherboard cdp 80 la-e151p
Since ssd is replaced and had clean install windows, i've... -
This specification for the DELL Latitude 5420 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 5420 boardview and 5420 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL Latitude 5420...09-07-2024, 06:31 AM
- Loading...
