latitude 5420 board LA-k491P bios problem.
  • bachir2004
    • Feb 2015
    • 439
    • maroc
    have a dell latitude 5420 bord LA-k491P with bios problem(does not switch on).
    the original dump is corrupted.Can someone please help?
  • hoaca388
    Badcaps
    • Jan 2022
    • 12035
    Re: latitude 5420 bord LA-k491P bios problem.
    Here
    • bachir2004
      • Feb 2015
      • 439
      • maroc
      Thanks will test it.
      • bachir2004
        • Feb 2015
        • 439
        • maroc
        not working.Machine does not even turn on.
        • lapfix
          • Mar 2020
          • 2750
          • my workshop
          sevice tag !
          • bachir2004
            • Feb 2015
            • 439
            • maroc
            Originally posted by lapfix
            sevice tag !
            ok.see pm.
            • lapfix
              • Mar 2020
              • 2750
              • my workshop
              try
              • bachir2004
                • Feb 2015
                • 439
                • maroc
                thank you so much.With this it swiches on normally but still no image.
                • lapfix
                  • Mar 2020
                  • 2750
                  • my workshop
                  Just wait a few second ,laptop may restart few times too
                  • bachir2004
                    • Feb 2015
                    • 439
                    • maroc
                    This one is a real pain.changed the screen finally got image machine boots but after entering the service tag got an error(wrong service tag) witch is weird restarted it and no boot no image again.
                    • bachir2004
                      • Feb 2015
                      • 439
                      • maroc
                      I know.bad screen.thank you so much your bios works.
                      • jm801
                        Banned
                        • Apr 2020
                        • 123
                        • monterrey
                        dell 5420 LA-K491P PASWORD
                        could you help me unlock this bios
                        • aldopc
                          • Jul 2017
                          • 465
                          • Chilito
                          Re: dell 5420 LA-K491P PASWORD
                          Test and comments
                          • skazide
                            • Jul 2015
                            • 142
                            • morocco
                            plz need help , need to unlock this dump
                            • skazide
                              • Jul 2015
                              • 142
                              • morocco
                              problem solved thanks
                              • jm801
                                Banned
                                • Apr 2020
                                • 123
                                • monterrey
                                Originally posted by aldopc
                                Test and comments
                                thank you it worked you are very kind
                                • darckreign1984
                                  • 260
                                  please how to read this bios?
                                  laptop died after update in windows
                                  bios chip its winbond W25R256JV
                                  i have tl866II
                                  thanks
                                    • 21389
                                    i have tl866II
                                    thanks
                                    It isn`t in the TL866II support list,so choose another chip, same size and voltage such as W25Q256 and untick check ID
                                    • darckreign1984
                                      • 260
                                      for tl866 it give me a schematics for so and si, in this chip are 4 pin for data In out - what to solder?
                                      IO0
                                      IO1
                                      IO2
                                      IO3
                                      and this chip dont have wp reset hold pin assigned
                                      • darckreign1984
                                        • 260
                                        IO0
                                        IO1
                                        IO2
                                        IO3
                                        i used
                                        MOSI: Master Out Slave In (data output from master); PIN 5 TL866 TO PIN 2 IO0
                                        MISO: Master In Slave Out (data output from slave) pin 4 tl866 to pin 5 io1 - when i use this - all bin was 000000
                                        tried this variant to
                                        MOSI: Master Out Slave In (data output from master); PIN 5 TL866 TO PIN 5 IO0
                                        MISO: Master In Slave Out (data output from slave) pin 4 tl866 to pin 2 io1 - same result all bin memory 0000000
                                        • TripTop
                                          Dell Latitude E7270 - Requesting BIOS clean/corrupt? service tag CB00KC2
                                          by TripTop
                                          Hi
                                          i have dell latitude E7270 with following symptoms:
                                          - takes long time to restart.
                                          - sometimes powers on and then off
                                          - sometimes while working it just dies,
                                          From googling online bios clean could possible resolve this?
                                          i was able to save bios and was going to try bios clean myself but get an below error when i drop it in ME analyzer.(unsure whether this sometimes occurs or could be due to bad/corrupt bios)
                                          As ME analyzer gave me an error i just decided to write bios with a cleaned bios from E7270 bios post.
                                          I reinstall...
                                          09-09-2024, 02:05 PM
                                        • macabook
                                          by macabook
                                          🧩 Initial Issue
                                          07-24-2025, 02:17 PM
                                        • gizaha
                                          by gizaha
                                          02-13-2024, 07:18 AM
                                          DELL Latitude 5420 Notebook 5000 Specification for Upgrade or Repair
                                          This specification for the DELL Latitude 5420 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 5420 boardview and 5420 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL Latitude 5420...
                                          09-07-2024, 06:31 AM
                                          09-07-2024, 03:40 AM
