someone help me to get zed note 14i firmware file
  • almanda
    • Jun 2021
    • medan
    Hi. can someone help me to get zed note 14i firmware file. I've visited the web but the web seems to have been closed. Please help
    NAME : ZED NOTE 14i
    KODE PART : IL.1406G.264WAESW
  • peste
    • 13924
    • ROMANIA
    Re: someone help me to get zed note 14i firmware file
    NAME : ZED NOTE 14i
    post the original bios here ... maybe we can fix it ..
    • almanda
      • Jun 2021
      • medan
      my backup.....
      NAME : ZED NOTE 14i
      • Mazorca
        • Jan 2017
        • 463
        Here is your file with a cleaned ME, try it first.
        • almanda
          • Jun 2021
          • medan
          thanks a lot. i will try this
          • almanda
            • Jun 2021
            • medan
            not working bro.. touchpad,keyboard, touchscreen not working
            • Raichu89
              • Nov 2022
              • India
              Is your problem solved i have also have this problem
              • faysal
                • May 2015
                • 22
                • Pakistan
                i also have same problem with same model
                • Love Bird
                  Ankit Sudhera
                  • Mar 2025
                  • Saudi Arabia
                  Can someone help me to get zed note 14i firmware file. I've visited the many websites but the web seems to have been closed.
                  Please help
                  NAME : ZED NOTE 14i
                  KODE PART : IL.1406G.264WAERW​
                  • peste
                    • 13924
                    • ROMANIA
                    Please help
                    NAME : ZED NOTE 14i
                    post S/N, full name and model, motherboard model,etc.
                    post the contents of the bios chip even if it is corrupted..
                    • Love Bird
                      Ankit Sudhera
                      • Mar 2025
                      • Saudi Arabia
                      Hi Everyone,
                      I understand how challenging it can be to identify and resolve this issue. After dedicating two days to troubleshooting, I finally discovered a solution and wanted to share it to assist others facing the same problem.
                      For a detailed explanation, please refer to the following link:
                      https://www.youtube.com/watch?v=vl5mbJpSf1I
                      Hope it helps.
                      Regards,
                      Ankit​
                      • Daniel Larsson
                        Firmware file for LG SK10Y Soundbar stuck in Please wait loop needed
                        by Daniel Larsson
                        My LG Soundbar, SK10Y, has somehow ended up in an endless "PLEASE WAIT" loop and I am now starting to suspect that the firmware is causing this, and I can't manage to connect via the app to push a new firmware in as it never really starts.
                        I can trick it to start via HDMI ARC and it actually starts up, flashes OPTICAL and then goes to ARC where the sound (including sub) is perfect, but the white led indicator keeps blinking and after 20 seconds it says "GOOD BYE" and shuts down.
                        During these seconds the function button is not working...
                        08-13-2025, 10:29 AM
                      • Daniel Larsson
                        Firmware file for Marantz NR1501 needed
                        by Daniel Larsson
                        I picked up a Marantz NR1501 that the seller said did not produce any audio, but was starting up just like normal. This was indeed the case and the hunt for damaged components started.
                        After confirming all voltages and replacing all caps on this godforsaken HDMI-board I finally got sound from the AUX input, but all digital inputs are still dead.
                        The service menu shows no DSP version so I desoldered IC1604 that should have the serial flash DSP firmware on it and made two dumps that turned out identical.
                        The content of these seems to be useless as far...
                        05-23-2025, 04:11 AM
                      • GeckoGreen
                        Samsung service bulletin: need firmware file for PN63C550 TV
                        by GeckoGreen
                        I'm hoping someone with access to the Samsung GSPN can help me. I need someone with access to download a firmware file for my PN63C550 TV, as it will fix a problem per the Samsung service bulletin.
                        You can reference Samsung bulletin #:ASC20130528001 and I need the [2D63]LOGIC.bin file please.
                        The full service bulletin is linked here: https://www.avsforum.com/attachments...3-pdf.1080602/
                        Will you please help me get the [2D63]LOGIC.bin file for my TV?
                        05-17-2025, 02:47 PM
                      • m1ch43lzm
                        by m1ch43lzm
                        Hi everyone
                        09-06-2025, 05:47 PM
                      • Kolecki
                        Epson et-2756 Firmware dump file
                        by Kolecki
                        Hi I need bios or firmware dump file to printer Epson et-2756. Can you help me. My printer is bricked in printer mode and i need reprogram chip on board
                        01-18-2025, 11:38 AM
