HP fpi50 la-h329p bios dump needed help!
  • ridouane
    • Mar 2019
    • 23
    • casablanca
    #41
    The BIOS in message #35 boots into Windows, but if you press f9 to select the boot device the message appears:enter administrator password ------system locked press the power button to shut down the system.
    I flashed the bios by the file FPI50 LA-H329P cleanme dmi
    no message: Manufacture Programming Mode is in Unlock Mode ,but the Windows system does not start​. PC FREEZE ON HP LOGO.
    thank you very much Mr m1ch43lzm​.​
    • m1ch43lzm
      • Mar 2019
      • 654
      • Peru
      #42
      You didn't say that BIOS from # 35 had password
      Try #19 from here: https://www.badcaps.net/forum/troubl...75#post3661175It may show also "Manufacture Programming mode is in Unlock mode", this is what we want to change serial
      First boot, enter BIOS pressing F10, go to Boot options, change "Secure Boot" to Disabled, change "Legacy Support" to Enabled, save and exit
      It depends if Windows was installed on Legacy mode or UEFI
      Windows should start, then you can edit serial, build ID, SKU number and set Manufacturing Programming Mode to Lock, like this, remove the * from unlock, and add an * to Lock:
      Code:
          *Lock
          Unlock​
      • DynaxSC
        by DynaxSC
        11-17-2023, 10:56 AM
      • TacticalFahrrad
        [REQUEST] Fujitsu Lifebook E5513 – Full BIOS Dump Needed (.bin)
        by TacticalFahrrad
        I'm trying to recover a Fujitsu Lifebook E5513 (most likely 2023 model) that was bricked during a BIOS update. The update was interrupted (probably due to power loss), and now the laptop is stuck in a boot loop showing "PBB rollback" / "SBB rollback" messages.
        BIOS access (F2) and Boot Menu (F12) are no longer possible – the system instantly reboots after the rollback messages.
        I extracted the official BIOS update package from Fujitsu (contains FJNB2FD.CAP, ~18.7 MB) and tried tools like UEFIExtract, but it seems to only contain...
        06-30-2025, 04:09 AM
      • vinaypundith
        Razer RZ09-01682 Blade Stealth 13 2016 BIOS dump needed
        by vinaypundith
        I have this laptop that does boot but it's on an older BIOS that has issues with Secure Boot, and I cannot use the normal Razer BIOS updater because for some reason the serial number is missing / got deleted somehow (Common issue on this model, from what I've read). I got a dump of the BIOS chip (or at least what I think is the BIOS chip), and its 16MB in size - the files from the Razer BIOS update are 8MB. (There's two 8MB files, am I supposed to combine these somehow? Or combine with an Intel ME firmware? I have no idea).
        So, I'm looking for a BIOS dump for this machine - a 16MB one....
        08-03-2024, 12:32 PM
      • James Maxwell
        HP DM1-4000er Bios Dump needed
        by James Maxwell
        I badly need bios dump for HP DM1-4000er,
        Model: HP DM1-4000er
        Motherboard: DA0NM9MB6D0 REV.D
        Product: QJ490EA#ACB
        Please help. My bios chip burned so I don't have the old bios anymore. I need bios dump before I can install the replacement.
        10-28-2024, 05:38 PM
      • Habble7
        by Habble7
        Suspected Cause:
        Troubleshooting Attempts:
        05-22-2025, 07:28 AM
