I need la-h325p bios please
    VIP Moderator
    • Aug 2018
    • 4386
    • Bulgaria 🇧🇬
    Re: I need la-h325p bios please
    Originally posted by sundeon
    Hi! I need my bios fixed, can someone help me? Turns on no display
    Hp 250 g8 fpw50 LA-H325P Ver: 1.0
    sn: CND1431TLZ
    Here is my backup
    Read post #17
    Become a Badcaps supporter
    Thanks to all supporters.​
    • Tosebeee
      • Aug 2023
      • 10
      • Nigeria
      hi! i need my bios fixed,can someone help me ? turns on no display
      HP :15-dw1239nia la-h325p rev :1.0
      SN :CND1345BD2
      HERE IS MY BACK UP
        • 21457
        Originally posted by Tosebeee
        PLS I NEED HP 15-DW1239nia la-h3259 rev:1.0 bios . mine display problem
        Read the rules at post #15 .
        • Tosebeee
          • Aug 2023
          • 10
          • Nigeria
          here is my back up
          • Tosebeee
            • Aug 2023
            • 10
            • Nigeria
            • jhuztine2881
              • 37
              • Philippines
              #26
              pls anyone who can fix bios no display
              Hp 15s-du0110tu FPW50 LA-H325P
              • hoaca388
                hoaca388 commented
                Editing a comment
                Serial number ?
            • hoaca388
              Badcaps
              • Jan 2022
              • 12118
              #27
              SN :CND1345BD2
              HERE IS MY BACK UP
              BID : 085F5
              DMI : 3C7000h -> 3C900Fh
              WINDOWS KEY : 3C5000h -> 3C503Fh
              ​https://www.badcaps.net/donate
              • hyditech
                • Jun 2012
                • 272
                • nigeria
                #28
                please i have this hp laptop with the board number LA-H325P with password..
                the chip is 4mb.. i have try other ways,but password wont remove.
                please me to unlock.
                S/N CND13355CR
                Thank you
                  SMDFlea commented
                  Editing a comment
                  Your BID is 085F5 ,use the virgin bios at post 29 .The DMI is at the same offsets,if you still can`t use a hex editor use HP Bios Config Utility to add the DMI. HP BCU can`t add a windows key though.
              • talisman
                • May 2019
                • Nigeria
                #29
                Hi All need bios Hp FPW50 LA-H325P REV 1.0 i tried post #6 but same issues 5 long beep then 3 short its bios corrupts signal i attach dump bios backup anybody have 100 percent working plz share
                Hello aijazli, where you able to sort this issue on your hp FPW50 LA H325P REV 1.0 2019-01-18. mine have same 5 caps long flash and 3 short ones. Pls I will needed the bin if yours worked
              • Argento7
                • Jan 2010
                • 27
                #30
                Hi friends, please help. Turns on, no caps lock codes but no display. I try some bios but no changes. Bios version 085f5 F63, Serial CND3192ZNH.
                I can program EC ENE KB9022Q
                Thanks in advance
                  Vesko356 commented
                  Editing a comment
                  Thread merged.
              • Argento7
                • Jan 2010
                • 27
                #31
                Thanks in advance
                Post #6 bios is working! Thanks
                TIP: If "manufacture programming mode is in unlock mode" appear when power on, use HP tool https://ftp.ext.hp.com/pub/caps-soft...it/HP_BCU.html
                • ash91
                  • Jun 2023
                  • 31
                  • SAUDI
                  #32
                  Hello all
                  i recive this hp laptop with caps lock 5 slow and 3 fast blink error which indcate bios error
                  the motherboard numper is FPW50 LA-H325P1 REV 1.0
                  sn CND131133V
                  the laptop seems to be bios programed before so i read the bios chip and attached the file
                  but i think i have to modify this file or it culd be the wrong file programed by some one else
                  so is there any way that i can find the right bios file because i try some bin files with the same result
                  i read that i need to modify DMI and some another things in order to be able flash the bios
                  thank you all in advance
                  • Md Jibrail
                    • Mar 2023
                    • 21
                    • Saharsa
                    #33
                    Originally posted by hoaca388
                    Re: Fpw50 la-h325p rev 1.0 bios
                    HP Notebook - 15-dw1213nia
                    TESTED OKK Thank you so much
                    • Infinity13197
                      • Sep 2020
                      • 20
                      • Nigeria
                      #34
                      fpw50 la-h325p rev 3.0 bios please mine is 4MB
                    • Infinity13197
                      • Sep 2020
                      • 20
                      • Nigeria
                      #35
                      FPW50 LA-H325P REV: 3.0 2021-10-21
                      HP Notebook - 15-dw1208nia
                      SN:CND2120XGT
                      File Size: 4MB
                        • 21457
                        SN:CND2120XGT
                        File Size: 4MB
                        Thread merged. The bios should not be 4MB ,choose the chip manually,don`t use autodetect. What is the chip part number,which programmer are you using and the software version .
                        • Infinity13197
                          • Sep 2020
                          • 20
                          • Nigeria
                          #37
                          I'M USING EZP2010 FIRMWARE VERSION 3.0
                          BUT YOU HAVEN'T GIVEN ANY FILE TO USE YET
                            • 21457
                            If you can`t answer all the questions then i can`t help. As i said the the bios should not be 4MB, so you`ve either got the wrong 4MB bios chip on the board or the programmer has wrongly detected the chip. Don`t use ALL CAPS in your reply please !
                            • UlaFZ
                              • Sep 2023
                              • 11
                              • Costa Rica
                              #39
                              I need the bios of LA-H325P model: 15-dw1504la
                              i can't find it
                                • 21457
                                i can't find it
                                Thread merged.Post your backup and the laptop serial number https://www.badcaps.net/forum/troubl...before-posting
                                • mikeybass
                                  by mikeybass
                                  04-23-2025, 04:30 PM
                                • al3m0di
                                  Update bios EFCN58WW to EFCN59WW
                                  by al3m0di
                                  Update bios EFCN58WW to EFCN59WW for solving The Connected AC adapter has a lower wattage than the recommended AC adapter
                                  I have a Lenovo Legion 5 15imh05a device that I bought used online. It came with a 20V 8.5A 170W charger.
                                  The BIOS version is EFCN58WW.
                                  When I turn on the device, it displays the message:
                                  "The Connected AC adapter has a lower wattage than the recommended AC adapter..."
                                  The device rarely charges the battery, and even when it does, it doesn't show that it's charging.
                                  I've tried
                                  07-29-2024, 10:32 AM
                                • Shadowtuy
                                  Bricked bios from a bad flash/update in a case of NO BACKUP repair question
                                  by Shadowtuy
                                  So I'm new here and have successfully unlocked a bios using "RCUnlocker" but after that I'm curious on recovery of a bricked bios from a bad flash/update in a case of NO BACKUP.
                                  The part I'm stuck on is my HP backup are a 32,768KB and 16,384KB image compared to a fresh bios from HP at 23,690KB. How would I use the fresh image to repair a flash chip? The guide I'm following just takes the image and flashes it over but clearly there is more to it.
                                  Just looking to expand my knowledge of this since the password removal worked great. Sorry if I missed this being...
                                  09-05-2023, 11:24 AM
                                • 0xx
                                  2022 Razer Blade 14 (RZ09-0427) won’t boot after Windows update, only the green LED blinks - overheated or BIOS?
                                  by 0xx
                                  Hi folks,
                                  My son clicked “Update and Shutdown” on a Razer Blade 14 (2022, RZ09-0427), closed the lid, disconnected the charger, and put the laptop in his backpack. The next day, it wouldn’t boot: only the green LED blinked, no fans, no keyboard backlight, no display. The chassis does get warm, so the CPU/GPU seems to get power.
                                  What I’ve tried so far: disconnecting the main battery, CMOS reset with power drain (30s), using a different power adapter, and connecting to the monitor - same result.
                                  I assumed that Windows Update was interrupted due to closing...
                                  09-14-2025, 03:46 PM
                                • trix11
                                  Dell Precision T1650 MT Workstation bricked after BIOS update
                                  by trix11
                                  I have a Dell Precision T1650 MT workstation (of the following spec.) that was bricked yesterday when attempting to update the BIOS from A27 to A28 per:
                                  - https://www.dell.com/support/home/en...-t1650/drivers > Dell Precision T1650 System BIOS
                                  - Dell Precision T1650 mid tower Workstation
                                  - Xeon E3-1225 V2
                                  - 32Gb PC3-12800E RAM
                                  - 4Tb SATA HDD
                                  - motherboard: Dell part: 0C3YXR CN-0C3YXR-72200-39C-01GR-A02
                                  I see now that others have experienced like issues e.g.:
                                  - https://www.dell.com/community/Prec...
                                  10-24-2022, 10:35 PM
