Please help unlock 845 g8
  • N0f3ar
    • Oct 2016
    • 51
    • Bulgaria
    hi , please help me unlock hp elitebook 845 g8
    i have already tried rc unlocker it says wrong bios chip
    here are both 32 mb dumps top and bottom
    thanks
  • lover7173
    • Apr 2017
    • 19
    • South Korea
    Re: Please help unlock 845 g8
    Try working with this file.
    • N0f3ar
      • Oct 2016
      • 51
      • Bulgaria
      hi , it does boot but is says it is locked and not give the opertunity to write pass at all
      • hoaca388
        Badcaps
        • Jan 2022
        • 11730
        Try
        • N0f3ar
          • Oct 2016
          • 51
          • Bulgaria
          there is a problem with hp endpoint security controller on the unit
          next screen - system locked to turn off please press power button
          and this is it
          • hoaca388
            Badcaps
            • Jan 2022
            • 11730
            and this is it
            Re-flash the bios file I posted and the original EC file. Can you go to bios settings during the first boot ? Use the F10 button.
            • N0f3ar
              • Oct 2016
              • 51
              • Bulgaria
              now black screen and full speed fan
              • N0f3ar
                • Oct 2016
                • 51
                • Bulgaria
                Anybody?
                • lapfix
                  • Mar 2020
                  • 2720
                  • my workshop
                  if you open your 2 files with hxd yo will not find thee usual form of bios....so certainally theres another 3 chip
                  • N0f3ar
                    • Oct 2016
                    • 51
                    • Bulgaria
                    there definately only 2 bios chips
                    • satishkumar
                      • Sep 2015
                      • 164
                      • India
                      ur mbd is with AMD Cpu or Intel CPU ???
                      • satishkumar
                        • Sep 2015
                        • 164
                        • India
                        thanks
                        • N0f3ar
                          • Oct 2016
                          • 51
                          • Bulgaria
                          amd
                          • N0f3ar
                            • Oct 2016
                            • 51
                            • Bulgaria
                            Not booting , full speed fan and black screen
                            • N0f3ar
                              • Oct 2016
                              • 51
                              • Bulgaria
                              it is finally unlocked , but i have hp security controller error
                              can somebody help with this error
                              • png
                                • May 2022
                                how did you read and write the chips? did you desolder them or is it possible in circuit?
                                • hoaca388
                                  Badcaps
                                  • Jan 2022
                                  • 11730
                                  Whether or not the chip has to be removed from the motherboard is up to your programmer. With a trusted programmer there is no need to remove the chip from the motherboard.
                                  • png
                                    • May 2022
                                    Ok now I was able to get the dumps, but only by unsoldering the chips.. Now I am trying to unlock. I used the files posted above but without luck. Can somebody help?
                                    • hoaca388
                                      Badcaps
                                      • Jan 2022
                                      • 11730
                                      Try
                                      • N0f3ar
                                        • Oct 2016
                                        • 51
                                        • Bulgaria
                                        Please help remove hp endpoint security controller error
                                        • Syseng
                                          Lenovo P14s Gen 5 SVP unlock
                                          by Syseng
                                          This sums up discussion related to Lenovo P14s Gen5 in this thread. Credits go to Sbaro and especially Maxpower3. The locked dump is attached.
                                          The device is based on NM-F871 motherboard with Nuvoton NPCK397 series controller. The motherboard also contains three BIOS chips: two different Winbond chips for main BIOS and external EC flash, and also a Gigadevice chip which purpose I do not know. The password information is contained directly in controller and thus can be manipulated by reprogramming it, so reprogramming BIOS chips is technically not required, however you may wish to make...
                                          06-22-2025, 07:44 AM
                                        • remizbushka
                                          Dell inspirion 5775 bios "Unlock Setup fail"
                                          by remizbushka
                                          Hi sirs. please help
                                          Dell Inspiron 5775 bios locked "Unlock Setup fail"
                                          After generating the Password Recovery code, I go to the “Security” tab - “Locked Settings” - it says “Unlock Settings? I tried many wrong passwords and it shows an error to unlock settings [ Press any key ].
                                          What I did:
                                          I read the bios dump.
                                          Downloaded the bios update to 1.6.0 from the official Dell website, extracted the dump from it, updated the bios, but the problem persisted. Please help me to solve the problem....
                                          03-24-2025, 09:07 AM
                                        • salim5566
                                          loking for bio tool that hve all feature like ps5 bios and laptop bios unlock and repair 1 tool can do all please good tool?
                                          by salim5566
                                          Hi guys i like to buy tool that automatic unlock bios or find password also can flash and repair bios ic, looking for good tool have good software that have 1 click and unlock bios any recommend good tool? looking for sony ps5 and and laptop bios
                                          06-26-2025, 03:25 PM
                                        • Syavko1
                                          Unlock Bios HP Spectre x360 Convertible 14-ea0520na (2Z6W0EA)
                                          by Syavko1
                                          Hello, help me. I need to unlock the BIOS on my laptop. HP Spectre x360 Convertible 14-ea0520na (2Z6W0EA)
                                          I have access to Windows. Is it possible to unlock it through Windows? Do I need to unsolder the chip? ​
                                          01-22-2025, 02:04 PM
                                        • zenius
                                          by zenius
                                          12-08-2024, 06:13 AM
