Lenovo flex 5-14alc05
  • klenovo
    • Oct 2025
    • italy
    #321
    please SN: PW023V6G
    PN Board: MTM: 82HU00MTIX
    MO:PWN0B2511006
    IdeaPad Flex 5 14ALC05
    Thank you.
    • peste
      • Dec 2016
      • 13924
      • ROMANIA
      #322
      Originally posted by klenovo
      please SN: PW023V6G
      MO:PWN0B2511006
      Thank you.
      you have everything you need 6 posts above...
      • klenovo
        • Oct 2025
        • italy
        #323
        I've tried creating the new BIOS using the data from the old BIOS.
        When I do the write operation, the program writes it successfully, but during the verify process it fails at 50%.
        Maybe I'm not building the BIOS file correctly.
        Could you please clarify what exactly I should do or what I might be missing?
        • peste
          • Dec 2016
          • 13924
          • ROMANIA
          #324
          The bios chip must be unsoldered from the board before writing or reading..
          do not use the clip, you may have errors..if you do not have anything to unsolder it with,
          solder wires between the programmer and the bios chip..
          you need an SPI programmer...here is a video for example..https://www.youtube.com/watch?v=DWWi...nnel=ThisIsHow
          • Ludwigdallas
            • Oct 2025
            • 3
            Lenovo IdeaPad Flex 5 14ALC05
            sn r914d444
            mo r9n0b192500h
            help pls
            • LBTT1121
              • Nov 2024
              • 1239
              • Việt Nam
              #326
              sn r914d444
              mo r9n0b192500h
              help pls
              and what is your problem??
              • Ludwigdallas
                • Oct 2025
                • 3
                Flashing keyboard and lit caps lock with no display
                • Ludwigdallas
                  • Oct 2025
                  • 3
                  Never mind I got it! Thanks
                  • cricco56
                    • Aug 2018
                    • 3
                    • netherlands
                    #329
                    I have same bios issue, capslock and esc on no boot faulty bios. Can someone help me to edit bios ? Orijn bin file attached. Thanks a lot .
                    IDEALPAD FLEX 5 14ALC05
                    SN PW01X0S1
                    MO PWN0B240800E
                    • peste
                      • Dec 2016
                      • 13924
                      • ROMANIA
                      #330
                      SN PW01X0S1
                      MO PWN0B240800E
                      you have everything you need 14 posts above..
                      • cricco56
                        • Aug 2018
                        • 3
                        • netherlands
                        #331
                        I can not find any information, was busy long time editing bios but didn't work . I need help if someone can help. thanks
                        • primode
                          • Dec 2016
                          • mexico
                          #332
                          HI. I HAVE THIS LENOVO IDEAPAR FLEX 5 14 ALC05 -- BLACK SCREEN AND CAPSLK LIGHTED UP NO BOOT, PLEASE HELP WITH BIOS
                          MN- 82HU
                          S/N - PW001DD2
                          MTM - 82HU00JWUS
                            • 22293
                            MN- 82HU
                            S/N - PW001DD2
                            MTM - 82HU00JWUS
                            Everything you need is here -> https://www.badcaps.net/forum/troubl...95#post1769295
                            • cricco56
                              • Aug 2018
                              • 3
                              • netherlands
                              #334
                              copydmi script doesnt work , mybios file is 8mb . Bios files on posts 16mb .
                              • m1ch43lzm
                                • Mar 2019
                                • 1126
                                • Peru
                                #335
                                SN PW01X0S1
                                MO PWN0B240800E
                                BIOS backup is incomplete, the BIOS chip should be 16MB for this model
                                Select correct chip or equivalent in your programmer software, example: W25Q128JW 1.8V (128 Mbit = 16MB)
                                • deansanity16
                                  • Jun 2022
                                  • 21
                                  • philippines
                                  #336
                                  hello,can someone fix my bios.no display
                                  lenovo ideapad flex 5 14alc05
                                  model: 82hu
                                  s/n PW0419KK
                                  BOARD CODE: LC56-14A SVT 203021-1
                                  THANKS IN advance.
                                  motherboard code : LC56-14A SVT 203021-1 448.0MD08.0011 sn: R9122SNY Bios password...
                                  • peste
                                    • Dec 2016
                                    • 13924
                                    • ROMANIA
                                    #337
                                    model: 82hu
                                    s/n PW0419KK
                                    THANKS IN advance.
                                    bios extracted from Lenovo website update for Flex 5 14ALC05, Flex 5 15ALC05
                                    DMI 5EA000 - 5EDFFF
                                    KEYWIN 61709C - 6170B8 Attached Files if you find these attachements useful please consider making a small donation to the site
                                    • deansanity16
                                      • Jun 2022
                                      • 21
                                      • philippines
                                      #338
                                      same problem.no display, caps is on
                                      • danito
                                        • Jun 2016
                                        • 1259
                                        • Romania
                                        #339
                                        You may have another problem, not the bios.
                                        • dongle_ro
                                          • Nov 2025
                                          • Österreich
                                          #340
                                          sn PW015JQL
                                          Hello, I'm asking for help with a bios on a Lenovo Flex 5 14ALC05, it doesn't turn on and lights is blinking
                                          add original packaged bios
                                          thank you in advance
                                            Lenovo IdeaPad Flex 5 Hybrid (2-in-1) Flex Specification for Upgrade or Repair
                                            This specification for the Lenovo IdeaPad Flex 5 Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Flex 5 boardview and Flex 5 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Lenovo...
                                            09-07-2024, 07:20 AM
                                            09-07-2024, 06:38 AM
