HP X360 1030 g8 Bios unlock
  • Akintunde
    • Mar 2017
    • 154
    • Nigeria
    Re: HP X360 1030 g8 Bios unlock
    @ Mr hoaca388, Thanks for your time and Help. i really appreciate. i think the problem is from the Laptop.
    • omaryou
      • Aug 2017
      • 81
      • mexico
      hp elitebook 1030 x360 g8 32mb
      hello
      i need to unlock this hp elitebook 1030 x360 g8
      32mb
      • lapfix
        • Mar 2020
        • 2565
        • my workshop
        Re: hp elitebook 1030 x360 g8 32mb
        Originally posted by omaryou
        hello
        32mb
        You`ve tried RCUnlocker ?
        https://www.badcaps.net/forum/showthread.php?t=98539
        • omaryou
          • Aug 2017
          • 81
          • mexico
          Originally posted by lapfix
          Yes but not work because ec and bios is 32mb
          • omaryou
            • Aug 2017
            • 81
            • mexico
            can you help me pls
            • hardware1
              • Sep 2021
              • 2888
              • N/A
              #26
              hello
              32mb
              Here are your Unlocked files, program the both files together.
              In the first boot go to Bios menu and disable security options (Default).
              all donations are welcome,
              • omaryou
                • Aug 2017
                • 81
                • mexico
                #27
                worked 100%
                thanks bro
                • cpaskov3
                  • Sep 2010
                  • 4
                  #28
                  hello
                  32mb
                  • Vesko356
                    VIP Moderator
                    • Aug 2018
                    • 4386
                    • Bulgaria 🇧🇬
                    #29
                    Originally posted by cpaskov3
                    hello
                    32mb
                    Become a Badcaps supporter
                    Thanks to all supporters.​
                    • cpaskov3
                      • Sep 2010
                      • 4
                      #30
                      worked 100%
                      thanks bro
                      • stars-n-dust
                        • Apr 2019
                        • 59
                        HP Elitebook x360 1030 G8, please remove the password.
                        • Vesko356
                          VIP Moderator
                          • Aug 2018
                          • 4386
                          • Bulgaria 🇧🇬
                          #32
                          Are you sure it's the original EC dump? Because it looks like it's already been manipulated.
                          The serial number in the main dump is CND3062BT8, does it match the one at the factory label?
                          • stars-n-dust
                            • Apr 2019
                            • 59
                            The serial number is correct. Files were read three times and check for no errors.
                            • Vesko356
                              VIP Moderator
                              • Aug 2018
                              • 4386
                              • Bulgaria 🇧🇬
                              #34
                              OK, program main chip with this dump to see if it'll solve the problem, if not the dump must be edited additionally to boot in MPM mode.
                              • Holaa321
                                • Jun 2023
                                • 10
                                • United Kingdom
                                #35
                                Hi, I've got an Hp X360 1030 G8 Laptop. It has locked bios. Is it required to take off both the bios chip as well as the EC chip or is it possible just to use the bios chip?
                                Another thing is it possible for me to use the zip files which are unlocked for other laptop in this forum?
                                I would greatly appreciate your help in this matter.
                                Thank you
                                • aldopc
                                  • Jul 2017
                                  • 464
                                  • Chilito
                                  #36
                                  Thank you
                                  Hello, you must read and upload your in of the uec3 chip, it is always best to repair the original file, many times the bios of other computers do not work, especially in the new generations, and if they work, some detail may remain...
                                  • Holaa321
                                    • Jun 2023
                                    • 10
                                    • United Kingdom
                                    #37
                                    Hi, Thank you for your quick reply.
                                    I've taken off the main bios chip and made a copy of it. I am unsure what you mean(For which I apologize) by uec3 chip. Is this the chip next to the main bios chip or the one at the back of the board?
                                    Luckily I was able to make a copy (of the main Winbond BIOS chip)and I've attached it.
                                    I was able to find the uec3 chip on the motherboard. I will send a copy of it after reading it.
                                    Please let me know if there is anything else I may be missing. I appreciate your efforts.
                                    Last edited by Holaa321; 06-10-2023, 06:44 PM. Reason: Just adding a bit more infromation
                                    • aldopc
                                      • Jul 2017
                                      • 464
                                      • Chilito
                                      #38
                                      You must read the chip that I mentioned before, check the image.
                                      • Holaa321
                                        • Jun 2023
                                        • 10
                                        • United Kingdom
                                        #39
                                        Thank you for clarifying that I was able to get the chip off and got the data off I've attached both files.
                                        Once again I appreciate your help.
                                        • aldopc
                                          • Jul 2017
                                          • 464
                                          • Chilito
                                          #40
                                          Ok write just the uec3 test and comment the result.
                                          • zenius
                                            by zenius
                                            12-08-2024, 06:13 AM
                                            HP EliteBook x360 EquipoEliteBook x360 1030 G4 Hybrid (2-in-1) Specification for Upgrade or Repair
                                            This specification for the HP EliteBook x360 EquipoEliteBook x360 1030 G4 Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the EquipoEliteBook x360 1030 G4 boardview and EquipoEliteBook x360 1030 G4 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer...
                                            09-06-2024, 11:32 AM
                                            HP EliteBook x360 EliteBook x360 1030 G2 Hybrid (2-in-1) Specification for Upgrade or Repair
                                            This specification for the HP EliteBook x360 EliteBook x360 1030 G2 Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the EliteBook x360 1030 G2 boardview and EliteBook x360 1030 G2 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that...
                                            09-06-2024, 08:27 AM
                                            HP EliteBook x360 EliteBook x360 1030 G2 (ENERGY STAR) Hybrid (2-in-1) Specification for Upgrade or Repair
                                            This specification for the HP EliteBook x360 EliteBook x360 1030 G2 (ENERGY STAR) Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the EliteBook x360 1030 G2 (ENERGY STAR) boardview and EliteBook x360 1030 G2 (ENERGY STAR) schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                                            09-06-2024, 06:40 AM
                                            09-06-2024, 05:33 AM
