bios Nitro 5 FH51/FH51M LA-J871P
Every donation made will go towards server fees and maintenance costs. -
Dump BiosAttached FilesComment
try..........
Hello everyone!
I needed help to clean the ME region of this original Bios Dump.
I just replaced PCH, original one was shorted and had the die cracked.
Ive quickly tested and it charges battery, turns on and off, but does not POST.
Hope all is good with PCH and just needs a clean me
Heres the info of the device and board:
Motherboard FH51M LA-J871P Rev: 1B
ACER MODEL: AN515-55-73G9
S/N: NHQ7MEF004034141583400
SNID: 03408226434
Attached File bkp original dump
Thanks in advance!
ACER MODEL: AN515-55-73G9S/N: NHQ7MEF004034141583400SNID: 03408226434Attached Files↵
https://www.badcaps.net/donateComment
Can anyone help this bios no display
Motherboard FH51M LA-J871P Rev: 1A
ACER MODEL: AN515-55-50B1
S/N: NHQ7RSI0040300C9AE3400
SNID: 03005163034Attached FilesComment
by macabookHello everyone,
Channel: BIOS Requests ONLY!
07-24-2025, 02:17 PM -
by martin83Hello everyone.
I'm here to ask for help troubleshooting an issue with my Acer Nitro 5 An55-515. Board number fh51m LAJ871P .
The laptop turns on without any image, and after inspection, I noticed the 1.2V voltage was reading 8V spikes. The PQM1 MOSFET's gate was shorted to the source.
I replaced PQM1, PQM2, and PUM1. After turning on the machine, the 1.2V voltage appears correctly for about 1 minute, but after that, PQM1 shorted again. The MOSFET and controller assembly has already been replaced twice and continues to blow. I can't understand what's going on. I should also add... -
by jbonavitaHi, my laptop wont boot at all
Some issues
Things I tried
1- Update / clear ME: Took the non working bios, made a backup, and did this: https://www.badcaps.net/forum/troubl...theory/trouble...-
- Loading...
