Lenovo V15-IIL 82C5 Bios please
Become a Badcaps supporter
Thanks to all supporters.
----------------------------------------------------------------------------------------------------------------------------------------------------------Doctrina est fructus dulcis, radicis amarae.. -
I need help, i'm not sure if a bios backup is okay. Can someone verify it is it okay?
Lenovo V15-IIL Model: 82C5
S/N: PF2G48Y6
Board: GS44D/GS554D NM-C711 Rev. 1.0 2019-09-18
CPU: I5-1035G1
Bios was extracted using CH341A Black board
BIOS Chip: Gigadevice 25b127dsig
And if it is okay, can onboard ram be disabled? i need only SO-DIMM.Attached FilesComment
hello i need to unlock password thanks SN / PF32LT4T MODEL V15-IIL / 82C5Attached FilesComment
Brand: LENOVO
Serial: PF2GCT07
Model name: V15-IIL
Main Board: NM-C711
Original bios attached.Attached FilesComment
Lenovo V15-IIL Intel 10TH gen bios password removal
Model Name : S2C5
SN : PF2CBP07
MTM : 82C500A3MZ
this is my dumpAttached FilesComment
Hi.This Lenovo is delay to display screen
please Clean bios file
V15-IIL (i3 gen10) whitout GPU
GS44D-GS54D NM-C711 rev1.0 2019.09.18
Model:82C5
MTM:82C500T6AK
MO:PF9XB1827012Attached FilesComment
bios extracted from Lenovo site update for S145-14IIL, S145-15IIL, V14-IIL, V15-IIL
DMI 622000 - 623FFFDue to a lack of donations, server free space at a critical level, and possible closure of Bios Requests all donations are welcome, click:
Every donation made will go towards server fees and maintenance costs.Comment
V15-IIL Laptop (Lenovo) - Type 82C5
sn PF1CKES8
motherboard NM-C711 REV 1.0
OnBoard RAM disabled??Attached FilesComment
Try this file and provide feedback:
hello
Can someone please fix this bios,
simptoms: no power
i tried other bios from the forum works but random shutdowns
model lenovo V16-IIL 82C5
PF2960XN
mother board: GS44D/GS54D NM-C711 REV 1.0
Intel i3 onboard RAM
Thank youAttached FilesComment
Try the bios at post 33 ,it is a virgin bios. If you can use a hex editor copy your DMI from your backup to the new bios using the offsets that peste has posted. If it doesn`t work try the RAM disabled bios by Stefan Steff aboveComment
by abhorsenHey guys,
Hope you all are doing well. I come here from Win-Raid because I am having issues disabling Flash Protection Range Registers so I can flash my BIOS from within Windows using Intel's IFW tool/using flashrom within Linux, however I cannot due to the above mentioned error.
Here is my thread on Win-Raid detailing the whole process I went through: https://winraid.level1techs.com/t/re...h-gen/95478/27
Essentially I managed to boot into Windows while shorting PINs 1+5 of my audio chip to disable the HAP bit...-
by Vesko356First of all thanks to all of our members who have posted previously all methods posted here.
Operating system and OS version.If...-
Channel: BIOS Requests ONLY!
by HotSaladMan*##*#*#*#*#*#Cringe Warning Used Clips for Tl866ii Plus Backups#*#*#*#*#*#
Model : Lenovo ThinkBook 14S Yoga ITL
S/N : MP28JT19
MFG Date : 2022/02/09
Factory ID PRC4
MO : MPNXB26080FX
MTM : 20WE001US
MODULE FCC ID : PD9AX201NG
IC : 1000M-AX201NG
BOARD INFO
FLV34 LA-KO51P
REV : 1B 2020-08-24
Bit of Info
Using Tl866ii Plus, it would scan the chip but wouldn't not detect the
chip id, so i would always uncheck the id check, so it would bypass the error
i did in fact make...-
Hello!
A few days ago I bricked my Lenovo x1 nano gen 1 while updating the bios/fw from linux.
No the machine power up, but it stuck in a recovery state and I can not do much.
Lenovo X1 Nano Gen 1
Type: 20UN - X021US
S/N: R9 - 10W2D9
I would like to flash a new BIOS/FW on the chip using a CH341a programmer but ... I actually don't know which "chip" on the motherboard to target 🤦♂️
So here I am to ask for help.
I opened the laptop and I found a chip that may be the target, on it I've:
Winbond 25R256...2 Photos-
by to5it0Need Clean BIOS/EC Bin File for Lenovo ThinkPad Yoga 11e - Stuck with 0275 Error CMS
I am attempting a repair on a Lenovo ThinkPad Yoga 11e that is currently stuck at boot with the error: "0275 error CMS" even after setup new bios battery and will not allow me to enter the BIOS/Setup.
This is a critical issue that I believe requires flashing the BIOS chip directly using a programmer (e.g., CH341A/RT809H), as standard software updates or resets are not possible.
I have opened the laptop and identified the main BIOS chip...2 Photos-
- Loading...
