Acer prediator ph17-53 bios
  • Kesavan
    • Aug 2016
    • 205
    • India
    Acer prediator ph17-53 bios need
    board part no: 6050a3087502-mb-a03(a3)
    old bios attached
    • 21922
    Re: Acer prediator ph17-53 bios
    old bios attached
    Post the laptop serial number,then it can be checked against the serial in your backup.
    • Kesavan
      • Aug 2016
      • 205
      • India
      please find serial no image of laptop
      • DanielDacko
        • Mar 2015
        • 328
        • Macedonia
        Extracted from latest update, try and report back...
        I don't provide help for people using CH341A and a clip.
          • 21922
          Originally posted by danieldacko
          extracted from latest update, try and report back...
          dmi
          • Kesavan
            • Aug 2016
            • 205
            • India
            Thank you so much brother. This bios is working good..
            • macabook
              by macabook
              🧩 Initial Issue
              07-24-2025, 02:17 PM
            • aico60
              Acer Nitro 5 AN515-46 DMI not working
              by aico60
              I am working on an Acer Nitro 5 AN515-46, board HH51R LA-M002P Rev: 1A with an AMD CPU and Insyde Bios rev 5.
              Short issue description: BIOS does not recognize any of the DMI data.
              History of the laptop:
              The seller of the laptop said that it shut down during a BIOS update.
              I bought in in a condition where it turned on but did not post.
              While waiting for my RT809F to arrive, I tried to perform a Crisis recovery, which messed up the EC firmware, so... the laptop stopped even turning on. Power and Charging LEDs didn't work either...
              05-06-2025, 08:44 AM
            • zarabota
              Acer Aspire A717-71G - problem BIOS with keyboard
              by zarabota
              I am experiencing the following issue with my laptop. I have an Acer Aspire A717-71G with a motherboard model C5MMH/C7MMH LA-E911P Rev. 1A. Unfortunately, the original board stopped working, so I purchased a replacement. The new board is the same model but a different revision (Rev. 1B). From what I understand, this should not cause compatibility problems.
              However, the replacement board came with a BIOS version intended for the Acer Nitro 5 AN515-51, which causes the keyboard to function incorrectly. I attempted to reflash the BIOS chip using a CH341A programmer...
              09-03-2025, 01:58 AM
            • verniumEN
              Acer Extensa 15 EX215-23-R7NG - BIOS, badly need help :(
              by verniumEN
              My laptop model is EX215-23-R7NG
              BIOS chip XM25QU128C
              Here is my original bin file, as well as how the BIOS chip looks like
              My situation is if I press my laptop power on, fan turns on for the first five seconds and turns off, no display (not even acer), but power indicator is on, and the CPU gets warm, even caught one time if powered on for long (before an hour) the fan turns on again, is it only right that I'm approaching via BIOS?
              Before I got into this situation, I was just watching movies, and while turned on, pressed the battery reset button and cleaned...
              04-21-2025, 02:31 AM
            • eivel-ice
              need help on bios of acer 514-53-37wq
              by eivel-ice
              good day to everyone,
              i have an acer n19h2 model 514-53-37wq
              s/n : NXHUPSP001035081D02N00
              HISTORY : i only need to replace keyboard and when i finished replacing keyboard, it power on but blue light and charging only, no display and fan is not running. i tried to check if i damage anything on the motherboard but i dont see any damage at all, i tester it and no short or grounded parts,
              i searched here and found this https://www.badcaps.net/forum/troubl...blets-and-mobi...
              03-05-2025, 12:22 PM
