EL4C4/FL454 LA-H082P bios
  • napilsas
    • Mar 2016
    • 10
    • saudia arabia
    hi
    I need dump bios for this laptop
    EL4C4/FL454 LA-H082P REV:1.0 bios bin
    thank u
    • 21692
    Re: EL4C4/FL454 LA-H082 bios
    Originally posted by napilsas
    hi
    thank u
    Post the full laptop make and model number, also your bios backup
    • DanielDacko
      • Mar 2015
      • 326
      • Macedonia
      hi
      thank u
      Try this backup, but you should listen to SMDFlea and post the things he mentioned in order to get newest bios with your DMI included.
      I don't provide help for people using CH341A and a clip.
      • napilsas
        • Mar 2016
        • 10
        • saudia arabia
        thank u
        lenovo idealpad c340
        el4c4/fl454 la-h082p
        • napilsas
          • Mar 2016
          • 10
          • saudia arabia
          thank u
          i'll try it
          • dokterpc
            • Aug 2020
            • 47
            • Indonesia
            this isn't work on lenovo ip c340-14il with code board el4c4/fl454 la-h082p rev 1.0, can you give for la-h082p?
            • dokterpc
              • Aug 2020
              • 47
              • Indonesia
              tis my old bios
              • hoaca388
                Badcaps
                • Jan 2022
                • 12281
                Originally posted by dokterpc
                tis my old bios
                Reading your bios chip again. The file you posted is only half, the other half is empty.
                • dokterpc
                  • Aug 2020
                  • 47
                  • Indonesia
                  i just get it, maybe this bios had flashed by other engineer
                  • magneh
                    • Apr 2014
                    • 610
                    • Portugal
                    Hey guys
                    Machine turns on with no image. All voltages present
                    Can someone clear ME on the bios backup?
                    • hardware1
                      • Sep 2021
                      • 2946
                      • N/A
                      Originally posted by magneh
                      Hey guys
                      Here's your New Bios file, it's a Virgin Bios from Lenovo with your DMI and Windows Key.
                      Serial Number: MP1PB0C8.
                      all donations are welcome,
                      • macadam
                        • Apr 2016
                        • 51
                        • United Kingdom
                        hi
                        need help
                        lenovo ideapad c340-14iwl
                        EL4C1/EL451
                        LA-H081P rev 1.0
                        no display
                        can you help with a bios please
                        original bios attached
                        thanks
                        Last edited by Vesko356; 06-08-2023, 08:09 AM. Reason: Attached archive removed. Thread hijack
                        • Vesko356
                          VIP Moderator
                          • Aug 2018
                          • 4386
                          • Bulgaria 🇧🇬
                          Originally posted by macadam
                          hi
                          need help
                          EL4C1/EL451
                          LA-H081P rev 1.0
                          no display
                          thanks
                          Read the rules before posting:
                          Do NOT hijack threads.
                          Become a Badcaps supporter
                          Thanks to all supporters.
                          • mferna14
                            • Jun 2018
                            • 1046
                            Hi buddies., working on this Lenovo Laptop. Problem is sometimes there is display & boots & then shuts down., & at times no display at all. All voltages are present, I assume that Bin file has to be re-done. Original BIN files is attached.
                            Lenovo IdeaPad FLEX-14IML, Serial # MP1QB93T​ , Motherboard #: EL4CA/FL454 LA-H082P Rev: 1.0 2019-07-05 ... thanks for the help
                            • mferna14
                              • Jun 2018
                              • 1046
                              Don't worry about this bin. I easred the BIOS Chip & re-programmed the Original bin to the IC. All worked fine. Thanks
                              • mferna14
                                • Jun 2018
                                • 1046
                                Re-posted: I think there is a BIOS Problem, it just does not give display at time just shuts down. Kindly re-built please.
                                Lenovo IdeaPad FLEX-14IML, Serial # MP1QB93T , Motherboard #: EL4CA/FL454 LA-H082P Rev: 1.0 2019-07-05 ... thanks for the help​
                                • hoaca388
                                  Badcaps
                                  • Jan 2022
                                  • 12281
                                  FLEX-14IML Laptop (ideapad) - Type 81XG
                                  • Habble7
                                    by Habble7
                                    Suspected Cause:
                                    Troubleshooting Attempts:
                                    05-22-2025, 07:28 AM
                                  • haitham sharabati
                                    [Request] Clean BIOS dump for HP 15-da2007ne (8XF55EA#ABV) - N4000 - BIOS Lock
                                    by haitham sharabati
                                    Hello engineers 😀,
                                    I’m kindly requesting a clean and unlocked BIOS dump for the following HP laptop, as it’s bricked after flashing SP152727. The system now keeps rebooting, and the original issue was an Administrator / Power-On Password that I can no longer access.😏
                                    🔧 Device Info:
                                    - Model: HP 15-da2007ne
                                    - Product Number: 8XF55EA#ABV
                                    - Serial Number: CND0338P0D
                                    - CPU: Intel Celeron N4000
                                    - EC/BIOS Chip: [Add chip number from the motherboard or BIOS chip]
                                    💀 Problem:😅
                                    - Device shows “Administrator Password”...
                                    08-07-2025, 04:54 AM
                                  • Citymin
                                    by Citymin
                                    S/N : 5RNK9FFT70...
                                    08-05-2025, 05:12 AM
                                  • DynaxSC
                                    by DynaxSC
                                    11-17-2023, 10:56 AM
                                  • greelidd
                                    K6604J Vivobook RTX 4070 BIOS Dump Request
                                    by greelidd
                                    Hi all! Tldr: need a bios dump (.bin format) for K6604J (rtx 4070 and i9-13980hx)
                                    Longer story: my vivobook stopped booting after i switched out the thermal paste. I think the BIOS got corrupted. Everything i tried didn’t work until finally i decided to buy a CH341A BIOS programmer and just send over the BIOS directly from another PC onto the BIOS chip. I connected fine and backed up the existing BIOS, but i can’t find a clean BIOS that’s a .bin format. And I tried using UEFI software to extract all the files from the ASUS BIOS .exe file and get to the .bin but it was a .302...
                                    09-01-2025, 06:14 PM
