Lenovo IdeaPad L340-17IRH - need BIOS and EC dump
Re: Lenovo IdeaPad L340-17IRH - need BIOS and EC dump
Check from the serial number that the bios has been downloaded correctly. Check the hardware again.
Mọi khoản quyên góp cho badcaps đều được hoan nghênh, hãy nhấp vào liên kết này để quyên góp. Cảm ơn tất cả những người ủng hộ----------------------------------------------------------------------------------------------------------------------------------------------------------------Comment
Lenovos usually have a Model Type/Machine Type part number as well as a serial.
The bios youve tried already are ok,your problem is somewhere else.Comment
my laptop behaves very similarly. The power button flashes 6 times, current consumption is about 0.30A. Unfortunately, I do not know the exact model or serial number because the sticker has been damaged.
I have attached the bios I read.
I would ask for the correct bios and input to the EC.Attached FilesComment
At least write your Motherboard Number.----------------------------------------------------------------------------------------------------------------------------------------------------------------------
all donations are welcome,
>>>>> click on this link to donate via PayPal. <<<<<
----------------------------------------------------------------------------------------------------------------------------------------------------------------------Comment
FG541/FG741 NM-C361 rev.1.0
I was able to find the model and serial number on the box.
IdeaPad L340-17IRH
SN : PF1BRP56Last edited by fifi88; 03-02-2023, 09:28 AM.Comment
According to your Serial Number, the file which I attached should works fine.----------------------------------------------------------------------------------------------------------------------------------------------------------------------
Hi!
Can somebody make me good ec, spi rom and bios file too for this laptop?
IdeaPad L340-17IRH Gaming
Model Name: 81LL
SN: PF1TB56 MTM: 81LLOOCYGE
Mfg Date 2020/10/17 Factory ID. JVHFC1
MO: PE9XB0A17136
NM-C361 rev 1.0
Thanks!Last edited by Miim113; 05-06-2023, 12:27 AM.Comment
if you read the whole thread before posting, you would have solved the problem a long time ago.. you would have known you had to go to post #6... when you make a bios request, they always post the bios even if it is corrupted..Due to a lack of donations, server free space at a critical level, and possible closure of Bios Requests all donations are welcome, click:
Every donation made will go towards server fees and maintenance costs.Comment
regardsComment
you have at post #6 the interval in which the DMI information is located, use the HxD program and pass the information from your bios, into the bios from post #6 which is virgin.. select the area and (copy - paste)..Due to a lack of donations, server free space at a critical level, and possible closure of Bios Requests all donations are welcome, click:
You can give me the adresses? Please... I must to edit in 2 files?Comment
https://*******/file/szgHWLjS#4S7qMF...mTyYovXNwn1v00
this is the modified bios what I write in chipComment
Read the rules before posting:
Become a Badcaps supporter
Thanks to all supporters.
----------------------------------------------------------------------------------------------------------------------------------------------------------Doctrina est fructus dulcis, radicis amarae..Comment
You must attach files directly to your post instead of linking to external websites!
.Attached FilesLast edited by Miim113; 05-06-2023, 06:44 AM.Comment
by mximiliandzGood morning, gentlemen, I hope you can help me with my laptop, I told you that I saved it about 2 years ago because it wouldn't turn on, now I have a ch341a programmer, I made a backup of the bios, I flashed an original downloaded from lenovo and it started, but it turned off after a few minutes, I entered the bios configuration and the brand, model, serial number, windows serial number, etc. did not appear, I request your help, I did everything I found in the forum but I could not solve it, also now it won't start again, it turns on but the fan does not turn, I will share all the information...
Channel: BIOS Requests ONLY!
by jendkkd jejeSo a couple of years ago i got a bios update through Lenovo Vantage, so i installed it and bricked my whole BIOS, so i couldn't fix it so i put that ideapad in a box, 3 years later i found that one PC and want to recover it to switch from a 2014 hp laptop to this one.
I found a method to recover the BIOS of many lenovo laptops tha consists in pluging in a USB Flash with the BIOS files and power on the laptop with Fn + R keys pressed until fans go loud and start beeping loud, but nothing worked, so i think filename is wrong, i tried naming the bios file as 07WW.BIN, BIOS.BIN, BIOS.fd,...10-11-2024, 03:12 PM -
by AHmad_SalalHello all,
I have a Lenovo Thinkstation P500 that is stuck at post with no display, it happened after I changed the memory timings in bios. I can not clear CMOS using the jumper on the motherboard, also tried re-flashing bios suing a USB stick but it also doesn't work. The only solution that I can think of right now is re-flashing the bios chip using an external programmer but the problem is that I don't have the bios dump of p500 for flashing externally and I don't know the location of bios chip. If someone can provide the bios dump and bios chip location it would be really helpful....-
by hirensLenovo ideapad 3 14IGL05 bios dump needed
model: 81wh
sn: pf36ta6h
board no: nm-c961 gs453/gs553
hey guys above is my laptop info
it only blinks the power button kindly help me with a working dump
old dump attached...-
by lngcsHi, could some one please help extract or provide bios dump for Lenovo ideapad1 15alc7, MTM:8244007aau,s/n:pf4k2bzn.thanks...
- Loading...
