Lenovo IdeaPad L340-17IRH - need BIOS and EC dump
    • 21204
    Re: Lenovo IdeaPad L340-17IRH - need BIOS and EC dump
    Originally posted by outsider
    Hmmm maybe EC? You have dump?
    Post the laptop serial number.
    • outsider
      • Apr 2014
      • 104
      • localhost
      Originally posted by hoaca388
      EC file
      Still no change
      • outsider
        • Apr 2014
        • 104
        • localhost
        Originally posted by smdflea
        post the laptop serial number.
        sn: Pf1blapu
        • hoaca388
          Badcaps
          • Jan 2022
          • 11902
          Check from the serial number that the bios has been downloaded correctly. Check the hardware again.
            • 21204
            I don't undersand.
            sn: Pf1blapu
            Lenovos usually have a Model Type/Machine Type part number as well as a serial.
            The bios youve tried already are ok,your problem is somewhere else.
            • fifi88
              • Jun 2015
              • 3
              • Poland
              #26
              my laptop behaves very similarly. The power button flashes 6 times, current consumption is about 0.30A. Unfortunately, I do not know the exact model or serial number because the sticker has been damaged.
              I have attached the bios I read.
              I would ask for the correct bios and input to the EC.
              • hardware1
                • Sep 2021
                • 2940
                • N/A
                #27
                Try this file, it's a Virgin BIOS from Lenovo with your DMI.
                At least write your Motherboard Number.
                all donations are welcome,
                • fifi88
                  • Jun 2015
                  • 3
                  • Poland
                  #28
                  Your file is same as my backup.
                  FG541/FG741 NM-C361 rev.1.0
                  I was able to find the model and serial number on the box.
                  IdeaPad L340-17IRH
                  SN : PF1BRP56
                  • hardware1
                    • Sep 2021
                    • 2940
                    • N/A
                    #29
                    IdeaPad L340-17IRH
                    SN : PF1BRP56
                    You mean my file gives you the same symptoms or behavior?
                    According to your Serial Number, the file which I attached should works fine.
                    • Miim113
                      • May 2023
                      • 10
                      • Romania
                      #30
                      Hi!
                      Can somebody make me good ec, spi rom and bios file too for this laptop?
                      IdeaPad L340-17IRH Gaming
                      Model Name: 81LL
                      SN: PF1TB56 MTM: 81LLOOCYGE
                      Mfg Date 2020/10/17 Factory ID. JVHFC1
                      MO: PE9XB0A17136
                      NM-C361 rev 1.0
                      Thanks!
                      • peste
                        • Dec 2016
                        • 12973
                        • ROMANIA
                        #31
                        Originally posted by Miim113
                        Hi!
                        Model Name: 81LL
                        MO: PE9XB0A17136
                        NM-C361 rev 1.0
                        Thanks!
                        if you read the whole thread before posting, you would have solved the problem a long time ago.. you would have known you had to go to post #6... when you make a bios request, they always post the bios even if it is corrupted..
                        • Miim113
                          • May 2023
                          • 10
                          • Romania
                          #32
                          Hi. Don't need to put sn? The laptop was at many services, and don't have nothing... I wolud put new chips...
                          regards
                          • peste
                            • Dec 2016
                            • 12973
                            • ROMANIA
                            #33
                            regards
                            you have at post #6 the interval in which the DMI information is located, use the HxD program and pass the information from your bios, into the bios from post #6 which is virgin.. select the area and (copy - paste)..
                            • Miim113
                              • May 2023
                              • 10
                              • Romania
                              #34
                              You can give me the adresses? Please... I must to edit in 2 files?
                              • Miim113
                                • May 2023
                                • 10
                                • Romania
                                #35
                                In ec what need to modify?
                                  • 21204
                                  forget the EC, just flash the bios from post #6
                                  • Miim113
                                    • May 2023
                                    • 10
                                    • Romania
                                    #37
                                    Same result... nothing changed
                                    • Miim113
                                      • May 2023
                                      • 10
                                      • Romania
                                      #38
                                      https://*******/file/szgHWLjS#4S7qMF...mTyYovXNwn1v00
                                      this is the modified bios what I write in chip
                                      • Vesko356
                                        VIP Moderator
                                        • Aug 2018
                                        • 4386
                                        • Bulgaria 🇧🇬
                                        #39
                                        You must attach files directly to your post instead of linking to external websites!
                                        Read the rules before posting:
                                        Become a Badcaps supporter
                                        Thanks to all supporters.
                                        • Miim113
                                          • May 2023
                                          • 10
                                          • Romania
                                          #40
                                          Sorry man!
                                          • jendkkd jeje
                                            Lenovo IdeaPad 330 15-AST 81D6 BIOS Recovery
                                            by jendkkd jeje
                                            So a couple of years ago i got a bios update through Lenovo Vantage, so i installed it and bricked my whole BIOS, so i couldn't fix it so i put that ideapad in a box, 3 years later i found that one PC and want to recover it to switch from a 2014 hp laptop to this one.
                                            I found a method to recover the BIOS of many lenovo laptops tha consists in pluging in a USB Flash with the BIOS files and power on the laptop with Fn + R keys pressed until fans go loud and start beeping loud, but nothing worked, so i think filename is wrong, i tried naming the bios file as 07WW.BIN, BIOS.BIN, BIOS.fd,...
                                            10-11-2024, 03:12 PM
                                          • joven016
                                            Lenovo Ideapad S145 need working bios HELP!!
                                            by joven016
                                            Problem is blinking power led only
                                            i don't know exactly if it's s145-15igm or s145-14igm
                                            have a backup bios file but i dont know the serial.. coz text already erased at the back of the cover
                                            Mother board : fs440fs541 nm-c111 rev 1.0 2019-01-08
                                            Already tested some of posted bios here
                                            S145-14igm - success but invalid serial and not booting on OS
                                            S145-15igm - success with serial and some other info in bios but still not booting on OS
                                            already tried installing new windows but always booting on bios setup
                                            windows installer flash drive detected on...
                                            08-21-2025, 10:55 PM
                                          • AHmad_Salal
                                            Need BIOS Dump/ROM for Lenovo Thinkstation p500
                                            by AHmad_Salal
                                            Hello all,
                                            I have a Lenovo Thinkstation P500 that is stuck at post with no display, it happened after I changed the memory timings in bios. I can not clear CMOS using the jumper on the motherboard, also tried re-flashing bios suing a USB stick but it also doesn't work. The only solution that I can think of right now is re-flashing the bios chip using an external programmer but the problem is that I don't have the bios dump of p500 for flashing externally and I don't know the location of bios chip. If someone can provide the bios dump and bios chip location it would be really helpful....
                                            11-28-2023, 05:28 AM
                                          • Ahari
                                            by Ahari
                                            I...
                                            08-13-2025, 06:12 AM
                                          • mximiliandz
                                            help bios lenovo ideapad s145-14iil type 81w6
                                            by mximiliandz
                                            Good morning, gentlemen, I hope you can help me with my laptop, I told you that I saved it about 2 years ago because it wouldn't turn on, now I have a ch341a programmer, I made a backup of the bios, I flashed an original downloaded from lenovo and it started, but it turned off after a few minutes, I entered the bios configuration and the brand, model, serial number, windows serial number, etc. did not appear, I request your help, I did everything I found in the forum but I could not solve it, also now it won't start again, it turns on but the fan does not turn, I will share all the information...
                                            06-20-2025, 06:50 AM
