Lenovo IdeaPad L340-17IRH - need BIOS and EC dump
    • 20416
    Re: Lenovo IdeaPad L340-17IRH - need BIOS and EC dump
    Originally posted by outsider
    Hmmm maybe EC? You have dump?
    Post the laptop serial number.
    • outsider
      • Apr 2014
      • 104
      • localhost
      Originally posted by hoaca388
      EC file
      Still no change
      • outsider
        • Apr 2014
        • 104
        • localhost
        Originally posted by smdflea
        post the laptop serial number.
        sn: Pf1blapu
        • hoaca388
          Badcaps
          • Jan 2022
          • 11354
          • Viet Nam
          Check from the serial number that the bios has been downloaded correctly. Check the hardware again.
            • 20416
            I don't undersand.
            sn: Pf1blapu
            Lenovos usually have a Model Type/Machine Type part number as well as a serial.
            The bios youve tried already are ok,your problem is somewhere else.
            • fifi88
              • Jun 2015
              • 3
              • Poland
              #26
              my laptop behaves very similarly. The power button flashes 6 times, current consumption is about 0.30A. Unfortunately, I do not know the exact model or serial number because the sticker has been damaged.
              I have attached the bios I read.
              I would ask for the correct bios and input to the EC.
              • hardware1
                • Sep 2021
                • 2912
                • N/A
                #27
                Try this file, it's a Virgin BIOS from Lenovo with your DMI.
                At least write your Motherboard Number.
                all donations are welcome,
                • fifi88
                  • Jun 2015
                  • 3
                  • Poland
                  #28
                  Your file is same as my backup.
                  FG541/FG741 NM-C361 rev.1.0
                  I was able to find the model and serial number on the box.
                  IdeaPad L340-17IRH
                  SN : PF1BRP56
                  • hardware1
                    • Sep 2021
                    • 2912
                    • N/A
                    #29
                    IdeaPad L340-17IRH
                    SN : PF1BRP56
                    You mean my file gives you the same symptoms or behavior?
                    According to your Serial Number, the file which I attached should works fine.
                    • Miim113
                      • May 2023
                      • 10
                      • Romania
                      #30
                      Hi!
                      Can somebody make me good ec, spi rom and bios file too for this laptop?
                      IdeaPad L340-17IRH Gaming
                      Model Name: 81LL
                      SN: PF1TB56 MTM: 81LLOOCYGE
                      Mfg Date 2020/10/17 Factory ID. JVHFC1
                      MO: PE9XB0A17136
                      NM-C361 rev 1.0
                      Thanks!
                      • peste
                        • Dec 2016
                        • 12295
                        • ROMANIA
                        #31
                        Originally posted by Miim113
                        Hi!
                        Model Name: 81LL
                        MO: PE9XB0A17136
                        NM-C361 rev 1.0
                        Thanks!
                        if you read the whole thread before posting, you would have solved the problem a long time ago.. you would have known you had to go to post #6... when you make a bios request, they always post the bios even if it is corrupted..
                        • Miim113
                          • May 2023
                          • 10
                          • Romania
                          #32
                          Hi. Don't need to put sn? The laptop was at many services, and don't have nothing... I wolud put new chips...
                          regards
                          • peste
                            • Dec 2016
                            • 12295
                            • ROMANIA
                            #33
                            regards
                            you have at post #6 the interval in which the DMI information is located, use the HxD program and pass the information from your bios, into the bios from post #6 which is virgin.. select the area and (copy - paste)..
                            • Miim113
                              • May 2023
                              • 10
                              • Romania
                              #34
                              You can give me the adresses? Please... I must to edit in 2 files?
                              • Miim113
                                • May 2023
                                • 10
                                • Romania
                                #35
                                In ec what need to modify?
                                  • 20416
                                  forget the EC, just flash the bios from post #6
                                  • Miim113
                                    • May 2023
                                    • 10
                                    • Romania
                                    #37
                                    Same result... nothing changed
                                    • Miim113
                                      • May 2023
                                      • 10
                                      • Romania
                                      #38
                                      https://*******/file/szgHWLjS#4S7qMF...mTyYovXNwn1v00
                                      this is the modified bios what I write in chip
                                      • Vesko356
                                        VIP Moderator
                                        • Aug 2018
                                        • 4386
                                        • Bulgaria 🇧🇬
                                        #39
                                        You must attach files directly to your post instead of linking to external websites!
                                        Read the rules before posting:
                                        Become a Badcaps supporter
                                        Thanks to all supporters.
                                        • Miim113
                                          • May 2023
                                          • 10
                                          • Romania
                                          #40
                                          Sorry man!
                                          • mximiliandz
                                            help bios lenovo ideapad s145-14iil type 81w6
                                            by mximiliandz
                                            Good morning, gentlemen, I hope you can help me with my laptop, I told you that I saved it about 2 years ago because it wouldn't turn on, now I have a ch341a programmer, I made a backup of the bios, I flashed an original downloaded from lenovo and it started, but it turned off after a few minutes, I entered the bios configuration and the brand, model, serial number, windows serial number, etc. did not appear, I request your help, I did everything I found in the forum but I could not solve it, also now it won't start again, it turns on but the fan does not turn, I will share all the information...
                                            06-20-2025, 06:50 AM
                                          • jendkkd jeje
                                            Lenovo IdeaPad 330 15-AST 81D6 BIOS Recovery
                                            by jendkkd jeje
                                            So a couple of years ago i got a bios update through Lenovo Vantage, so i installed it and bricked my whole BIOS, so i couldn't fix it so i put that ideapad in a box, 3 years later i found that one PC and want to recover it to switch from a 2014 hp laptop to this one.
                                            I found a method to recover the BIOS of many lenovo laptops tha consists in pluging in a USB Flash with the BIOS files and power on the laptop with Fn + R keys pressed until fans go loud and start beeping loud, but nothing worked, so i think filename is wrong, i tried naming the bios file as 07WW.BIN, BIOS.BIN, BIOS.fd,...
                                            10-11-2024, 03:12 PM
                                          • AHmad_Salal
                                            Need BIOS Dump/ROM for Lenovo Thinkstation p500
                                            by AHmad_Salal
                                            Hello all,
                                            I have a Lenovo Thinkstation P500 that is stuck at post with no display, it happened after I changed the memory timings in bios. I can not clear CMOS using the jumper on the motherboard, also tried re-flashing bios suing a USB stick but it also doesn't work. The only solution that I can think of right now is re-flashing the bios chip using an external programmer but the problem is that I don't have the bios dump of p500 for flashing externally and I don't know the location of bios chip. If someone can provide the bios dump and bios chip location it would be really helpful....
                                            11-28-2023, 05:28 AM
                                          • hirens
                                            Lenovo ideapad 3 14IGL05 bios dump needed
                                            by hirens
                                            model: 81wh
                                            sn: pf36ta6h
                                            board no: nm-c961 gs453/gs553
                                            hey guys above is my laptop info
                                            it only blinks the power button kindly help me with a working dump
                                            old dump attached...
                                            07-21-2023, 04:48 AM
                                          • bob113313
                                            extract bios dump file from exe Lenovo amd ideapad 5 15alc05
                                            by bob113313
                                            first of all my apologies for my English (I don't speak it very well, I am French).
                                            I am trying to troubleshoot a lenovo ideapad 5 15alc05 ryzen 7 that boots but remains in black screen.
                                            I would like to know if anyone knows how to extract the .bin of bios from the exe published on the lenovo site. I have found several information on the internet but they don't work in my case. I think it's because it's an amd.
                                            I found some dump on the internet but I don't really trust it. I would like to make a clean bis from the official Lenovo file...
                                            12-10-2022, 05:16 AM
