Help nm-d281 rev1.0 LEGION 5-15ARH05H bios
  • hoaca388
    Badcaps
    • Jan 2022
    • 11802
    #41
    Originally posted by RecoMat
    Sorry, doesnt work, CPU regained the VCCCORE and APU warms up now, but still no image.
    power LED changed from white to yellow colour. (feature ?)
    side LED still blinking white.
    Any chance for different bios ?​
    Thanks!
    No. https://www.badcaps.net/forum/troubl...mobile-devices
    • Jari Savolainen
      • Mar 2025
      • 6
      • Finland
      #42
      Lenovo Legion 5 15ARH05H won't start. Power button led is on and of about 10s frequency. Nothing more happens.
      S/N:PF251ELJ MTM: 82B1005VMX
      Tried to start by removing devices one by one but no help. No visible physical damages found in pcb:s. Bios battery voltage is only about 2,4V but I suppose it is not causing problems. I bought CH341A programmer and received it recently. Attached original BIOS dump done with NeoProgrammer V2.2.0.10. I tried also most bios.bins found in this thread without success. I didn't make any DMI or other modifications just uploaded them to bios chip and tried to start pc - wrong?
      "You just need to copy the DMI from your backup to that one using a hex editor,with these offsets 75C000 - 75DFFF"
      Does this mean I just need to replace this section from original to new bios? Or go through this guide
      https://www.badcaps.net/forum/troubl...pt#post1214739
      I also tried to extract bios from lenovo bios update pack downloaded from Lenovo support site. I used this guide
      https://www.badcaps.net/forum/troubl...k-bios?t=80861
      Bios was packed 7zip instead of TDK packer but 7-zip extracted it. But the length of removed section from the beginning was much bigger than in guide if new bios will need to start with same values than original bios. I suppose it need to start. End offset was told to be 7FFFFF so I removed rest. Then just reprobrammed bios with this file. No success :-)
      Could you gurus tell newbie what I'm doing wrong or/and deliver be working bios file. I just don't want to throw laptop to recycle bin yet :-)
      • peste
        • Dec 2016
        • 12859
        • ROMANIA
        #43
        try popst #17..
        • Jari Savolainen
          • Mar 2025
          • 6
          • Finland
          #44
          Thanks. Tried #17 file FSCN28WW.bin. I tried earlier without modifying - not worked. Now modified bin by copying DMI section 75C000 - 75DFFF according post #32. Still not working - powerlight flash 10 s frequency and no more. Any ideas?
          • Luke Anders
            • Oct 2024
            • 10
            I'm looking for a specific BIOS for my Lenovo Legion 15ARH05H. Here's the specs/details:
            Machine: Lenovo Legion 15ARH05H (Type: 82GU)
            Serial Number: PF19KUUH
            Board Model Number: NM-D281 Rev 1.0​
            I seem to have the same problem as Jari Savolainen - every file I've tried so far leads to the laptop turning on, and then shutting down after 10s. I've attached the original file to this post, I was wondering if someone could help with making a file for my specific BIOS?
            Jari Savolainen if you've found a solution for this, please do let me know in the meantime!
            Thanks!
            • hoaca388
              Badcaps
              • Jan 2022
              • 11802
              #46
              Originally posted by Luke Anders
              Thanks!
              Your DMI's corrupted.
              • Jari Savolainen
                • Mar 2025
                • 6
                • Finland
                #47
                I tried both files from post #17 from this thread as they are. And tried both by copying section 75C000 - 75DFFF from my original bios dump to them. No help. Does it mean I have something other wrong than bios? Or I too having DMI corrupted? Attached my latest bios trial. My original is in post #42
                • hoaca388
                  Badcaps
                  • Jan 2022
                  • 11802
                  #48
                  Serial number ?
                  • Jari Savolainen
                    • Mar 2025
                    • 6
                    • Finland
                    #49
                    Originally posted by hoaca388
                    Serial number ?
                    • hoaca388
                      Badcaps
                      • Jan 2022
                      • 11802
                      #50
                      Legion 5-15ARH05H Laptop (Lenovo) - Type 82B1
                      • Jari Savolainen
                        • Mar 2025
                        • 6
                        • Finland
                        #51
                        Thanks :-) . Tried bios #50 but unfortunately not better result. Still slowly blinking power led only wake up sign. Perhaps there is some other problem....
                        • Luke Anders
                          • Oct 2024
                          • 10
                          I've got the same problem, even after flashing the DMI fixed BIOS. I've tried reflowing the SoC, no difference. I believe the problem has to do with the EC Chip, but I'm not sure. Let me know if you come up with anything, perhaps we can discuss this further via DMs too.
                          • Jari Savolainen
                            • Mar 2025
                            • 6
                            • Finland
                            #53
                            Jep I will tell if I'll find anything. Just now no ideas. Nothing look bad in pcb:s but unfortunately I don't have much electronics fixing skills. And new/used mainboards are simply too pricy in ebay/aliexpress...
                            • beast4ever
                              • Feb 2015
                              • 162
                              • egypt
                              #54
                              File Repair
                              Power is on but no data
                              All voltages are present, friends​
                              lenovo legion 5 15arh05h
                              sn-pf2g76ds
                              mtm-82b10051us
                              factory id-jvhfc1
                              • peste
                                • Dec 2016
                                • 12859
                                • ROMANIA
                                #55
                                Originally posted by beast4ever
                                File Repair
                                sn-pf2g76ds
                                mtm-82b10051us
                                factory id-jvhfc1
                                bios extracted from Lenovo website update for BIOS Update for Legion 5-15ARH05H, Legion 5-17ARH05H, Legion 5P-15ARH05H
                                DMI 75C000 - 75DFFF
                                • Fencus
                                  • Oct 2022
                                  • 10
                                  • Hungary
                                  #56
                                  Name: Legion 5-15ARH05H
                                  Board: NM-D281
                                  S/N:PF2LGQAE
                                  I need a 56kB firmware for ITE8176fn,
                                  Accidentally original firmware has been erased so posting dump is not possible.
                                  Thanks for help
                                  • peste
                                    peste commented
                                    Editing a comment
                                    post merged..next time look for a thread with the name and model, motherboard model of the laptop, and post there, if you can't find it, then make a new thread..
                                • fiala985
                                  fiala985
                                  • Jul 2024
                                  • 19
                                  • Slovakia
                                  #57
                                  Good day, I have a laptop problem, black screen, the fans stop slowly at first and then spin quickly, and when I connect the adapter, the laptop turns on, but only to a black screen.
                                  lenovo legion 5 15ARH05H
                                  sn:PF33JDJE
                                  mtm:82B100EACK
                                  ryzen 7
                                  rtx2060
                                    • 20990
                                    sn:PF33JDJE
                                    mtm:82B100EACK
                                    ryzen 7
                                    rtx2060
                                    Post moved to 5 15ARH05H topic.
                                    • peste
                                      • Dec 2016
                                      • 12859
                                      • ROMANIA
                                      #59
                                      sn:PF33JDJE
                                      mtm:82B100EACK
                                      ryzen 7
                                      rtx2060
                                      You have everything you need two posts above.
                                      • fiala985
                                        fiala985
                                        • Jul 2024
                                        • 19
                                        • Slovakia
                                        #60
                                        whitch number
                                        • macabook
                                          by macabook
                                          🧩 Initial Issue
                                          07-24-2025, 02:17 PM
                                        • grimacelord
                                          Lenovo Legion T5-26AMR5 Desktop - Corrupt BIOS
                                          by grimacelord
                                          Hello there.
                                          I am working on a Lenovo Legion T5-26AMR5 desktop that currently has a corrupt BIOS and I have been unsuccessful thus far in trying to fix it myself.
                                          History:
                                          1. This computer came to me initially with an error message that said "BiInitializeLibrary failed 0xc0000001" or "0135 fan error". It would always be one of the two errors. It should be noted that when it produced the fan error, there was no physical problem with the fans. They were all spinning just fine.
                                          I searched for this error online and discovered...
                                          03-15-2023, 03:29 PM
                                        • faousi
                                          BIOS Legion C730
                                          by faousi
                                          Hello frends,
                                          I have an issue with this Computer. It doesnt boot, only fans are spining. I think I have a corrupted BIOS!
                                          So I have read an save BIOS from the chip with a ch341A programer.
                                          On the Lenovo driver site I have downlaoded the BIOS-Update but I cant extract the BIOS-Firmare to program the chip!
                                          Can someone help me!
                                          I have a
                                          Legion C730-19ICO Desktop (Lenovo) - Type 90JH
                                          Serielno. : S1011C9G​
                                          That is the Link to the lenovo BIOS:
                                          https://pcsupport.lenovo.com/de/de/p.../legion-c730-1...
                                          01-13-2025, 09:46 AM
                                        • Vesko356
                                          by Vesko356
                                          08-11-2023, 03:27 AM
                                        • jbonavita
                                          by jbonavita
                                          Some issues
                                          Things I tried
                                          04-29-2025, 09:38 PM
