Help nm-d281 rev1.0 LEGION 5-15ARH05H bios
https://www.badcaps.net/donate -
Lenovo Legion 5 15ARH05H won't start. Power button led is on and of about 10s frequency. Nothing more happens.
S/N:PF251ELJ MTM: 82B1005VMX
Tried to start by removing devices one by one but no help. No visible physical damages found in pcb:s. Bios battery voltage is only about 2,4V but I suppose it is not causing problems. I bought CH341A programmer and received it recently. Attached original BIOS dump done with NeoProgrammer V2.2.0.10. I tried also most bios.bins found in this thread without success. I didn't make any DMI or other modifications just uploaded them to bios chip and tried to start pc - wrong?
"You just need to copy the DMI from your backup to that one using a hex editor,with these offsets 75C000 - 75DFFF"
Does this mean I just need to replace this section from original to new bios? Or go through this guide
https://www.badcaps.net/forum/troubl...pt#post1214739
I also tried to extract bios from lenovo bios update pack downloaded from Lenovo support site. I used this guide
https://www.badcaps.net/forum/troubl...k-bios?t=80861
Bios was packed 7zip instead of TDK packer but 7-zip extracted it. But the length of removed section from the beginning was much bigger than in guide if new bios will need to start with same values than original bios. I suppose it need to start. End offset was told to be 7FFFFF so I removed rest. Then just reprobrammed bios with this file. No success :-)
Could you gurus tell newbie what I'm doing wrong or/and deliver be working bios file. I just don't want to throw laptop to recycle bin yet :-)
Attached FilesComment
Could you gurus tell newbie what I'm doing wrong or/and deliver be working bios file. I just don't want to throw laptop to recycle bin yet :-)Due to a lack of donations, server free space at a critical level, and possible closure of Bios Requests all donations are welcome, click:
Every donation made will go towards server fees and maintenance costs.Comment
Thanks. Tried #17 file FSCN28WW.bin. I tried earlier without modifying - not worked. Now modified bin by copying DMI section 75C000 - 75DFFF according post #32. Still not working - powerlight flash 10 s frequency and no more. Any ideas?Comment
I'm looking for a specific BIOS for my Lenovo Legion 15ARH05H. Here's the specs/details:
Machine: Lenovo Legion 15ARH05H (Type: 82GU)
Serial Number: PF19KUUH
Board Model Number: NM-D281 Rev 1.0
I seem to have the same problem as Jari Savolainen - every file I've tried so far leads to the laptop turning on, and then shutting down after 10s. I've attached the original file to this post, I was wondering if someone could help with making a file for my specific BIOS?
Jari Savolainen if you've found a solution for this, please do let me know in the meantime!
Thanks!Attached FilesComment
Thanks!↵
https://www.badcaps.net/donateComment
I tried both files from post #17 from this thread as they are. And tried both by copying section 75C000 - 75DFFF from my original bios dump to them. No help. Does it mean I have something other wrong than bios? Or I too having DMI corrupted? Attached my latest bios trial. My original is in post #42Attached FilesComment
Legion 5-15ARH05H Laptop (Lenovo) - Type 82B1
I've got the same problem, even after flashing the DMI fixed BIOS. I've tried reflowing the SoC, no difference. I believe the problem has to do with the EC Chip, but I'm not sure. Let me know if you come up with anything, perhaps we can discuss this further via DMs too.Comment
Jep I will tell if I'll find anything. Just now no ideas. Nothing look bad in pcb:s but unfortunately I don't have much electronics fixing skills. And new/used mainboards are simply too pricy in ebay/aliexpress...Comment
File Repair
Power is on but no data
All voltages are present, friends
lenovo legion 5 15arh05h
sn-pf2g76ds
mtm-82b10051us
factory id-jvhfc1Attached FilesComment
DMI 75C000 - 75DFFFAttached FilesDue to a lack of donations, server free space at a critical level, and possible closure of Bios Requests all donations are welcome, click:
Name: Legion 5-15ARH05H
Board: NM-D281
S/N:PF2LGQAE
I need a 56kB firmware for ITE8176fn,
Accidentally original firmware has been erased so posting dump is not possible.
Thanks for help
Good day, I have a laptop problem, black screen, the fans stop slowly at first and then spin quickly, and when I connect the adapter, the laptop turns on, but only to a black screen.
lenovo legion 5 15ARH05H
sn:PF33JDJE
mtm:82B100EACK
ryzen 7
rtx2060Attached FilesComment
You have everything you need two posts above.Due to a lack of donations, server free space at a critical level, and possible closure of Bios Requests all donations are welcome, click:
by macabookHello everyone,
Channel: BIOS Requests ONLY!
07-24-2025, 02:17 PM -
by grimacelordHello there.
History:
I searched for this error online and discovered...-
by faousiHello frends,
I have an issue with this Computer. It doesnt boot, only fans are spining. I think I have a corrupted BIOS!
So I have read an save BIOS from the chip with a ch341A programer.
On the Lenovo driver site I have downlaoded the BIOS-Update but I cant extract the BIOS-Firmare to program the chip!
Can someone help me!
I have a
Legion C730-19ICO Desktop (Lenovo) - Type 90JH
Serielno. : S1011C9G
That is the Link to the lenovo BIOS:
https://pcsupport.lenovo.com/de/de/p.../legion-c730-1...-
by jbonavitaHi, my laptop wont boot at all
Some issues
Things I tried
1- Update / clear ME: Took the non working bios, made a backup, and did this: https://www.badcaps.net/forum/troubl...theory/trouble...-
- Loading...
