Lenovo L340-15IRH won't start
  • hoaca388
    Badcaps
    • Jan 2022
    • 11384
    • Viet Nam
    Re: Lenovo L340-15IRH won't start
    Originally posted by gungor1981tr
    Does it work if we read and write ec from a system that works differently to this device?
    Does he definitely want the ec file according to the serial number
    With this model the EC file is part of the bios file, my guess is it will share this data from the bios chip to the EC chip when you press the power button after flashing the bios. We assume that the EC chip is damaged, the sharing fails and the device cannot be booted.
    • gungor1981tr
      • May 2015
      • 81
      • turkey
      hi
      I managed to repair 2 of the 3 devices in the repair, I will supply materials from China to 1 of them
      The bios and ec files you have provided are working, thank you again.
      • Miim113
        • May 2023
        • 10
        • Romania
        Hi! Can somebody make me good ec file and bios file too for this laptop?
        IdeaPad L340-17IRH Gaming
        Model Name: 81LL
        SN: PF1TB56 MTM: 81LLOOCYGE
        Mfg Date 2020/10/17 Factory ID. JVHFC1
        MO: PE9XB0A17136
          • 20453
          Model Name: 81LL
          MO: PE9XB0A17136
          Post your request in the L340-17IRH thread ---> https://www.badcaps.net/forum/showthread.php?t=106857
          • aditzuthebest
            • Dec 2020
            • 8
            • Romania
            I have a Lenovo L340-15IRH Gaming Laptop (ideapad) - Type 81LK
            Serial Number:PF1SECN0
            Machine Type Model:81LK009ERM
            Black screen after I changed Secure Boot from OFF to ON.
            I suspect a corrupt bios. If I read this bios, can I extract some good data? or all data will be corrupted?
            Should I make a back up before? even if the bios is corrupted?
            Thank you!
            • hoaca388
              Badcaps
              • Jan 2022
              • 11384
              • Viet Nam
              #26
              Thank you!
              Should you make a back up before, even if the bios is corrupted.
              • aditzuthebest
                • Dec 2020
                • 8
                • Romania
                #27
                @hoaca388 another question for you.
                If I find a laptop with model 81LK009ERM in my country and I use Universal BIOS Backup Toolkit 2.0 to back up the bios on that machine and restore on mine...is this ok?
                • hoaca388
                  Badcaps
                  • Jan 2022
                  • 11384
                  • Viet Nam
                  #28
                  I don't know about "Universal BIOS Backup Toolkit 2.0" because if I had to back up I would use a device called a programmer. With software, I don't know if it backs up the entire bios or if it only backs up the "bios region".
                  • Gjackson
                    • Aug 2021
                    • 134
                    • Malta
                    #29
                    Hi! I have a Lenovo L340-15IRH FG541 FG741 NM-C361, bios chip is Winbond 25Q128JVSQ. Laptop charges and powers on, power button and power light are solid white, keyboard turns on for a second or two and goes back off, fan spins and then also turn off. CPU get's warmer and fans turn back on after a while. Absolutely nothing on display and no back-light either. no display on external monitor and Caps Lock does not respond, doesn't seem to post.
                    I tried to reset CMOS but no dice.
                    I've attached the BIOS I attempted to dump with raspberry PI and flashrom. File size looks OK so I think it's intact.
                    Thank you!
                  • Gjackson
                    • Aug 2021
                    • 134
                    • Malta
                    #30
                    Unfortunately the laptop has been salvaged and it seems that the S/N sticker is no longer there, I tried to search for it everywhere but didn't find it anywhere. I would have certainly posted it otherwise, Is it possible to proceed without it?
                      SMDFlea commented
                      Editing a comment
                      Yes it is possible without it.
                  • perudesk
                    • Oct 2023
                    • 3
                    • peru
                    #31
                    Hi, I have the same problem as my colleague "Crabolog".
                    I changed some parameters in the bios and now the laptop turns on but only remains in white screen,
                    Lenovo ideapad L340-15IRH gaming laptop type 81LK
                    serial number: pf27mfk6
                    machine type model : 81LK011KLM
                    Thanks in advance​
                  • perudesk
                    • Oct 2023
                    • 3
                    • peru
                    #32
                    no luck, any other suggestions my friend.
                    • abhorsen
                      Help Disabling Flash Protection Range Registers on Lenovo P360 Tiny BIOS
                      by abhorsen
                      Hey guys,
                      Hope you all are doing well. I come here from Win-Raid because I am having issues disabling Flash Protection Range Registers so I can flash my BIOS from within Windows using Intel's IFW tool/using flashrom within Linux, however I cannot due to the above mentioned error.
                      Here is my thread on Win-Raid detailing the whole process I went through: https://winraid.level1techs.com/t/re...h-gen/95478/27
                      Essentially I managed to boot into Windows while shorting PINs 1+5 of my audio chip to disable the HAP bit...
                      07-06-2023, 10:22 AM
                    • Vesko356
                      by Vesko356
                      08-11-2023, 03:27 AM
                    • HotSaladMan
                      Lenovo ThinkBook 14S Yoga ITL Bad Flash + Need Bios
                      by HotSaladMan
                      *##*#*#*#*#*#Cringe Warning Used Clips for Tl866ii Plus Backups#*#*#*#*#*#
                      Model : Lenovo ThinkBook 14S Yoga ITL
                      S/N : MP28JT19
                      MFG Date : 2022/02/09
                      Factory ID PRC4
                      MO : MPNXB26080FX
                      MTM : 20WE001US
                      MODULE FCC ID : PD9AX201NG
                      IC : 1000M-AX201NG
                      BOARD INFO
                      FLV34 LA-KO51P
                      REV : 1B 2020-08-24
                      Bit of Info
                      Using Tl866ii Plus, it would scan the chip but wouldn't not detect the
                      chip id, so i would always uncheck the id check, so it would bypass the error
                      i did in fact make...
                      11-07-2024, 07:46 AM
                    • Nicola Bianchi
                      Lenovo x1 nano gen 1 -- bricked -- where to flash the bios/fw
                      by Nicola Bianchi
                      Hello!
                      A few days ago I bricked my Lenovo x1 nano gen 1 while updating the bios/fw from linux.
                      No the machine power up, but it stuck in a recovery state and I can not do much.
                      Lenovo X1 Nano Gen 1
                      Type: 20UN - X021US
                      S/N: R9 - 10W2D9
                      I would like to flash a new BIOS/FW on the chip using a CH341a programmer but ... I actually don't know which "chip" on the motherboard to target 🤦‍♂️
                      So here I am to ask for help.
                      I opened the laptop and I found a chip that may be the target, on it I've:
                      Winbond 25R256...
                      01-11-2025, 09:50 AM
                    • 1g0r
                      Lenovo ThinkPad L15 G3 Bios 1 IC conductor track
                      by 1g0r
                      First, the data in brief:
                      Manufacturer: Lenovo
                      Model: ThinkPad L15 G3 21C3-0016GE
                      motherboard: LG4 LT5 ADL RT UMA MB 8L - 448.0PZ26.0011
                      IC Bios 1: MX77L25650F
                      IC Bios 2​: MX25L25673G
                      EC Chip: NPCX997KAABX
                      So far I've been a silent reader, but now I need your help
                      I bought a laptop. The seller said the bios was locked. I was looking for a way to remove this ban.
                      I then got the CH341A and pulled the corresponding files from here https://www.badcaps.net/forum/troubl...evices-and-ele...
                      The laptop was brought in with a BIOS problem and a password. After reading the dump, the information was damaged. I ask for help in the BIOS with a clean ME region. Motherboard 213035-1. Serial number: PW+04e998, Type number: 21c3-0016ge
                      01-18-2025, 02:39 AM
