Lenovo L340-15IRH won't start
  • Crabolog
    • Apr 2022
    • 30
    • Ukraine
    Hi all, I got a laptop Lenovo L340-15IRH FG541 FG741 NM-C361, bios chip is mx25l12872f. Previous owner said that he enabled bios back flash in bios settings and laptop not working now. When you press power button - it will blink continuosly, also blue light on the left sight of laptop blinking, fans will spin and cpu is getting warm, however display is all blank and pc is not responding to keyboad.
    I tried to remove battery and cmos, change ram and flash bios with official dumps from this forum with my ch34a1. The behavior of laptop is changing depeding on firmware, however is still won't boot properly. Could anyone please advice if the issue is in bios and do I also need to flash EC? Attached the original bios dump
  • hoaca388
    Badcaps
    • Jan 2022
    • 12330
    Re: Lenovo L340-15IRH won't start
    L340-15irh
    • Crabolog
      • Apr 2022
      • 30
      • Ukraine
      Sorry but it did not helped, symptoms are the same. Also upon flash verifying it keeps sayin "Chip main memory with the contents are in disagreement."
      • hoaca388
        Badcaps
        • Jan 2022
        • 12330
        so the cause is not bios, this is a completely clean bios.
          • 21914
          Use NeoProgrammer or ASProgrammer software, choose the chip manually,not auto detect.
          https://www.badcaps.net/forum/showpo...33&postcount=6
          https://www.badcaps.net/forum/showpo...6&postcount=10
            • 21914
            Bios + DMI .
            • Crabolog
              • Apr 2022
              • 30
              • Ukraine
              Thanks to everyone, was able to resolve the issue using ASProgrammer and Bios + DMI bin from this thread.
              • droidxxvii
                • Sep 2022
                • 6
                • Belgium
                help, please!
                L340 15IRH NM-C361 rev 1.0 model.
                no post, no display. power led turns on, kbd backlight turns on, then off again. fans turn on, off, then stays on. RAM and processor warms up, but nothing on display. not sure what happened to this, but definitely stopped working after upgrading the m.2 SSD and RAM. removed the new SSD, and replaced the RAM with the original does not resolve the issue.
                was able to retrieve the firmware from BIOS for you to check. please check if it needs cleaning or fixing.
                please help!
                • hoaca388
                  Badcaps
                  • Jan 2022
                  • 12330
                  Originally posted by droidxxvii
                  help, please!
                  please help!
                  L340-15IRH Gaming Laptop (ideapad)
                  • droidxxvii
                    • Sep 2022
                    • 6
                    • Belgium
                    thanks! will try this, and will let you guys know what happened next.
                    keeping my fingers crossed!
                    • droidxxvii
                      • Sep 2022
                      • 6
                      • Belgium
                      so, i erased the chip and reflashed this, and i still have the same issue.
                      it still does not continue posting, power led still blinks continuously, kbd lights up then turns off, fan turns on, off then back on again.
                      what could be causing this?
                      • hoaca388
                        Badcaps
                        • Jan 2022
                        • 12330
                        So you're having a different problem, not a bios error.
                        • droidxxvii
                          • Sep 2022
                          • 6
                          • Belgium
                          i cannot make that assumption as i do not know what could cause the system not to POST. if it wasn't POSTing, shouldn't it have been triggered by a fault in the BIOS?
                          • hoaca388
                            Badcaps
                            • Jan 2022
                            • 12330
                            The file I've posted is fully unzipped from Lenovo's homepage so it can't be faulted.
                            • droidxxvii
                              • Sep 2022
                              • 6
                              • Belgium
                              if it is as you say it is, then what could likely be the cause of this? if it wasn't the BIOS, would there be any other that would cause this issue? i've taken the offending upgrade parts and reinstalled the known good ones so i know they are stable.
                              • gungor1981tr
                                • May 2015
                                • 81
                                • turkey
                                lenovo l340-15ırh factory ıd:JVHFC1
                                The device turns on, but the CPU voltage does not come out.
                                Do you have the possibility to fix the bios file, I would like to try
                                • hoaca388
                                  Badcaps
                                  • Jan 2022
                                  • 12330
                                  Virgin bios with your DMI added
                                  • gungor1981tr
                                    • May 2015
                                    • 81
                                    • turkey
                                    Is there a suitable ec file for this?cpu and gpu voltages are coming out, I just can't get an image, I want to try if you have an ec file that you are sure is working, or if this motherboard has an original ec file
                                    • hoaca388
                                      Badcaps
                                      • Jan 2022
                                      • 12330
                                      Virgin EC file
                                      • gungor1981tr
                                        • May 2015
                                        • 81
                                        • turkey
                                        Does it work if we read and write ec from a system that works differently to this device?
                                        Does he definitely want the ec file according to the serial number
                                        • abhorsen
                                          Help Disabling Flash Protection Range Registers on Lenovo P360 Tiny BIOS
                                          by abhorsen
                                          Hey guys,
                                          Hope you all are doing well. I come here from Win-Raid because I am having issues disabling Flash Protection Range Registers so I can flash my BIOS from within Windows using Intel's IFW tool/using flashrom within Linux, however I cannot due to the above mentioned error.
                                          Here is my thread on Win-Raid detailing the whole process I went through: https://winraid.level1techs.com/t/re...h-gen/95478/27
                                          Essentially I managed to boot into Windows while shorting PINs 1+5 of my audio chip to disable the HAP bit...
                                          07-06-2023, 10:22 AM
                                          by Vesko356
                                          08-11-2023, 03:27 AM
                                        • HotSaladMan
                                          Lenovo ThinkBook 14S Yoga ITL Bad Flash + Need Bios
                                          by HotSaladMan
                                          *##*#*#*#*#*#Cringe Warning Used Clips for Tl866ii Plus Backups#*#*#*#*#*#
                                          Model : Lenovo ThinkBook 14S Yoga ITL
                                          S/N : MP28JT19
                                          MFG Date : 2022/02/09
                                          Factory ID PRC4
                                          MO : MPNXB26080FX
                                          MTM : 20WE001US
                                          MODULE FCC ID : PD9AX201NG
                                          IC : 1000M-AX201NG
                                          BOARD INFO
                                          FLV34 LA-KO51P
                                          REV : 1B 2020-08-24
                                          Bit of Info
                                          Using Tl866ii Plus, it would scan the chip but wouldn't not detect the
                                          chip id, so i would always uncheck the id check, so it would bypass the error
                                          i did in fact make...
                                          11-07-2024, 07:46 AM
                                        • Nicola Bianchi
                                          Lenovo x1 nano gen 1 -- bricked -- where to flash the bios/fw
                                          by Nicola Bianchi
                                          Hello!
                                          A few days ago I bricked my Lenovo x1 nano gen 1 while updating the bios/fw from linux.
                                          No the machine power up, but it stuck in a recovery state and I can not do much.
                                          Lenovo X1 Nano Gen 1
                                          Type: 20UN - X021US
                                          S/N: R9 - 10W2D9
                                          I would like to flash a new BIOS/FW on the chip using a CH341a programmer but ... I actually don't know which "chip" on the motherboard to target 🤦‍♂️
                                          So here I am to ask for help.
                                          I opened the laptop and I found a chip that may be the target, on it I've:
                                          Winbond 25R256...
                                          01-11-2025, 09:50 AM
                                        • to5it0
                                          by to5it0
                                          10-24-2025, 01:35 AM
