Where can i get bios dump for HP 15-cs2005nc ?
  • ktmmotocross
    Boardkiller
    • Feb 2014
    • 3637
    • slovakia
    Guys im in need of bios dump for HP 15-cs2005nc
    did anybody know good source of hp 15- dumps?
    • 22286
    Re: Where can i get bios dump for HP 15-cs2005nc ?
    Download the bios https://ftp.hp.com/pub/softpaq/sp135...0/sp135625.exe .You can get the bios by entering the serial number at the support page,or by entering the laptop model number.If there is no bios shown or a message says no drivers,change the OS to win10 64bit
    Run the exe,it will give you the option to save to a location. If there`s a message about installing a driver cancel it,eventually the popup screen will come up allowing you to save the files. There are 2 bios extracted, 8MB and 16MB, so yours is one of them depending on the backup size. The bios is virgin,it has NO DMI ,its easy to copy the DMI from an insyde bios so make a backup !! ,and post it.
    • ktmmotocross
      Boardkiller
      • Feb 2014
      • 3637
      • slovakia
      i must give credit to HP for easying process of extracting dump from their update.
      I try to repair ME but ME analyzer give me weird messages that it is not in index. it shows ME version 300.
      • hoaca388
        Badcaps
        • Jan 2022
        • 12441
        Your case does not need to clear ME.
          • 22286
          Yeah credit to HP for making it easy to extract the newer bios updates and giving the option to make a recovery key or save a virgin bios.
          You don`t have to clean the ME, just use a virgin bios and copy the DMI over,its quicker,in my opinion.You could just flash the virgin bios,if the DMI isn`t recovered by itself you`ll have to use HP`s shitty BCU and/or wndmifit.
          • ktmmotocross
            Boardkiller
            • Feb 2014
            • 3637
            • slovakia
            sorry guys for bothering u. offcourse i find those shitty intel PCH burned again. 7 of 10 laptops with intel CPU with NO START have burned PCH. i stop counting at maybe 30
            • Ahari
              by Ahari
              I...
              08-13-2025, 06:12 AM
            • mkdj
              by mkdj
              Dear all,
              10-19-2025, 04:41 AM
            • Habble7
              by Habble7
              Suspected Cause:
              Troubleshooting Attempts:
              05-22-2025, 07:28 AM
            • haitham sharabati
              [Request] Clean BIOS dump for HP 15-da2007ne (8XF55EA#ABV) - N4000 - BIOS Lock
              by haitham sharabati
              Hello engineers 😀,
              I’m kindly requesting a clean and unlocked BIOS dump for the following HP laptop, as it’s bricked after flashing SP152727. The system now keeps rebooting, and the original issue was an Administrator / Power-On Password that I can no longer access.😏
              🔧 Device Info:
              - Model: HP 15-da2007ne
              - Product Number: 8XF55EA#ABV
              - Serial Number: CND0338P0D
              - CPU: Intel Celeron N4000
              - EC/BIOS Chip: [Add chip number from the motherboard or BIOS chip]
              💀 Problem:😅
              - Device shows “Administrator Password”...
              08-07-2025, 04:54 AM
            • Citymin
              by Citymin
              S/N : 5RNK9FFT70...
              08-05-2025, 05:12 AM
