FPW50 LA-H324P Rev 1.0
  • ScorpioMan86
    • Dec 2016
    • 94
    • South Africa
    Hi There,
    I would like to request a bios build for LA-H324P, the laptop has 5.3 HP Blink code, WIN+B Bios recovery option doesnt work.
    Ive attached the current bios.
    Laptop Model number is 15-dw00031ni
    Its an i7 8th Gen with an nvidia gpu (not sure of the gpu model number)
    ProID : 7dq62ea#acq
    SN : cnd9301j0p
    Thank you
    • 20792
    Re: FPW50 LA-H324P Rev 1.0
    the serial number is wrong.The model is 15-dw0031ni
    • ScorpioMan86
      • Dec 2016
      • 94
      • South Africa
      Thanks for the response, i mistyped the model number. the serial number should be correct. i have uploaded the picture form the base of the laptop
        • 20792
        Go to the HP support site,enter the serial number or model number to find the drivers and bios.Download the bios update sp135991.exe .Run the exe,select the option to save the bios image to a location you choose. The exe will decrypt and extract seven bios for different models.Two are 8MB so they aren`t for your laptop,that leaves five.
        Download HxD hex editor and open your bios backup with it https://mh-nexus.de/en/downloads.php?product=HxD20, search for the word BID08 to find your bios ID .Open the matching 08***.bin virgin bios with HxD.
        Click back onto your bios backup tab,Select the offsets in the attached picture and copy the DMI (serial,win key,feature byte etc) and paste-insert into the virgin bios using the same offsets and save the file.
        • ScorpioMan86
          • Dec 2016
          • 94
          • South Africa
          Thank you,i followed the instruction and issue still persists. please see my edited bios. I will continue to check what else might be causing this issue
            • 20792
            Your edited bios is AOK .It could be a ram problem,try some other know working ram,try pressing down lighly on the ram slot while booting, and check all the pins.If youve got a KBC EC programmer you can flash that as well .
            • ScorpioMan86
              • Dec 2016
              • 94
              • South Africa
              Thank you, i used the ioprogrammer to backup the ene chip and program it with the file attached, i believe it is fair to assume the issue is not bios/firmware related.
              Laptop behaves the same after programming, change of ram or no ram doesnt change the blink code
              Ive also uploaded the file read from the ENE chip before programming
              • lukasrz
                • 7
                • polska
                Propably CPU problem, I have the same problem. 3/5 blink codes
                I attached BIOS 085F1.bin from HP site + EC from that bios file
                15-dw1014ne
                still 3/5 blink codes
                • kingkong computers
                  • Sep 2018
                  • 188
                  • pakistan
                  100% ok tersted working bios enjoy friends
                    • 20792
                    Thanks for sharing,it may be working but not 100% as the ME firmware is initialised.
                    • Wahaz
                      by Wahaz
                      10-30-2023, 08:42 PM
                    • macabook
                      by macabook
                      🧩 Initial Issue
                      07-24-2025, 02:17 PM
                    • thxd43
                      Lenovo laptop does not turn on, what does this number mean in a BIOS chip?
                      by thxd43
                      Hello, first of all, excuse me, I am using the translator, English is not my native language.
                      I have a Lenovo ideapad 330S - 14IKB laptop.
                      The tablet did not recognize me when I connected it, so I checked the device manager and I realized that there were many with the exclamation mark, so one by one I began to update their drivers until the sign disappeared of admiration, I even updated the BIOS, and the laptop rebooted normally and worked, so far so good, but the tablet still did not recognize me, I read on the internet that it could be due to a...
                      02-23-2023, 08:37 PM
                    • jbonavita
                      by jbonavita
                      Some issues
                      Things I tried
                      04-29-2025, 09:38 PM
                    • zenius
                      by zenius
                      12-08-2024, 06:13 AM
