Lenovo Ideapad 305-15IBD Bios required
  • dicky96
    Sun Seeker
    • Mar 2017
    • 1825
    • Spain
    Hi Guys
    I have a Lenovo Ideapad 305 laptop here
    Long story short - it was brought to me by another alleged repair company. It would not switch on but it would charge the baterry - I fixed this by repairing the flexi ribbon cable from the on/off switch which had a hole in it almost certainly caused by someone putting a case screw through it that was too long
    After fixing that, it powers on for a couple seconds then powers off again. Pressing the start button repeats the process. I get no picture, just the fans spin and I hear the HDD spin up. I tried unfreezing the SIO and resetting the BIOS, no difference. Tried with our without HDD, with PSU/Battery and both no difference. Tried with just one DIMM in either slot, no difference.
    I can see I have 3.3V and 5V but 1.7V, 1.1V, 1.35V come on for a couple seconds then go off again.
    After that I noticed someone has previously desoldered the BIOS and I have no idea what file it has been programmed with
    I read the BIOS contents (attached). The Eprom is a GD25B64BSIG and identifies/reads OK
    Can anyone give me a known good BIOS file or compare the one I posted with a known good one and tell me if it is OK or not?
    Richard
    Follow me on YouTube
    Learn Electronics Repair
    • 21679
    Re: Lenovo Ideapad 305 Bios required
    Originally posted by dicky96
    Hi Guys
    Can you post the serial number thats on the case.
      • 21679
      Hi Guys
      Try this one rich.
      • dicky96
        Sun Seeker
        • Mar 2017
        • 1825
        • Spain
        Serial Number
        • dicky96
          Sun Seeker
          • Mar 2017
          • 1825
          • Spain
          Thanks for the BIOS file, unfortunately it made no difference - the laptop still has the same symptoms. The battery charges OK, when I press the start button it goes green, I hear the fan and HDD spin up, then after a couple of seconds the green LED goes out, the HDD clicks then spins down and the fan stops.
          I know that I have 3.3V and 5V stable but Vram, Vcore and the 1.7V rail are powering up then down again
          I'd like to go a bit further with this one, mainly to see if I am better than he previous tech who looked at this but now I am getting into new territory so I have quite a few questions
          1/ Does anyone have a schematic for this board ZIWB2 / ZIWB3 / ZIWE1 LA-8092P Rev 3.0? Most likely I think I would find that the SIO or EC or whatever they call the damn thing these days is causing the power rails to come on then go off again, but it would be nice to check that.
          2/ The SIO is NPCE288NA0DX. This is a programmable device, I found this video showing how to do it
          https://www.youtube.com/watch?v=cpTD-HwqbMQ
          He is using an IR16 programmer. I had a look but I couldn't find any obvious links to buy one of these. Is this what I need or should I be looking at some other device? I currently just have a TL866CS and a CH341A with 1.8V adapter.
          3/ Where do I find the software file? Here?
          4/ Should I be trying to reprogram the original SIO or buying a new one? I can also see cheap Nuvoton 288 adapter boards on this page for RT809F/RT809H so maybe that answers Question 2
          https://www.aliexpress.com/wholesale...chText=npce288
          5/ Should I be looking at other likely causes before considering reprogramming the SIO? I heard Lenovo SIO are prone to having a hole burnt in the but this one looks OK physically
          Hopefully someone can educate me on the above topics.
          TIA
          Rich
            • 21679
            The bios is ok. The schematic has been posted in the schematics requests section https://www.badcaps.net/forum/showth...light=LA-B092P
            For the programmer youve got a choice, Vertyanov JIG,SVOD3 or 4 ,RT809H ,theres some others too but a lot more expensive than those.
            • ianbak
              • Apr 2023
              • 55
              I'm trying to remove the supervisor password from a Lenovo 305-15IBD (serial number MP13EAJA, board LA-B092P). I've used Autopatcher successfully before, but with this one I get the same error message that some others have reported:
              Using UEFIReplace to inject 2 DXE drivers...
              [1/2] BootOption (GUID e0746c42-d3f9-4f8b-b211-1410957b9ff5)
              c:\temp\bios_original.bin is corrupted or does not contain a valid dump.
              There was an error... Aborting.​
              I don't think that the file I'm using *is* actually corrupted or invalid, because I can load it into my programmer and verify it against the chip on the board.
              Does anyone have any suggestions as to what might be going wrong?
                SMDFlea commented
                Editing a comment
                Post moved to 305-15IBD topic.
            • Maxpower3
              Bad Veteran
              • Feb 2018
              • 1321
              • France
              Autopach not work .
              bootoption and translate no present in bios of ideapad
              • ianbak
                • Apr 2023
                • 55
                I can confirm that the BIOS file from post #3 works fine as an alternative, but it would still be nice to keep the original one and to understand why Auto-Patcher isn't working for me.
                • ianbak
                  • Apr 2023
                  • 55
                  Originally posted by Maxpower3
                  Autopach not work .
                  OK, so it looks like I'll be sticking with the generic BIOS. Which is fine. Does anyone know if this Auto-Patcher issue is likely to be fixed?
                  • Maxpower3
                    Bad Veteran
                    • Feb 2018
                    • 1321
                    • France
                    If you're brave, you can try this! No idea if it will work for testing.
                    otherwise you would have to disable multiple vss keys to see if one of them disables the password. or it may be stored elsewhere in the padding
                    Compare with smdflea bios ​
                      • 21679
                      The Autopatcher doesn`t work with this type of bios (Insyde) , there`s nothing to fix, it`s free and only works on certain models.
                      Bios + DMI attached.
                      • Maxpower3
                        Bad Veteran
                        • Feb 2018
                        • 1321
                        • France
                        Originally posted by SMDFlea
                        The Autopatcher doesn`t work with this type of bios (Insyde) , there`s nothing to fix,.
                        Do you think it could work by invalidating the VSS or with a full FF instead?
                        Click image for larger version  Name:	image.png Views:	0 Size:	78.1 KB ID:	3659653
                        • hardware1
                          • Sep 2021
                          • 2946
                          • N/A
                          Does anyone think the Password could just be "L" letter?
                          all donations are welcome,
                          • Maxpower3
                            Bad Veteran
                            • Feb 2018
                            • 1321
                            • France
                            lol
                            I saw it too but I didn't really believe it.
                            Click image for larger version  Name:	image.png Views:	0 Size:	9.4 KB ID:	3660317
                            I should have trusted the number of characters and the corresponding checksum.
                            In addition, we know it.
                            Finally, I mix everything up by dint of searching.
                            • hardware1
                              • Sep 2021
                              • 2946
                              • N/A
                              lol
                              Yeah, the checksum makes sense. 01+26+D9 = 100h (256)
                              • jendkkd jeje
                                Lenovo IdeaPad 330 15-AST 81D6 BIOS Recovery
                                by jendkkd jeje
                                So a couple of years ago i got a bios update through Lenovo Vantage, so i installed it and bricked my whole BIOS, so i couldn't fix it so i put that ideapad in a box, 3 years later i found that one PC and want to recover it to switch from a 2014 hp laptop to this one.
                                I found a method to recover the BIOS of many lenovo laptops tha consists in pluging in a USB Flash with the BIOS files and power on the laptop with Fn + R keys pressed until fans go loud and start beeping loud, but nothing worked, so i think filename is wrong, i tried naming the bios file as 07WW.BIN, BIOS.BIN, BIOS.fd,...
                                10-11-2024, 03:12 PM
                              • joven016
                                Lenovo Ideapad S145 need working bios HELP!!
                                by joven016
                                Problem is blinking power led only
                                i don't know exactly if it's s145-15igm or s145-14igm
                                have a backup bios file but i dont know the serial.. coz text already erased at the back of the cover
                                Mother board : fs440fs541 nm-c111 rev 1.0 2019-01-08
                                Already tested some of posted bios here
                                S145-14igm - success but invalid serial and not booting on OS
                                S145-15igm - success with serial and some other info in bios but still not booting on OS
                                already tried installing new windows but always booting on bios setup
                                windows installer flash drive detected on...
                                08-21-2025, 10:55 PM
                              • lucaszmn
                                by lucaszmn
                                Problem:
                                Initial Findings:
                                • I concluded that the
                                08-12-2025, 03:01 PM
                              • mximiliandz
                                help bios lenovo ideapad s145-14iil type 81w6
                                by mximiliandz
                                Good morning, gentlemen, I hope you can help me with my laptop, I told you that I saved it about 2 years ago because it wouldn't turn on, now I have a ch341a programmer, I made a backup of the bios, I flashed an original downloaded from lenovo and it started, but it turned off after a few minutes, I entered the bios configuration and the brand, model, serial number, windows serial number, etc. did not appear, I request your help, I did everything I found in the forum but I could not solve it, also now it won't start again, it turns on but the fan does not turn, I will share all the information...
                                06-20-2025, 06:50 AM
                              • Wahaz
                                by Wahaz
                                10-30-2023, 08:42 PM
