I need bios Acer A515-56
Hi, i need bios for Acer A515-56-73EY
SN:NXA1EEB00D04511E193400
SNID:04507324134
ThanksAttached FilesComment
Hello, can you clean the original bios with a new update please, it starts but does not display anything, I tried two bios here but no result
Acer aspire 5
model : a515-56-513v
Sn : NXA16EF001190B63C3400
Motherboard : FH5AT LA-K093P REV 1Attached FilesComment
I tried post 2, without result, the laptp starts but no display, can you redo my original bios pleaseLast edited by madjid911; 10-29-2024, 07:45 AM.Comment
Every donation made will go towards server fees and maintenance costs.Comment
Hi, I need bios for Acer A515-56-54AE
Serial Number : NXA19SA00D134174D63400
ThnaksAttached FilesComment
Attached Files↵
https://www.badcaps.net/donateComment
Hello
Please help me with a working bios for acer laptop FH5AT la-k093p rev 1b
ISSUE: NO DISPLAY/BLANK SCREEN
i tried some files with no success
I could not get the SN plz.
backup attached.Attached FilesComment
Serial Number : NXAASAA002152152FB3400Attached Files↵
I need a good bios file for my Acer Aspire 5 A515-516 i5 11th Gen model.
Serial Number: NXA1FAA00504209DFA3400
It originally had a supervisor password. I used this tool (https://www.biosbug.com/acer-10-digit/) to unlock it but it does not detect SSD. Also, I can't remove supervisor password either enable or disable. So I think it is somehow corrupted.
Attached is the bios dump.Attached FilesComment
Part Number: NX.A1FAA.005
Serial Number : NXA1FAA00504209DFA3400Attached Files↵
Hello Y'all..
I need a BIOS bin file for my laptop. Below are the details of my device, along with the corrupted BIOS bin file that I extracted and backed up (attached):
Model Number: A515-56-53RZ
S/N - NXA18SP00D1511DC5C3400
SNID - 15112194834Attached FilesComment
Hello I need bios for this board code FH5AT LA-K093P REV 1.0 I cannot post the serial number because it is not visible at the back of the laptop it is already damage.
Here is the bios bin it has no Display
Need bios
Acer Aspire 5
A515-56-56w9
N20C5
Board FH5AT LA-K091P
REV 2.0
Orig Bios Attached
Issue Power On then Off few seconds
by EbrahimSiamiHello everyone,
I need help with my Acer Aspire 5920G laptop. Its original GeForce 8600M GT graphics card failed, so I replaced it with an Nvidia GeForce 9600M GT MXM card.
**Problem:** The laptop powers on, but there is no display (black screen) on either the internal LCD or external monitor. This indicates a BIOS compatibility issue with the new graphics card.
**What I have tried so far:**
1. I have my **original stock BIOS dump (1MB .BIN file)** from my laptop, which works and allows the laptop to power on normally (but no display with 9600M...-
Channel: BIOS Requests ONLY!
07-02-2025, 02:31 PM -
by Wg188I have an Acer veriton Z4660G all in one pc,
Model: Z4660G-I5850H1 (VZ4660G_W)
Need bios dump and schematic would save my life !
to make a long story short I bought this all in one used
with a broken lcd, with the objective of making a custom desktop out of it
,it was working perfectly but unfortunately this motherboard default settings does not show post or bios on external screen, I tried everything and every cable/port/screen also ext gpu or internal i also tried to navigate blindly because I could access bios without seeing...-
by ub6ib969Acer Predator PO3-650 BIOS can someone help convert .CAP to .BIN ?
Model Number: PO3-650
Part Number: DG.BK4AA.006
Serial Number : 33400117730
BIOS IC : XM25QH256C
I have uploaded the bios from the acer website and the extracted bios from the board. Any help would be appreciated...-
by zarabotaHello,
I am experiencing the following issue with my laptop. I have an Acer Aspire A717-71G with a motherboard model C5MMH/C7MMH LA-E911P Rev. 1A. Unfortunately, the original board stopped working, so I purchased a replacement. The new board is the same model but a different revision (Rev. 1B). From what I understand, this should not cause compatibility problems.
However, the replacement board came with a BIOS version intended for the Acer Nitro 5 AN515-51, which causes the keyboard to function incorrectly. I attempted to reflash the BIOS chip using a CH341A programmer...-
by verniumENMy laptop model is EX215-23-R7NG
BIOS chip XM25QU128C
Here is my original bin file, as well as how the BIOS chip looks like
My situation is if I press my laptop power on, fan turns on for the first five seconds and turns off, no display (not even acer), but power indicator is on, and the CPU gets warm, even caught one time if powered on for long (before an hour) the fan turns on again, is it only right that I'm approaching via BIOS?
Before I got into this situation, I was just watching movies, and while turned on, pressed the battery reset button and cleaned...-
- Loading...
