Dell Latitude 7400 EDC40 LA-G871P
  • TrustMe
    • Jan 2024
    • 6
    Let me know if I posted this in the wrong thread. I just have a question. What programmer are you using to read the BIOS chip? I have the RT809F and I just bought ch341a v1.7. Neither one of these seem support the chip. The chip I am trying to read is WINBOND 25Q80DVSIG. Am I trying to read the right chip? I am new to programming.
    • hoaca388
      Badcaps
      • Jan 2022
      • 12335
      #102
      WINBOND 25Q80DVSIG is not bios chip.
      • TrustMe
        • Jan 2024
        • 6
        Thank you for letting me know. I do not have any training in electronics. I know to look for a SOP8 chip. I guess I will have to take the motherboard out and look for it on the other side. If I knew that I would have not bought them off eBay. I have two that I plan to give to my grandchildren. Is there a way to know if it is a BIOS chip or not? I did a Google search and it did not tell me one way or another. All it brought up is the data sheet. The only thing I know to look for on that is the voltage.
        • hoaca388
          Badcaps
          • Jan 2022
          • 12335
          #104
          Find the numbers: 64, 128, 256
          • TrustMe
            • Jan 2024
            • 6
            Thank you again. I will look for them.
            • TrustMe
              • Jan 2024
              • 6
              Dell Latitude 7400 EDC40 LA-G871P REV 1.0 (A00)
              Hello, can someone remove the password from the BIOS. Thank you.
            • TrustMe
              • Jan 2024
              • 6
              Please ignore my post above to remove the password from the BIOS file. From my understanding the BIOS file is split between two chips on this laptop. I only have the dump from one of the chips in the post above. I will try to get a dump from the other chip and post again. Thank you.
              The Service Tag and Express Service Code is in the zipped file.
                SMDFlea commented
                Editing a comment
                The service tag must be typed out .
            • allexkom
              • Mar 2019
              • 5
              • Ukraine
              #108
              Hi, can someone help remove the password from BIOS.
              DELL Latitude 7400
              MB LA-G781P rev. 1.0
              Service TAG: CL60533
              Thank you.
              • Markus1741
                • Sep 2020
                • 948
                • N/A
                #109
                Try this unlocked file ....
                • allexkom
                  • Mar 2019
                  • 5
                  • Ukraine
                  #110
                  thanks it worked.
                  • Paul.Junge2020
                    • Feb 2023
                    • 39
                    • Ukraine
                    #111
                    Hello. I bought a Dell 7400 with the problem that there is no image. Can someone help? I tried other bios from those flashed - it doesn't work
                    Here is my dump. thanks for the help​
                    Dell Latitude 7400
                    LA-G871P
                    Service tag - 5JPWP13
                    • hoaca388
                      Badcaps
                      • Jan 2022
                      • 12335
                      #112
                      Dell Latitude 7400
                      LA-G871P
                      Latitude 7400
                      Service Tag: 5JPWP13
                      • MMComputers
                        • May 2020
                        • 17
                        • BIH
                        #113
                        greetings, I'm using this forum for the first time, if there are any mistakes on my part, I'm sorry. I am attaching the bios bin file of Dell Latitude 7400 edc40 la-g871p rev 1.0
                        service tag BH1C063. the problem is that the laptop won't turn on the screen. I tried with other bios from the forum, the screen turned on, but they were mostly locked. If someone can help me, I would be grateful.
                        • Markus1741
                          • Sep 2020
                          • 948
                          • N/A
                          #114
                          It looks like your original BIOS is damaged.
                          Be careful when programming the chip.
                          If I program it with CH341A, be very careful that it is spelled correctly.​
                          • MMComputers
                            • May 2020
                            • 17
                            • BIH
                            #115
                            Thank you very much. My laptop works fine now. Be alive and healthy and may happiness always follow you.
                            • Markus1741
                              • Sep 2020
                              • 948
                              • N/A
                              #116
                              Nice to here that i could help you.
                              • chinh
                                • Mar 2020
                                • 96
                                • viet nam
                                #117
                                have enough power source
                                error:
                                interrupt continuously​
                                DELL Latitude 7400
                                MB LA-G781P rev. 1.0 (A00)
                                Service TAG: 98TYM13
                                Thank you.
                                • hoaca388
                                  Badcaps
                                  • Jan 2022
                                  • 12335
                                  #118
                                  error:
                                  DELL Latitude 7400
                                  Thank you.
                                  Latitude 7400
                                  Service Tag: 98TYM13
                                  • chinh
                                    • Mar 2020
                                    • 96
                                    • viet nam
                                    #119
                                    Latitude 7400
                                    thank hardware error
                                    • ostenx
                                      • Mar 2022
                                      • 15
                                      • algeria
                                      #120
                                      Hi, can anyone help me remove password from this Dump Thank You !
                                      SERVICE TAG : 9JXMP13
                                        DELL Latitude 7400 Notebook 7000 Specification for Upgrade or Repair
                                        This specification for the DELL Latitude 7400 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 7400 boardview and 7400 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL Latitude 7400...
                                        09-06-2024, 08:40 PM
                                        09-06-2024, 12:36 PM
                                        DELL Latitude 7400 Hybrid (2-in-1) 7000 Specification for Upgrade or Repair
                                        This specification for the DELL Latitude 7400 Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 7400 boardview and 7400 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL Latitude...
