Dell Latitude 7400 EDC40 LA-G871P
  • peste
    replied
    Originally posted by sliptend
    hi
    can you help me with dell latitude 7400 ?
    8RY23X2-CF1B
    What's wrong with your laptop? What can we help you with?
    post S/T, full name and model, motherboard model, etc.
    post the contents of the bios chip even if it is corrupted..
  • peste
    commented on 's reply
    post merged...next time look for a thread with the name and model, motherboard model of the laptop, and post there, if you can't find it, then make a new thread..
  • sliptend
    replied
    hi
    I have lock bios password on my PC
    8RY23X2-CF1B
  • mmalagelada
    replied
    Finally got time to do it. SUCCESS!
    1: Protect the PCB with aluminium tape. I had no availability for kapton. Nobody wants nearby capacitors flying away.
    2: hot blower at 360ºCelsus.
    3: Preheat the zone.
    4: Attack the SPI Chip that in my case it ws a 25Q64JVIQ in WSON8 Capsule. 30 seconds was enough.
    5: Clean the chip and attach the WSON to DIL adapter. Read with the CH347 Black edition reader. Software used: NeoProgrammer V2.2.0.10
    6: save the file (8Mb for the 25Q64JV)
    7: execute the Badcaps 8fc8 patcher.
    8: Flash the patched file to the chip
    9: Read and compare to make sure the write was successful.
    10: Cure the PCB with the solder, flux, and wick. Drop some solder paste, I used 170ºC fusion point tin-lead paste.
    11: Preheat, heat, solder..
    12: Clean
    13: reassemble and Start the computer
    14: Wait 2 to 3 minutes. it will start in Factory Mode.
    15: Write the service tag when prompted.
    16: Once restarted press Alt+F to exit factory mode.
    Password was removed. Donation was made.
    replied
    Originally posted by rioda91
    hi everyone, can someone help me with this bios of a Dell E5540? it have bios password... thank you very much!
    Off topic, this thread is for the Latitude 7400 .Find a E5540 topic to post your request in, and include the required service tag. Read the rules - https://www.badcaps.net/forum/troubl...before-posting
  • rioda91
    replied
  • hoaca388
    replied
    Originally posted by Pasco97233
    Hello
    Who can help me remove the BIOS password?
    My service tag is: 4XLGYY2
    Thank you for your help.​
    File's corrupted.
  • Pasco97233
    replied
    Hello
  • mmalagelada
    replied
    I just found a related post in BadCaps. As I see in the photo, it is in the underside ob the PCB.
Name:	LA-G871P UC5 Location.jpg
ID:	3647988 Click image for larger version
ID:	3647989 Click image for larger version
    Its UC5 ??
  • LBTT1121
    replied
    Originally posted by mmalagelada
    Someone can point me to the propper chip to read?
    I can see:
    - UC6 25Q128JVSQ
    - UT5 25Q80CSIG
    - UT2 25Q80DVS1G
    First one is a 16Mbytes flash SPI, and I can see people here having a 32Mb SPI for the Latitude 7400 LA-G871P
    If I read UC6 and try to apply REX98 8FC8 patcher, I receive the error :
    wa nakit-an ang intel signature
    Pinduta bisan unsang key para ma exit...​
    I've read using a clip and also desoldering the chip and reading directly connected to the CH341 Black, and the file is always the same.
    Thanks.
    pass on UT5
  • mmalagelada
    replied
    I can see:
    - UC6 25Q128JVSQ
    - UT5 25Q80CSIG
    - UT2 25Q80DVS1G
    Thanks.
  • docW4rte
    replied
    Thank you for the advice. That makes sense—I’ll look into the possibility of flashing the EC as well, although I don’t have prior experience reading the EC on this MEC model. I hadn’t considered that a version mismatch could be the cause. I’ll give it a try. Thanks again for your help.
  • m4tito
    replied
    Dell is picky and you'll probably need to flash the EC as well. If the EC has a different version than the BIOS, the laptop may sometimes fail to boot.
  • docW4rte
    replied
    Originally posted by lapfix
    Yor serviceTag is different did you flash another bios!!
    AT the sticker is Vpro indicated !!
    Latitude 7400
    Service Tag: 37ZK5Y2
    Version
    1.39.0.
    Try and Give Feedback
    I understand, and thank you for the clarification. It's possible that the BIN is no longer the original one, as I received this notebook from a client who had already taken it to another repair service before. However, the Service Tag is authentic and matches the one on the case.
    After replacing a shorted component in a 1V power rail, I encountered this startup issue. I've tested the file with version 1.39 you shared, but I'm still facing the same problem.
    Do you think this could be solved with a clean ME?
  • lapfix
    replied
    Originally posted by docW4rte
    Re: Dell Latitude 7400 EDC40 LA-G871P
    Good day everyone, could you help me with this BIN? The unit makes one fan revolution and then dies. It displays main voltages but no video at all.
    Latitude 7400
    Version
    1.39.0.
    Try and Give Feedback​
  • docW4rte
    replied
    Good day everyone, could you help me with this BIN? The unit makes one fan revolution and then dies. It displays main voltages but no video at all.​
  • mateusassuncao
    replied
    Originally posted by peste
    try..
    it worked fine
    tank you veryyy much!
  • peste
    replied
    Originally posted by mateusassuncao
    Guys, (laughs) here in Brazil it's already 01:00AM, can anyone help me!?
    try..
  • mateusassuncao
    replied
    DELL Latitude 7400 Notebook 7000 Specification for Upgrade or Repair
    This specification for the DELL Latitude 7400 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 7400 boardview and 7400 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL Latitude 7400...
    09-06-2024, 08:40 PM
    DELL Latitude 7400 Hybrid (2-in-1) 7000 Specification for Upgrade or Repair
    This specification for the DELL Latitude 7400 Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 7400 boardview and 7400 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL Latitude...
    09-06-2024, 12:36 PM
