Lenovo fa495 nm-c131 rev 1.0
  • santoslao
    • Apr 2017
    • 132
    • BZ
    Re: Lenovo fa495 nm-c131 rev 1.0
    Originally posted by snar
    Hi everyone can someone please help me remove the bios password. its locked from the company. thanks in advance. the laptop model is lenovo t495. board model FA495 NM-C131 Rev 1.0. i attached the old bios with password.
    try and feebdback..
    STEP 1: Flash and replace current BIOS with the generated patch file
    STEP 2: Boot the machine
    STEP 3: Press ENTER/F1/etc. to enter BIOS settings
    STEP 4: Enter any character when asked for Supervisor Password
    STEP 5: Press enter when it shows Hardware ID
    STEP 6: Press space bar 2x when asked
    STEP 7: Turn off machine
    STEP 8: Restore original BIOS
    STEP 9: Reset BIOS settings to factory default
    • snar
      • Feb 2018
      • 74
      • philippines
      sir SANTOSLAO thank you. i tried your bios patched. i follow all the procedures after i turn off the latop and power on. when i press F1 to enter bios. its stays blank it has backlight but no image. i cannot continue to bios. is there any solutions for this one sir?thank in advance .
      • santoslao
        • Apr 2017
        • 132
        • BZ
        Explain better! Is there a white screen after passing the patch or your file? Do you remove the chip or are you using an adapter directly on the board? Is the watch battery out of the board?
        see 2 more files generated from your original bios but I confess that the file I sent you before is universal and I always use it in any other equipment like that.
        • snar
          • Feb 2018
          • 74
          • philippines
          Sir santoslao, thank you very much. i try your new bios t495 fa495 nm c131 w password_PATCHED_CLEAN. the password is removed and the laptop is now working. once again thank you sir. god bless you more.
          • deansanity16
            • Jun 2022
            • 14
            • philippines
            can someone help me with my bin file, this is company laptop i cant reformat because i need to sign in to company. im stuck with the picture below.
            board code: FA495 NM C131 REV. 1.0
            SERIAL:PF-2HVSBF
            type number: 20NK-S66T02
          • hyditech
            • Jun 2012
            • 272
            • nigeria
            #26
            Good evening everyone, please help me to patch lenovo T495 AMD RYZEN
            S/N PF-134363
            • gsoft
              • Jul 2023
              • 38
              • Italy
              #27
              Hi santoslao
              I read in some posts you helped people to unlock bios for t495. I have a t495 and also a ch431a, please can you help me to remove supervisor password.
              Thank you so much​
            • gsoft
              • Jul 2023
              • 38
              • Italy
              #28
              Deleted for follow the correct request
              • jithinkn
                • Jul 2018
                • 40
                • UAE
                #29
                No display ,
                Please rebuild
                Ryzen pro
                S/N : PF1BGRXG
                Type: 20NKS0T11C
                Model : T 495
                M/B : NM-C 131, REV ; 1.00
                • hoaca388
                  Badcaps
                  • Jan 2022
                  • 12354
                  #30
                  Originally posted by jithinkn
                  No display ,
                  Please rebuild
                  Ryzen pro
                  S/N : PF1BGRXG
                  Type: 20NKS0T11C
                  Model : T 495
                  vvv
                  • waqarali
                    • Nov 2023
                    • 49
                    • United Arab emirates
                    #31
                    lenovo t495
                    SN: PF-20MK86
                    MB:FA495-NM-C131
                    Please remove password
                    thanks
                    • ibrahim03
                      • Oct 2015
                      • 143
                      • egypt
                      #32
                      Device:Laptop
                      Brand:Lenovo (ThinkPad) AMD RYZEN
                      Model: Thinkpad T495 (Type 20NJ, 20NK)
                      Board number: NM-C131 REV. 1.0
                      Request: patch bios to remove admin password
                      • kalilinux25
                        • Mar 2018
                        • 2089
                        • ZAMBOANGA SIBUGAY
                        #33
                        Originally posted by ibrahim03
                        Device:Laptop
                        please provide the SERIAL NUMBER
                        • ibrahim03
                          • Oct 2015
                          • 143
                          • egypt
                          #34
                          done fixed
                          • kalilinux25
                            • Mar 2018
                            • 2089
                            • ZAMBOANGA SIBUGAY
                            #35
                            done fixed
                            try this bin its a fresh bios , no serial number check if it will auto fill
                            • ajaysharma
                              • Jun 2018
                              • 8
                              • india
                              #36
                              Hi Sir, Please help me remove the password , i attached T459, NM-C131 REV 1 lock bin ... thanks in advance
                              • peste
                                • 13691
                                • ROMANIA
                                #37
                                post S/N
                                • nav0singh
                                  • Nov 2019
                                  • india
                                  #38
                                  nm-c131 bios password
                                • testinglaptops
                                  • Oct 2022
                                  • 85
                                  • United Arab Emirates
                                  #39
                                  try
                                  Thank You , post #11 Patch working 100% . Password Removed. I tested on 10 T495 laptops
                                  • kelogz
                                    • Apr 2025
                                    • india
                                    #40
                                    No display ,
                                    Please rebuild BIOS PASSWORD REMOVE
                                    Ryzen
                                    S/N : 1X5DKR
                                    Type: 20NK-S29V00
                                    Model : T 495
                                    M/B : FA 495 NM-C 131, REV ; 1.00
                                    • to5it0
                                      by to5it0
                                      10-24-2025, 01:35 AM
                                    • Forest79
                                      by Forest79
                                      07-23-2023, 07:39 AM
                                    • survivalbloke
                                      Unable to extract bios file from Lenovo bios exectuable
                                      by survivalbloke
                                      I'm trying to extract a flashable bios file(ch341a) from the lenovo bios executable download. I have tried the instructions from this site https://starkeblog.com/lenovo/uefi/2...pdate-exe.html, which are not working. According to those instructions, after issuing the command
                                      Code:
                                      "innoextract 7wcn38ww.exe"
                                      it should create an \app folder, inside which, I should find a newly created "7wcn38ww.exe" file. I should then be able to extract that using 7zip and find my .FD file.
                                      The trouble I'm having is that I'm not getting the newly...
                                      06-12-2024, 07:55 AM
                                    • coasterghost
                                      Lenovo T14 Gen 2 Type 20XK Model 20XK0069US Odd Charging Issues
                                      by coasterghost
                                      For Badcaps Readers, Please note that I am hopefully going to present this same message to Lenovo to see if they have any insight to the matter as well and figured to share the entirety here for clarification. The System is out of warranty as it is but does have the option to have it extended.
                                      Model Information: T14 Gen 2 (Type 20XK, 20XL) Laptop (ThinkPad) - Type 20XK - Model 20XK0069US
                                      Board: T14 Gen 2 (Type 20XK, 20XL) - Type 20XK.
                                      System Hardware:
                                      Processor: AMD Ryzen 7 PRO 5850U
                                      Memory: 1x 16GB DDR4 3200 (Soldered on Board); 1x Crucial 32GB DDR4...
                                      09-08-2025, 10:46 PM
                                    • survivalbloke
                                      Unable to extract Lenovo BIOS file from installer
                                      by survivalbloke
                                      I'm working on a Lenovo LOQ 15APH8, Serial# MP2L9MAV. I want to flash a new BIOS onto it, but I'm also trying to learn this process for my own enrichment and professional development.
                                      I was watching some tutorials, copying the serial info blocks from the old bios to a new bios. Before that though, they use innoextract on the Lenovo .exe. I downloaded Innoextract v1.9 but it tells me my .exe is not a supported inno setup installer(see screenshot). So if I unpack this using 7zip, I do get a .ROM file, but according to my tutorials, I'm looking for a .FD file.
                                      How can...
                                      07-16-2025, 03:21 PM
