HP BIOS unlock tool
  • bod0007
    replied
    SMDFlea I do not have CH programmer yet for flashing. The backup I have is previous BIOS done by the official updater.
    Will that work? I have read a about the patch you mentioned. Just want to know if you talking about programmer backup or the normal update backup.
    commented on 's reply
    Try to reset your bios backup to factory settings then reflash the bios, and at 1st boot press F10 and RESET BIOS to factory defaults https://www.badcaps.net/forum/troubl...y-bios-patcher
  • bod0007
    replied
    <BIOSCONFIG Version="" Computername="BOD" Date="2025/06/17" Time="18:52:38" UTC="1">
    SPM: Not Provisioned.
    BEAM mode: Disabled.
    <SETTING changeStatus="fail" name="Manufacturing Programming Mode" reason="Access denied" returnCode="6">
    <OLDVALUE><![CDATA[Lock]]></OLDVALUE>
    <NEWVALUE><![CDATA[Unlock]]></NEWVALUE>
    </SETTING>
    <ERROR msg="An operation failed" />
    <ERROR msg="BCU return value" real="13" translated="13" />
    </BIOSCONFIG>
    SMDFlea I have tried to unlock mpm with that method serverally. shows this error
    Use BCU 4.0 (Bios Config Utility) under cmd.
    biosconfigutility /get:1.txt and in 1.txt modify Manufacturing Programming Mode from *Lock to *Unlock (erase *from Lock and put it to Unock) save file as 2.txt and use biosconfigutility /set:2.txt then restart.
  • bod0007
    replied
    Originally posted by peste View Post
    The bios chip must be unsoldered from the board before writing or reading..
    do not use the clip, you may have errors..if you do not have anything to unsolder it with,
    solder wires between the programmer and the bios chip..
    do I need to unlock BIOS to correct the DMI details.
    Please point me to tutorials for dumping BIOS and restoring or flashing the unlocked BIOS file received from BIOS request.
  • bod0007
    replied
    Hi all, I have a HP EliteBook 855 G7 with 845 G7 BIOS details(i.e SN and Product number) I tried to correct it with BCD utilities but not work. I read I need to unlock MPM. Kindly help
  • peste
    replied
  • erwer
    replied
    I am trying to remove the BIOS lock of an HP elitebook 840-G8.
    I have all tool & software (CH341A, RCUnlocker, AS-Programmer) available and working.
    Since I don't have a suitable soldering station, I try to avoid soldering out the bios chip.
    With a Wson-chip adapter, I read out the correct bios chip W25Q128JV on the motherboard, which is tricky.
    Nevertheless I managed till now to read out the bios chip 8 times. Unfortinally all bios binaries are different, because of the of different CRC32 on the AS-Programmer. That is not suppriesing me.
    Curiously the Unlocker tool works for all the different binaries.
    The question is how to find the correct binary? Maybe the security mechanism use only a small memory part of the bios chip and the rest of the memory doesn't matter.
    Has somebody experience with the topic, respectively any suggestions?
    Br
  • peste
    replied
    Originally posted by GreenTeam View Post
    I've managed to do it but when I restart my laptop its still asking for a password when im go into f10.
    Is there a video that shows how to do this from start to finish?
    i'm sure I'm doing something wrong?
    any help would be appricated.
    post S/N, full name and model, motherboard model, product number,etc.
    post the contents of the bios chip even if it is corrupted..
    Don't post pictures unless asked.
  • GreenTeam
    replied
  • peste
    replied
    Originally posted by Muditha Folini View Post
    hello everyone, i am new here and could you please tell me how can i install hp unlocker tool? after i try to install it says FATAL ERROR DETECTED FAILED TO EXECUTE SCRIPT HPUNLOCKER
    you don't have to install the program...read post #1.
  • Muditha Folini
    replied
  • qwerty4512
    replied
    Originally posted by shiyab View Post
    hi try
    after on display ,bios notice 'systemnaufacture' ,can't open bios blackscreen ? have another solution?
  • shiyab
    replied
    Originally posted by qwerty4512 View Post
    anyone please helpme can open for this bios password unlock (
    type :HP x360 11 G7 ee
    s/n:5CG1191N28
    please helpme sirr )) thanksss
    hi try
  • qwerty4512
    replied
    s/n:5CG1191N28
  • alihomee
    replied
    Originally posted by RethoricalCheese View Post
    First check this site to see if your HP is supported for the great tool Mazzif has made.
    http://mazzifsoftware.blogspot.com/p...os-unlock.html
    If your model is newer and not in that list, you need to dump your bios, remove password from dump and reprogram bios with modified dump.
    For that you need an SPI programmer like CH341A or Raspberry Pi with Flashrom or any other similar programmer. A soic8 clip is also useful so there wouldn't be a need to unsolder bios IC.
    When you have your dump, just drag and drop your file on my HPUnlocker tool and it will create a new file. It will add "_unlocked" to the name of your locked file.
    Just program the new file on your bios IC.
    This unlocker should work on all Elite, EliteBook, ProBook and maybe some other series HP laptops.
    For those of you who need to unlock large amounts of laptops, I recommend adding a registry entry:
    Code:
    Computer\HKEY_CLASSES_ROOT\*\shell\HPUnlocker\command
    Then modify that string adding
    Code:
    "C:\*location-of-exe*\HPUnlocker.exe" "%1"
    This way you just need to right click your locked file and select HPUnlocker.
    If there are any issues, please do let me know so I can improve this tool.
    All Elitebooks, Probooks and zbooks which are up to ninth generation which should be up to year 2018, like 840 G5, are supported. Newer models are not supported (yet atleast).
    No Pavilions or other trash is supported
    NEW multitool and unlocker added .
    Unlocking
    HP - ProBook, EliteBook, ZBook (including 32MB models)
    Chromebooks from all various manufacturers
    Apple - everything older than T2
    More to come...
    RCUnlocker https://www.badcaps.net/forum/showthread.php?t=98539
    i am looking to use this softwere with win 11 ...any update or suggations as win 10 is good for this softwere but win 11 id not working propely
  • b4rdock
    replied
    SMDFlea sir ,here i can ask for help with my strange case password HP Zbook Firefly 14 G9 ?
  • Andreasbest
    replied
    Originally posted by danito View Post
    try
    Hello!
    Finally this BIOS worked, thank you very much.
    P.S: It would be wise to keep in mind that under certain circumstances both utilities fail to edit the locked BIOS. Unfortunately i don't know the exact circumstances but i'll keep the locked BIOS stored in case someone wants to run some research.
    Thank you again!
  • danito
    replied
    Originally posted by Andreasbest View Post
    Can someone please remove the password from the above bios manually?
    Thank you in advance.
    try
  • Andreasbest
    replied
