HP BIOS unlock tool
  • soniqu
    • Dec 2021
    • Україна
    #1561
    Originally posted by shiyab
    hi try flash ec file
    thanks
    • bhatt
      • Dec 2015
      • 92
      • pakistan
      #1562
      anyone have hp latest pwd removing tool. share with me,
      advace thanks
      • sadhan2704
        • Feb 2025
        • India
        #1563
        14r 113tu MPM How to Unlock
        • peste
          • 12374
          • ROMANIA
          #1564
          post S/N, full name and model, motherboard model, product number,post the contents of the bios chip even if it is corrupted..etc.
          ​What's the problem with the laptop??
          • llek100
            • Aug 2024
            • 11
            • Slovakia
            #1565
            Hello, I recently got two locked HP EliteBook 840 G5, I've seen that this tool supports them - however I am not able to get it working.
            When I dragged the locked dump onto the exe, I get a supposedly unlocked file, but when I flash it, the BIOS is still locked.
            I am flashing/reading from the 32MB chip.
            Here are my locked dumps.
            • lapfix
              • Mar 2020
              • 2636
              • my workshop
              #1566
              For File 1 :
              First boot loaded bios factory defaults, save and exit and then at the next boot reseted security settings .
              In the first boot go to bios menu and disable security options (Default).
              You must fill your DMI manually.
              For File 2 : try to read again twice and compare them , i think the one you uploaded is not GOOD
              • rolodog
                • Dec 2024
                • 6
                #1567
                HI, Can you please remove the password for this bios, I have run it through the tool which says it removed the password but upon reinstalling the chip i still have a password on the the bios,
                HP Elite x2 1013 G3
              • rolodog
                • Dec 2024
                • 6
                #1568
                Thanks for getting back to me, i have read the site and done all i can to get this to work but am still needing help. The serial number is 5CD9133M6X
                • llek100
                  • Aug 2024
                  • 11
                  • Slovakia
                  #1569
                  Originally posted by lapfix
                  For File 1 :
                  Thank you for the response, however, after flashing the 1 unlocked.bin to the corresponding laptop, it just showed "The BIOS has recovered it's identity data from the embedded controller due to data mismatch." and it is still locked.
                    • 20477
                    Try. Just flash the 16MB chip .Reset default settings at first boot, disable secrutiy options.
                    • rolodog
                      • Dec 2024
                      • 6
                      #1571
                      Hi, Thanks for the help so far. I have flashed just the 16mb as you suggested but upon starting the laptop it still has a Admin Password for the bios. Any more suggestions??
                        • 20477
                        flash this one.
                        • rolodog
                          • Dec 2024
                          • 6
                          #1573
                          Hi, Thanks for all your help. I have now managed to get past the admin password follow your instructions. However the tablet is now very slow to start will only boot after several tries .could this be down to the bios or perhaps a poor solder joint on the chip I put back in maybe.
                            • 20477
                            Try this bios
                            • Experimenter
                              • Feb 2025
                              Hello, have been working on a 650 G2 Bios locked Admin Password and think I finally got it but wish to be positive. All worked as described in the forum with some trials. Used a EZP 2019+ programmer but had to modify it for the ground pin as stated. Also, could not get the programmer to identify the Winbond W25Q128FVSO with the power supply connected and laptop off. Once it was unplugged the programmer identified it as Winbond W25Q128 and I took 4 reads and verified all, they were all the same then used HxD to compare all files were the same. Please have a look at the attached files and let me know if they seem OK to write.
                            • Experimenter
                              • Feb 2025
                              Sorry very new at this. Laptop information on the outside of cover. It is an HP 650 G2 i5-6300u, Serial- 5CG6434SRR.
                              Inside bottom cover stickers- SN:BCAPF100CTG9Y0ACEP, Build ID; 15WWCIDT601, Feature Bite: 3Q3X476J6S6Z6b7H7M7Q7W7saBaEapaqauawbhdUdpdq.5f
                              Bios Information: System Bios- N76 Ver 01.04 07/22/2016, System Board ID-80FD, System Board CT Number- PFKCT00WB47430
                              I am using a clip I don't see MB serial number visible.
                              Thanks in Advance
                              • rolodog
                                • Dec 2024
                                • 6
                                #1577
                                Hi, Sorry to keep asking questions but I still have an issue. The bios that you sent have worked perfectly and I no longer have a admin password. The issue now is I can not load windows onto the machine. The original that was on and also via trying a new install both fail. Any suggestions.
                                once again thanks for all your help
                                • hat07
                                  • Jan 2021
                                  • 9
                                  • tunisia
                                  #1578
                                  doesn't work hp elitebook 840
                                • rolodog
                                  • Dec 2024
                                  • 6
                                  #1579
                                  Any further help on post 1577 please. Thanks
                                  • Andreasbest
                                    • Aug 2014
                                    • 1142
                                    • Hellas ( Greece )
                                    #1580
                                    Ok now i'm into a very weird situation.
                                    I backed up the bios from a 650 G1, i drag into this tool and RCUnlocker too, the result is that both the original dump and the patched (from both tools) are identical!
                                    I compare them with HxD
                                    How is this even possible? I feel super dumb right now.
                                    • salim5566
                                      loking for bio tool that hve all feature like ps5 bios and laptop bios unlock and repair 1 tool can do all please good tool?
                                      by salim5566
                                      Hi guys i like to buy tool that automatic unlock bios or find password also can flash and repair bios ic, looking for good tool have good software that have 1 click and unlock bios any recommend good tool? looking for sony ps5 and and laptop bios
                                      06-26-2025, 03:25 PM
                                    • zenius
                                      by zenius
                                      12-08-2024, 06:13 AM
                                    • Forest79
                                      by Forest79
                                      07-23-2023, 07:39 AM
                                    • Kesavan
                                      HP 245 G10 BIOS UNLOCK FILE REQUEST
                                      by Kesavan
                                      Hello, Need unlock BIOS password for HP 245 G10 MOBO PART NO: HOKIE22-MV-VGT-6050A3461901-MB-A01
                                      Attached my backup file
                                      SERIAL NO: 5CG4300CNT...
                                      06-16-2025, 06:42 AM
                                    • Sebastian Codrean
                                      BIOS file for ASUS F542UN laptop
                                      by Sebastian Codrean
                                      Hello to all of you! I need help with a BIOS file.
                                      The BIOS chip is fried on my Asus F542UN laptop, and I bought a new chip that needs programming. I have a CH341a programmer but I need a .bin BIOS file. On Asus support page the firmware has another extension, .310 and from reading on this forum I understand that that file is not complete BIOS.
                                      So, in short I need the "complete" BIOS .bin file to flash on the new chip. Another issue is that on back of the case the label says F542UN but on the sticker on the motherboard it's X542UN.
                                      02-20-2025, 10:25 AM
