HP BIOS unlock tool
Re: HP BIOS unlock tool
OK
and sorry for my noob question but I have an other hp 840 g1 which i unlock without any problems. can I upload its bios to the previous laptop (same model)
there is a risk to brick the bios ?Comment
Oh, my bad. I mixed up me state in recovery mode and the not committed error. Bios update might get rid of me state issue. Not committed needs biosconfigutility.
Ofni, don't use same file on another machine. You would need to clean ME region and set up VSS region according to your serial number etc.Comment
THANK YOU everybody in this forum and thread, specially to @RetoricalCheese, @Vesko356 and @SMDFlea.
I did it !
This afernoon, I give a try to the three other softwares (NeoProgrammer,Colibri or ASProgrammer), basically same results of no detecting the chip ( this time with the clip, as I removed the wire solder yesterday), but surprisingly, in one of the attemtps adjusting the clip. Voilà. Colibri programmer detected.
Then with Colibri, I read the chip, verify it ( no discrepancies), saved it to bin file and drag&dropped it to RCUnlocker with a successful message. Afterthat, I erased the chip, loaded the unlocked bin file and wrote to chip. The surprise was when I verified what was written, Colibri told me about 7687 discrepancies ... did process again, with same results. 7687 discrepancies.
Well, I said...let's turn it on and see what happens.
The company logo was removed ( blanked,... no logo), but the bios admin password was still there, and computer could turn it on.
Logo removed was a little progress, but a progress.
So I decided to repeat process, what encourage me was that I could do it with the clip.
Then after 5-10 minutes of tuning and adjusting the clip, I manage to detect the clip.
This time I decided to use CH341 v1.34, just because the menus were more familiar to me. Same process: read, verify, save bin file, drag&drop it to RCUnlocker, erase chip, load unlocked bin, write and verify file.
This time.... zero discrepancies.
And voilà !
Full access to BIOS, standard HP logo when booting and reset security bios to defaults in the first bios access.
Perfect.
I think that I had problems with the Colibri program in the erase phase, as it completed in just 1-2 seconds, while this phase took around one minute when I repeated it with CH341A programmer.
My summary:
-. Main problem was the clip connections. Don't discourage if it takes you some extra time.
-. RCUnlocker program is badass !
-. People in this forum is fantastic to newcomers, even if we ask the basics.
-.Add HP Elitebook 745 G2 to the list of tested models for the tool.
@RetoricalCheese ... you should have a beer flying to Tartu. Enjoy it !Comment
Hello, just wanted to give a big thanks to RethoricalCheese the HPUnlocker tool.
I had a HP 705 mini G4 with dual MX25L12873F and a BIOS passwords.
With a Raspberry Pi, flashrom and the HPUnlocker I was able to get it removed.Comment
need to unlock my hp840 g5Attached FilesComment
For you
Attached Files↵
https://www.badcaps.net/donateComment
hi can you help me to remove the password on the bios of the hp 455 g7 ?Attached FilesComment
Become a Badcaps supporter
Thanks to all supporters.
----------------------------------------------------------------------------------------------------------------------------------------------------------Doctrina est fructus dulcis, radicis amarae..Comment
i try but he don't boot. the laptop reinstall the locked bios...i try to flash the bios with a ch341a pro but it say the files is to big for the bios chip .so .. i try with asprogrammer and say same thing...i got the uuid sn sn mother board system board etc if it can help you ...i don't understand how you put these informations in the bios*.bin with a hex program ??Comment
Did you desolder the chip for reading / writing or use a clip? Desolder better.. Which chip did you do, just 1 or both? I'm looking at a DA0X9MMB8F0 board with a Winbond 25Q128JVSQ 16M chip nearest the "BIOS" legend on the board (primary BIOS?), but also with a GigaDevice 25B127DSIG 16M chip very close
https://pdf1.alldatasheet.com/datash...5B127DSIG.html
https://pdf1.alldatasheet.com/datash...Q128JVSIQ.html
If these are the chips you have, they are 3V chips, Is your ch341a working 5V or 3V? There is a mod for ch341a if not,
https://www.chucknemeth.com/usb-devi.../3v-ch341a-modLast edited by dualtrace; 01-11-2022, 11:37 AM.Comment
it's a winbond w25q1128BV chip. i use a clip with cha141a and i did it on the chip winbond cause it write bios just in down of it. for the 3v or 5v i don't know i will test it to know ! thank for your advicesComment
Not quite sure what the difference is between B and J versions of the chip but they're both 16M 3V. Maybe B is just newer.
https://pdf1.alldatasheet.com/datash...W25Q128BV.html
Maybe if you did both chips, even if it did try to reload from the second chip, you'd have de-passworded that one too..
I'm no expert. Probably best to wait until someone more knowledgeable than I comes along & suggests what's safe to do.
Clips do seem to have a reputation for causing problems though. I'm waiting to do my own best machine until my solderings practised enough.
Some manuals for your machine in case they help:
https://support.hp.com/us-en/product...780046/manualsComment
help me to remove bios password
HP ELITEBOOK 830 G7
INVENTEC CAMELLIA
6050A3136201Attached FilesComment
Attached Files----------------------------------------------------------------------------------------------------------------------------------------------------------
by salim5566Hi guys i like to buy tool that automatic unlock bios or find password also can flash and repair bios ic, looking for good tool have good software that have 1 click and unlock bios any recommend good tool? looking for sony ps5 and and laptop bios
Thanks-
Channel: BIOS Requests ONLY!
by CityminHi all,
S/N : 5RNK9FFT70...-
by m1ch43lzmHi everyone
There's also an extra OTP Secu.R...-
by Forest79Hello,
However, the chip (a Macronix MX25L25673GMI-08G) has a size of 32 MB, and the BIOS file from the Lenovo website (extracted with UEFITool) has a little more than 16 MB. Thus, the software my acquaintance used (SiberiaProg v1.45, with a CH341A Programmer)...-
- Loading...
