HP BIOS unlock tool
  • RethoricalCheese
    • Mar 2013
    • 1519
    • Estonia
    #361
    Re: HP BIOS unlock tool
    I would buy a better programmer first
    But on that model, I think you need to program both chips. Just in case don't use the tool, just upload bin files and somebody will unlock manually.
    • onelook
      • May 2020
      • 27
      Originally posted by peste
      try..
      Is it possible that the file is corrupt. I couldn't write the file to Chip. I have tried 3 times and on 2 different BIOS Chips. With the file i uploaded i can write successfully.
      I am using flashrom to write
      Do you have another bin file or could you please check the file?
      Thanks for your help. I appreciate it.
      • Mozezz
        • Jun 2020
        • 17
        first thanks for reply! what do you mean with program both Chips? Do you think it doesnt work with the ch341a programmer? Sorry im beginner with this kind of technic and which programmer I should buy? My plan was not to desolder the Chip because I didnt have do that before!
        • peste
          • 13357
          • ROMANIA
          #364
          the bios is ok, there is no problem there, remove the bios chip from the motherboard before writing the chip, if you use the clip you may have errors ... if you have nothing to remove it, fix the clip on the chip.
          • onelook
            • May 2020
            • 27
            so i could have written to the chip and have verified the writting process (dump again and compare the hash).
            But still haven't luck. Laptop start with no output and the fan runs after 5 seconds full speed.
            Do you have any ideal?
            • peste
              • 13357
              • ROMANIA
              #366
              hi,
              try..
              • onelook
                • May 2020
                • 27
                try..
                hmm still the same problem.
                Power LED lights on and fan runs after 10 -15 seconds full speed...
                • onelook
                  • May 2020
                  • 27
                  Maybe something wrong with the 2nd BIOS? Even if i flash back the original dump, it has the same problem (Power LED lights on and fan runs after 10s full speed)
                  • ste222
                    • Apr 2020
                    • uk
                    #369
                    the bios youve copied dosent look good read my previous post about copying at least 3 times and verifying original then making sure you have a good erase dont trust what program says check the chip is blank else anything you copy wont work ive done a G5 and had no problems
                    • onelook
                      • May 2020
                      • 27
                      yes of cource i did. I always read again 2 times and check the Hash for sure. What i am wondering is, that the version, which i have dumped before i updated the BIOS doesn't work too. And i am 100% sure that this dump is good. Here is the dump you can check.
                      So what makes me concern is there is something new with the latest BIOS Version of HP, which prevents the boot. hmm i dont know
                      • ste222
                        • Apr 2020
                        • uk
                        #371
                        Hi onelook did a compare of your bios to the one i had and there are many differances mine was a 830 g5 dont remember the bios version but mine worked ok heres a copy of my working unlocked bios file
                        • sympa78
                          • Aug 2020
                          • France
                          #372
                          The HPunlocker v1.rar was unable to be used on my computer. The rar file don't seemed to be a compress one. Unable to open it.
                          • peste
                            • 13357
                            • ROMANIA
                            #373
                            update winrar or use 7zip
                            • saiih
                              • Aug 2020
                              • 7
                              • Ireland
                              #374
                              Hi all
                              can someone please help me get this HP Unlocker tool?
                              link from the beginning of this thread is not working, for me at least
                              i have HPBR by mazzif from before anyway ... but the only files inside are USB image tool and HPBR-Win32(with HP Bios Unlock.exe inside)
                              if i drag a bin file on HP Bios Unlock.exe im not getting an unlocked bin file ...
                              this HP Bios Unlock.exe is same with HP-Unlocker that you are talking about in this forum? thanks
                              • saiih
                                • Aug 2020
                                • 7
                                • Ireland
                                #375
                                sorry, my bad ...
                                was 2 o'clock in the morning when i was trying all of this ... i noticed now that HpUnlocker tool is made by RethoricalCheese
                                got it, thanks for this tool RethoricalCheese
                                • saiih
                                  • Aug 2020
                                  • 7
                                  • Ireland
                                  #376
                                  worked for me
                                  Hp 840 G2
                                  bios chip winbond 25q128fvsq
                                  battery, bios battery and power supply disconnected
                                  Programmer: CH314 miniprogrammer black
                                  ASprogrammer 1.4.1 version
                                  read bios, verify, use unlocker tool, erase bios chip, write unlocked version
                                  connect power supply, after 3 restarts it worked
                                  Thanks again to Rethorical Cheese and to this forum
                                  • keczuk
                                    • 84
                                    • WWW
                                    #377
                                    any update for G6 (there password is in 16MB chip).
                                    • dewako
                                      • Sep 2019
                                      • uae
                                      #378
                                      My hp 820 g3 have 2 passwords. Administrator and power on password by using your tool i removed administrator password but power on password still exists what should i do! Please help..
                                      • RethoricalCheese
                                        • Mar 2013
                                        • 1519
                                        • Estonia
                                        #379
                                        Upload your dump.
                                        • ranlyranly
                                          • May 2020
                                          • usa
                                          #380
                                          Not able to open the unlocker. Keep getting an error.
                                          • salim5566
                                            loking for bio tool that hve all feature like ps5 bios and laptop bios unlock and repair 1 tool can do all please good tool?
                                            by salim5566
                                            Hi guys i like to buy tool that automatic unlock bios or find password also can flash and repair bios ic, looking for good tool have good software that have 1 click and unlock bios any recommend good tool? looking for sony ps5 and and laptop bios
                                            06-26-2025, 03:25 PM
                                          • zenius
                                            by zenius
                                            12-08-2024, 06:13 AM
                                          • Citymin
                                            by Citymin
                                            S/N : 5RNK9FFT70...
                                            08-05-2025, 05:12 AM
                                          • m1ch43lzm
                                            by m1ch43lzm
                                            Hi everyone
                                            09-06-2025, 05:47 PM
                                          • Forest79
                                            by Forest79
                                            07-23-2023, 07:39 AM
