Hp 1040 g4
  • waelot
    • Dec 2020
    • 8
    • tunisia
    Hp 1040 g4
    Hello freind who can build this bios with no display
    Motherboard: da0y0umbad0
    S/N# 5CD82249N4
  • hoaca388
    Badcaps
    • Jan 2022
    • 12269
    Re: Hp 1040 g4
    Originally posted by waelot
    hello freind who can build this bios with no display
    motherboard: Da0y0umbad0
    s/n# 5cd82249n4
    ​https://www.badcaps.net/donate
    • waelot
      • Dec 2020
      • 8
      • tunisia
      Re: Hp 1040 g4
      Originally posted by hoaca388
      The same caps light blinks 5 times but no display
      • hoaca388
        Badcaps
        • Jan 2022
        • 12269
        Re: Hp 1040 g4
        Try again :
        • waelot
          • Dec 2020
          • 8
          • tunisia
          Re: Hp 1040 g4
          Try again :
          I tried but without successful
          Anyway thanks for your help
          • pixi75
            • Dec 2019
            • 82
            • Serbia
            Hp Elitebook 1040 g4 bios file
            Motherboard turn on but no screen,fan spin to max.
            Someone can clean Me bios file or put some dump file.
            DA0Y0UMBAD0 REV D
            • qayyum786
              • Aug 2018
              • 1959
              • INDIA
              Re: Hp Elitebook 1040 g4 bios file
              Originally posted by pixi75
              motherboard turn on but no screen,fan spin to max.
              Someone can clean me bios file or put some dump file.
              da0y0umbad0 rev d
              flash 16mb only
              • pixi75
                • Dec 2019
                • 82
                • Serbia
                Re: Hp 1040 g4
                • Kodza
                  • Jun 2016
                  • 191
                  • South Africa
                  Re: Hp 1040 g4
                  Hi I got HP Elitebook 1040 G4 motherboard DA0Y0UMBAD0 Rev D which is coming on and the fan is spinning fast but not displaying help me clean me, Thanks
                  • hardware1
                    • Sep 2021
                    • 2946
                    • N/A
                    Re: Hp 1040 g4
                    Here's your New BIOS, try it and let me know.
                    Program that file to your 16MB Chip and put your 8MB Chip Back.
                    Serial Number: 5CD8325W12.
                    all donations are welcome,
                    • Kodza
                      • Jun 2016
                      • 191
                      • South Africa
                      Re: Hp 1040 g4
                      Thank you Hardware1 I have tried your file but it's not displaying, the laptop turns on and it's giving 1 blink on caps lock and then after a few seconds the fan will start running max speed without display
                      • hardware1
                        • Sep 2021
                        • 2946
                        • N/A
                        Re: Hp 1040 g4
                        As far as I know, 1 Blink for HP is pointing to a CPU Issue. If you have tried more than 1 BIOS and it's the same, you can go and Post in the Hardware Forum, maybe they can help you there.
                        https://www.badcaps.net/forum/forumdisplay.php?f=23
                        • robante15
                          • Nov 2020
                          • 62
                          • El Salvador
                          Hello, I have in my hands an HP EliteBook 1040 G4 (DA0Y0UMBAD0 REV: D) that makes no attempt to turn on, display an image or anything.
                          I took out the BIOS and flashed one that I found in a forum for this model, and on the first boot it did give a power LED, it showed an image, but I got two HP screens, the first one said:
                          "Final step of BIOS update is in progress.", after that it turned off and turned on again this time showing the following warning "The BIOS has recovered its identity data from the Embedded Controller due to data mismatch."
                          When I hit OK, what it did was restart, it went on a black screen, and then it didn't turn on. And it returned to the same thing, that it does not show any sign of life.
                          I clarify that I only flashed the 16MB chip, there is an 8MB one right next to it, I have not touched that one at the moment.
                          If someone could help me with a BIOS for this model I would greatly appreciate it, I also attach the original BIOS of this device​
                            SMDFlea commented
                            Editing a comment
                            The serial number must be posted with every bios request
                            You MUST:
                            • Provide the full machine model number, serial number (or Service tag, SNID) and the board model number (see https://www.badcaps.net/forum/showthread.php?t=88758 ) ,The serial number, make, full model number, motherboard model and revision (except QR codes) must be written/typed at your request as per the rules. Not as a picture, part of the file name and so on.
                        • corona100
                          • Mar 2020
                          • 153
                          • U.S.A
                          8MB + 16MB Tested flash both bios
                          • robante15
                            • Nov 2020
                            • 62
                            • El Salvador
                            I get the same problem as other users. The Caps Lock LED flashes 5 times and after a few seconds the fan starts spinning at maximum speed
                            • trunguntilyou
                              • Aug 2022
                              • 355
                              • Vietnam
                              please help me!,, the machine won't turn on with enough power
                              s/n:5CD8033H9Z
                              • rex98
                                • Feb 2023
                                • 1289
                                • Mandaue CEBU, Philippines
                                s/n:5CD8033H9Z
                                try.
                                • trunguntilyou
                                  • Aug 2022
                                  • 355
                                  • Vietnam
                                  Originally posted by rex98
                                  try.
                                  Currently unable to try and report, sincerely apologize
                                  • motanya
                                    • Nov 2021
                                    • 161
                                    • Kenya
                                    hp elitebook 1040 g4 has no display, was forced to shutdown during update
                                    S/N# 5CD7433D6Y
                                    • wilber1412
                                      • Jan 2019
                                      • peru
                                      Hi guys, I need help with my BIOS.
                                      I can't configure secure boot because it asks for unlock pin​
                                      Attach my original BIN
                                      Thank, bless
                                      HP EliteBook Folio 1040 G3 Notebook 1040 Specification for Upgrade or Repair
                                      This specification for the HP EliteBook Folio 1040 G3 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 1040 G3 boardview and 1040 G3 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for HP...
                                      09-06-2024, 06:06 AM
                                      HP EliteBook Folio 1040 G2 Notebook 1040 Specification for Upgrade or Repair
                                      This specification for the HP EliteBook Folio 1040 G2 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 1040 G2 boardview and 1040 G2 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for HP...
                                      09-06-2024, 05:30 AM
                                    • glovecaps
                                      Asus ROG Strix Scar G533qm with a G733qm Motherboard, can I modify the Bios to accept G533 Bios
                                      by glovecaps
                                      I have a Asus ROG Strix Scar 15 (G533QM) that had a dead motherboard (Graphics card dead) and after trying to fix the motherboard with no success, I bit the bullet on a sale for a new motherboard. I ordered a motherboard for the 15 inch model which is the one that I have, and when the motherboard arrived it wasn't for a little while that I saw it was from the 17 inch model.
                                      My question is, can I update the Bios on this G733 motherboard to a G533 Bios.
                                      The reason for wanting to do this is that the keyboard isn't working as it should, and I think this...
                                      11-25-2024, 04:23 PM
                                    • Docus
                                      Legion Y540 17irh motherboard issue ( need help to know how to diagnose my motherboard)
                                      by Docus
                                      Hi everyone πŸ˜€,
                                      I'm here today to ask for help with repairing the motherboard of a Lenovo Legion Y540 17IRH.
                                      To give you some context, I'm passionate about computer repair so much so that I've invested in a lot of tools and started practicing on dead and old hardware. I've been learning how to solder and desolder components, mostly focusing on phone repairs.
                                      Recently, I bought a broken Lenovo Legion Y540 17IRH for just €150, and there are two main reasons why I made this purchase:
                                      1. I already own the exact same model, but its plastic chassis is badly damaged.
                                      06-10-2025, 04:24 PM
