Lenovo T490s bios password request.
  • arence20
    replied
    Originally posted by arence20
    any one can help bios password or supervisor password
    T490s FT491/FX390 NM-B891 rev;2.0
    S/N ;PC18XVK8
    MODEL; 20NYS6KV00
    THANK YOU
    help
  • arence20
    replied
    S/N ;PC18XVK8
    MODEL; 20NYS6KV00
    THANK YOU
  • techrecycle
    replied
    please help me to remove bios password
    sr:PC-1B48JH
  • unleadedblues
    replied
    Request to clean bios password.
    Lenovo T490S
    SN: MJ-0DEGNB
    Type: 20NX-S2UC00
    Motherboard: FT491/FX390 NM-B891 Rev: 2.0
    Dump of (U2101) - MXIC MX 25L25673G
    Tried Lenovo AutoPatcher but laptop just beeps on boot with patched file
  • OntarioTL
    replied
    Originally posted by volinakis
    AA553F -enabled
    AA553C -disabled
    remove CMOS battery, that's why you weren't able to disable Absolute from bios setup. At 1st boot enter bios setup Security-Absolute (somemtime Computrace) and permanently disable it.
    Thanks Volinakis, I will follow your recommendations. I'm sure it will work like the last one.
    This was where I am puzzled as I looked at the original BIOS file through HxD and what I though was the enable and disable for AbtState, but it already has AA553C instead of AA5533F. I thought this was for another option that was mixed in. Under UEFItools it showed it as it should so this is why I was getting a headache.
    Alright, after examining your screenshot, I gave HxD a shot again. With the search I should have used the "search all" feature which gave me 4 results. One of them had the AA5533F. This was probably one I should have tended to when I attempted to do the fix myself. Like they say, it's hard to teach an old dog new tricks.
    Thanks again!
  • volinakis
    replied
    Originally posted by OntarioTL
    Ok, so I attempted to modify another BIOS with the same AbtState enabled. I thought it would be easy to modify though UEFItools but of course the option is greyed out. The older UEFItools I've used can extract but it's not as simple as the HEX view from the newer version as it isolates that particular item. I've looked at other posts about how to change this option AA553F to AA553C , but I have noticed from Hexviewer that this option is not always located near the AbtState or it may not be for AbtState at all. My head hurts between this and a E15 Bios issue.
    I hate asking for help, but I would greatly appreciate a fix for one more laptop. I want to learn, and I spent a good 3 hours last night at home in front of the screen to find how to go about this. Every time it seems easy on a post, my results are different. I know it will be a slap in the forehead once it clicks on how to do and it's probably pretty easy, but for now I wave the white flag.
    Lenovo T490s
    TN: 20NY-S3L500
    SN: MJ-0CJQ2L
    Board : FT491/FX390 NM-B891
    AA553F -enabled
    AA553C -disabled
  • OntarioTL
    replied
    Lenovo T490s
    TN: 20NY-S3L500
    SN: MJ-0CJQ2L
  • OntarioTL
    replied
    there are too many AbtState invalidated. It should have worked since AbtState is invalidated, i did tens of lenovos in that way. Did you enter in bios setup to Security-Absolute and disable it? Remove CMOS battery if you forget to do it and press power button for 30s, start laptop without battery.
    I take it back. It worked. For some reason this morning I managed to have it boot without the Absolute activated before I was about to try your suggestions. Strange, but happy nontheless. Thanks for the help!
    Now to make my day brighter, I hope to get this E15 working after a botched BIOS update.
  • volinakis
    replied
    Unfortunately it did not work. I do see what I did on my attempt that screwed me up however. I noticed the difference between yours and hoaca that there were 2 changes where yours was only one. Would that be the issue?
  • OntarioTL
    replied
    try
  • volinakis
    replied
    I was experimenting on a T490s that has no password but absolute activated. I want to disable it of course. I thought it would be in the MEC1663 but I was wrong as I know with password reset with the MEC trick works to gets rid of Absolute or Computrace on other models. Secondly examining the last request original BIOS and fix applied by volinakis and hoaca388. I decided to compare my BIOS image and make the two adjustments I see in the fix with no luck. Am I missing something here? Or is the value different per activation and deactivation?
    My untouched BIOS image before I made changes.
    Lenovo T490s
    Sn: MJ-0CJQ2R
    TN: 20NY-S3L500
    try
  • OntarioTL
    replied
    Lenovo T490s
    Sn: MJ-0CJQ2R
    TN: 20NY-S3L500
  • krogs214
    replied
    Originally posted by hoaca388
    Try
    thank you also
  • krogs214
    replied
    try
    hi its working
    thank you so much
  • hoaca388
    replied
    Originally posted by krogs214
    Hi anyone can help i have Absolute Enable but No Bios Password
    anyone can disable it?
    Lenovo T490s
    Sn: PC1F1WZK
    Board Number: FT491 FX390 NM B891 FEV 2.0
    thanks in advance
    Try
  • volinakis
    replied
    Lenovo T490s
    Sn: PC1F1WZK
    thanks in advance
    try
  • krogs214
    replied
    Lenovo T490s
    Sn: PC1F1WZK
    thanks in advance
  • Vesko356
    commented on 's reply
    Do NOT post in all caps please.
    You MUST:
  • Rashid334
    replied
    HELLO EVERY ONE CAN HELP ME REMOVE SUPERVISOR PASSWOR
  • piszpunta
    replied
    Re: Lenovo T490s bios password request.
    I need working mec dump
  • zenius
    by zenius
    12-08-2024, 06:13 AM
  • RMDUiFT
    Should I buy a Lenovo Thinkpad E495 with bios password?
    by RMDUiFT
    Good day. I apologize if I posted this in the wrong topic. I saw somebody selling a Thinkpad E495 with a Ryzen 3500U CPU near me. In the pictures the laptop is running windows 10. I contacted the seller and asked a few questions about upgradability and if it has a bios password on it. He confirmed it has a bios password. I searched through the forum, I found a guide regarding removing the bios password using the autopatcher, I also found a thread with the e495 where people requested help with unlocking the bios password.
    I have a few questions:
    • If I would buy this laptop and have
    08-25-2024, 09:00 AM
  • Wahaz
    by Wahaz
    10-30-2023, 08:42 PM
  • lucaszmn
    by lucaszmn
    Problem:
    Initial Findings:
    • I concluded that the
    08-12-2025, 03:01 PM
  • baaligoga
    Help needed in unlocking BIOS Supervisor password - Lenovo X1 Yoga 5th Gen
    by baaligoga
    Good day, everyone!
    I'm encountering an issue with my Lenovo X1 Yoga 5th Gen laptop related to the BIOS supervisor password. I'm seeking assistance and guidance from the knowledgeable members of this community in resolving this problem.
    I am no expert and cannot perform soldering or unsoldering of the chip from the board. Therefore, I attempted to use an EZP 2023 programmer with a clip to extract the BIOS bin file without removing the BIOS chip from the motherboard. The BIOS chip has the following letters imprinted on it: "Winbond 25Q80DVNIG 2026". I used the...
    05-20-2023, 09:48 AM
