Hs461 hs561 hs761 nm-d521 rev 2.0 bios plz
  • leno2021
    replied
    Yes!!
    That's it, my laptop works again!!
    The procedure described in this post works.
    Lenovo really has a problem with its bios updates...maybe it's also their business...
    Thanks for your help !!​
  • hopkok
    replied
    Hi bros, I change ofset 1000 to 2FFF in this file, but DMI is still the same, bad offset?
  • leno2021
    replied
    Good morning,
    I erase the chip with asprogrammer and the ch351a.
    After modifying bios 52 I send it in the chip with the ch341a 1.8v
    I know that for many this seems obvious but is my procedure for modifying my bios the right one?
    THANKS.​
  • leno2021
    replied
    Oops !!!
    it's a capture that I made after modifying the files, in reality I put 2FFF!!
    Bravo for the observation!!​
    commented on 's reply
    In your picture there are 4 F`s in the end-offset , it should be 3 . 1000 to 2FFF
  • leno2021
    replied
    Good morning,
    With hxD, I opened the glcn52 file provided on this site and my oldbios file.
    I then copied the range from 1000 to 2FFF from my oldbios which I copied and pasted by overwriting on the glcn52 file.
    I haven't written about the chip yet, but is this the right procedure?
    THANKS​ Click image for larger version
  • peste
    replied
    Originally posted by leno2021
    Hello and thank you for the reply,
    I will follow your recommendations and come back to you if I have any doubts, otherwise,
    Can someone tell me if my bios is not damaged?
    Off topic, is it possible
    to make a donation but without a subscription? THANKS.​
    For donations, ask one of the moderators, SMDFlea, Vesko356... some changes have been made, they could clarify for you......
  • leno2021
    replied
  • peste
    replied
    Good morning,
    following an update of the GLCN55WW bios (under Windows 11) of my ideapad 3 15alc6, my laptop became unusable.
    I have a Ch341a with 1.8v adapter.
    I can read the chip and erase it well.
    Laptop:
    ideapad 3 15alc6
    PF9XB
    MTM 82 KU002
    05/27/2021
    s/n PF2X**FJ
    Bios Chip: Winbond 74M12JWSIQ
    Attached is the bios saved after flashing crash.
    Is my "oldbios" corrupted?
    Thanks for your help.​
    you have everything you need at post #52..
  • leno2021
    replied
    Good morning,
    Laptop:
    ideapad 3 15alc6
    PF9XB
    MTM 82 KU002
    05/27/2021
    s/n PF2X**FJ
  • Vesko356
    Latest version of NeoProgrammer is V2.2.0.10
    It's been discussed many times - choose the bios programmer according to your budget, please use the forum search before asking questions - you're starting to get off topic..
  • pcG44k
    replied
    Is CH341a (w/volt selector) with another adapter ok? Any better?
    NeoProgrammer v2.2.0 should be used to dump bios from the chip?
  • Vesko356
    https://www.badcaps.net/forum/troubl...88#post3233588
  • pcG44k
    replied
    Tnx for the reply, Vesko! πŸ˜‰
    I didn't make any bios backups previously, so is there a way to extract bios backup/info or something else can be done?
  • Vesko356
    Use the bios at post #14, transfer the DMI block from your dump or if you can't do it yourself, upload your bios backup and someone will do it for you.
  • pcG44k
    replied
    Re: Hs461 hs561 hs761 nm-d521 rev 2.0 bios plz
    Here's your New bios file, it's a virgin bios from Lenovo with your DMI so it should works fine.
    Next time find your device thread or create your own.
    Hi everyone! πŸ˜€
    Myself like most folks here a problem with BIOS as well (black screen, laptop boots up, LED's work), so I would like to ask if the Bios file from the post #12 would help my model?
    I have tried all known fixes with unplugging CMOS, ram, battery drains... which ultimately led me here, considering the wide issue with this model.
    Lenovo V 15 G2 ALC
    S/N: PF3ASAJ1
    MO: PF9XB1C25040
    MTM: 82KD0041YA
    Old (default) bios: GLCN41WW
    Installed bios: GLCN55WW
    Is DMI info unique for each model or do I have to do anything (make a bios dump from GLCN41WW or something) to have my version working?
    Can I have a working bios with v55WW or a virgin v51WW is enough?
    I'm new to the modding world, but I learn quickly, so I'm sorry if I haven't managed to follow something more thoroughly πŸ˜‰
    Please read the rules.Post the laptop serial number and your bios backup.
  • HEON04
    replied
    Lenovo ideapad 3 15ALC6 LCFC HS461&HS561&HS761 NM-D521 Rev 3.0 plssss
  • aminemsaken
    replied
    Originally posted by aminemsaken
    thx but power led blinking and fan turn processor work but black screen with my old bios and with new bios πŸ˜₯
    thnx very much, i will verify motherbord,maybe another problem, thank you sir.
  • Vesko356
    It's a virgin bios for your model with DMI transferred, you won't find any better bios, if it's not working your problem is not bios related, or you didn't program the chip as it should.
  • Marc97
    lenovo hs461&hs561&hs761 nm-d251 rev:2.0 bios bin file
    by Marc97
    hello there,, anyone who can help us to have bios for LENOVO
    HS461 HS561 HS761 NM-D251 REV 2.0
    I have downloaded bios from lenovo website,,, but it is .CAP FILE after my bios creator extract it...
    i attached the .CAP may you can help us also to trim it.....
    12-03-2022, 05:51 PM
  • macabook
    πŸ› οΈ MSI GP75 Leopard MS-17E71 – No Display, Deep BIOS/EC Troubleshooting
    by macabook
    🧩 Initial Issue
    07-24-2025, 02:17 PM
  • Vesko356
    by Vesko356
    08-11-2023, 03:27 AM
  • jbonavita
    by jbonavita
    Some issues
    Things I tried
    04-29-2025, 09:38 PM
  • zenius
    by zenius
    12-08-2024, 06:13 AM
