Yes!!
That's it, my laptop works again!!
The procedure described in this post works.
Lenovo really has a problem with its bios updates...maybe it's also their business...
Thanks for your help !!β
Hs461 hs561 hs761 nm-d521 rev 2.0 bios plz
Hi bros, I change ofset 1000 to 2FFF in this file, but DMI is still the same, bad offset?Leave a comment:
Good morning,
I erase the chip with asprogrammer and the ch351a.
After modifying bios 52 I send it in the chip with the ch341a 1.8v
I know that for many this seems obvious but is my procedure for modifying my bios the right one?
THANKS.Leave a comment:
Oops !!!
it's a capture that I made after modifying the files, in reality I put 2FFF!!
Bravo for the observation!!βLeave a comment:
For donations, ask one of the moderators, SMDFlea, Vesko356... some changes have been made, they could clarify for you......Leave a comment:
Hello and thank you for the reply,
I will follow your recommendations and come back to you if I have any doubts, otherwise,
Can someone tell me if my bios is not damaged?
Off topic, is it possible
to make a donation but without a subscription? THANKS.Leave a comment:
Good morning,
following an update of the GLCN55WW bios (under Windows 11) of my ideapad 3 15alc6, my laptop became unusable.
I have a Ch341a with 1.8v adapter.
I can read the chip and erase it well.
Laptop:
ideapad 3 15alc6
PF9XB
MTM 82 KU002
05/27/2021
s/n PF2X**FJ
Bios Chip: Winbond 74M12JWSIQ
Attached is the bios saved after flashing crash.
Is my "oldbios" corrupted?
Thanks for your help.βLeave a comment:
Good morning,
Laptop:
ideapad 3 15alc6
PF9XB
MTM 82 KU002
05/27/2021
s/n PF2X**FJ
Thanks for your help.Attached FilesLast edited by leno2021; 03-14-2024, 04:43 PM.Leave a comment:
Is CH341a (w/volt selector) with another adapter ok? Any better?
NeoProgrammer v2.2.0 should be used to dump bios from the chip?Leave a comment:
Tnx for the reply, Vesko! π
I didn't make any bios backups previously, so is there a way to extract bios backup/info or something else can be done?Leave a comment:
Hi everyone! π
Myself like most folks here a problem with BIOS as well (black screen, laptop boots up, LED's work), so I would like to ask if the Bios file from the post #12 would help my model?
I have tried all known fixes with unplugging CMOS, ram, battery drains... which ultimately led me here, considering the wide issue with this model.
Lenovo V 15 G2 ALC
S/N: PF3ASAJ1
MO: PF9XB1C25040
MTM: 82KD0041YA
Old (default) bios: GLCN41WW
Installed bios: GLCN55WW
Is DMI info unique for each model or do I have to do anything (make a bios dump from GLCN41WW or something) to have my version working?
Can I have a working bios with v55WW or a virgin v51WW is enough?
I'm new to the modding world, but I learn quickly, so I'm sorry if I haven't managed to follow something more thoroughly πLeave a comment:
Please read the rules.Post the laptop serial number and your bios backup.
https://www.badcaps.net/forum/troubl...before-posting -
Lenovo ideapad 3 15ALC6 LCFC HS461&HS561&HS761 NM-D521 Rev 3.0 plssssLeave a comment:
It's a virgin bios for your model with DMI transferred, you won't find any better bios, if it's not working your problem is not bios related, or you didn't program the chip as it should.
by Marc97hello there,, anyone who can help us to have bios for LENOVO
HS461 HS561 HS761 NM-D251 REV 2.0
I have downloaded bios from lenovo website,,, but it is .CAP FILE after my bios creator extract it...
i attached the .CAP may you can help us also to trim it.....-
Channel: BIOS Requests ONLY!
by macabookHello everyone,
Iβm currently working on a dead MSI GP75 Leopard (MS-17E71) motherboard (i7 CPU, NVIDIA GPU) with a no display/no backlight issue initially. After extensive investigation, Iβm at a critical stage involving EC firmware, BIOS/ME region interaction, and possible deep corruption. I'm seeking advanced insight from anyone with experience in EC/BIOS sync issues or PCH-level behavior. Hereβs a full breakdown:
π§© Initial Issue- Board powers on (fans spin, keyboard lights up and can be adjusted, caps lock led lights), but no display or backlight
- External display (HDMI) shows
07-24-2025, 02:17 PM -
by Vesko356First of all thanks to all of our members who have posted previously all methods posted here.
Operating system and OS version.If...-
by jbonavitaHi, my laptop wont boot at all
Some issues
Things I tried
1- Update / clear ME: Took the non working bios, made a backup, and did this: https://www.badcaps.net/forum/troubl...theory/trouble...-
- Loading...
