Hs461 hs561 hs761 nm-d521 rev 2.0 bios plz
  • John889988
    replied
    Re: Hs461 hs561 hs761 nm-d521 rev 2.0 bios plz
    Originally posted by hoaca388
    sssssss
    I would like to say thank you very much, uncle
  • hoaca388
    replied
    Originally posted by john889988
    thanks, it works on my laptop, but the s/n is different
    sssssss
  • John889988
    replied
    Try the BIOS from Post #31.If it works fine we can transfer your DMI.
  • John889988
    replied
    OK, I'll try
  • hardware1
    replied
    Originally posted by John889988
    I updated the bios of the ideapad3 15alc6, but my laptop went blank, the latest update was glcn52ww, I tried post 4, but failed, please help to turn it back on
    s/n : PF2Z76VV
  • John889988
    replied
    s/n : PF2Z76VV
  • hoaca388
    replied
    Originally posted by Raraneda
    Thanks for your answer, finally read the Bios with As Programmer, my notebook is a 14ALC6, but does not deliver video signal.
    Atached my Bios and information
    S/N: PC24FRC3
    IdeaPad 3-14ALC6 Laptop - Type 82KT DOWNLOADED FROM LENOVO HOME PAGE
  • Raraneda
    replied
    Originally posted by peste
    try a similar chip from the data list and see if you can read the bios chip, then post the content here..
    S/N: PC24FRC3
  • peste
    replied
    Great post, one question:
    I have a Ideapad 3 14ALC6 with motherboard Hs461 hs561 hs761 nm-d521 rev 2.0, and i will CH341a programmer, but chipset GD25LR128DSIG not found in data list (ASProgrammer or Neoprogrammer). Is there a way for me to add the chip for programmer with CH341a 1.8v adapter?
    The closest chip I could find listed was the GD25LQ128C 1.8v
    https://www.mouser.cl/ProductDetail/...RWx_mC8RhKqzrw
  • Raraneda
    replied
  • migreen06
    replied
    The flash worked fine but my issue still exists. I have a motherboard virus that apparently can"t be removed. Flashing the spi was the last resort. I guess I will be throwing away a laptop I bought less than 3 years ago.
  • migreen06
    replied
    Re: lenovo ideapad 3 15ACL6 bios request
    Originally posted by Vesko356
    Reading all related posts is not enough, you must try to understand all the information in that posts otherwise you just read some text which obviously is not very fruitful as you (and I) can see.
    Slow down - first of all old bios is needed for copying the DMI information in it - nothing more, nothing less, so all the modifying we must do is related to the new file i.e. new bios. Secondly if you try to read the guide more carefully you will see that you must remove the header from the bios.cap file extracted from the bios update executable downloaded from the manufacturer support page.
    That's right - after extracting the bios.cap file from the update executable we must cut it to have the new (virgin) bios dump, and after moving the DMI information from our old dump to it we have the finished file ready to be programmed to the bios chip.
    Don't want to be rude but that's B.S. Both old and new file must be 16,384 KB each.
    Post #4 is about 41 version (GLCN41WW) of the bios, so first things first, the link for you to download this update executable is:
    https://download.lenovo.com/consumer...s/glcn41ww.exe
    Download the file, extract the bios.cap file from it, attach the file in your next post when ready, and we will continue to talk after that.
    I didn't use GLCN41ww because that's a very old version. I used GLCN52WW.
    I figured it out. I was following the post about extracting TDK files and it says to select/copy 0-800000 but my chip is 16 not 8. So, I made the adjustment and got the DMI info in. So, I am ready to hook up my programmer. I was making it much more complicated than it needed to be.
    Thanks!
  • Vesko356
    replied
    Originally posted by migreen06
    I read literally every post, on every thread, that was even remotely relevant, which unfortunately, was hundreds. It got all jumbled up in my head.
    Post 20 says to read post 4, the copyDMI guide. It also says to remove the header but it's unclear if I remove the header from the "oldbios" AND the "newbios."
    The "newbios" is the bin file made after unpacking the Phoenix TDK file, mentioned in a different thread on this site?
    Does it matter that my original bios ("oldbios") is
    16,384
    kb and the "newbios" is 8,192 Kb? attached both.
  • migreen06
    replied
    Read post #20
    The "newbios" is the bin file made after unpacking the Phoenix TDK file, mentioned in a different thread on this site? Does it matter that my original bios ("oldbios") is 16,384 kb and the "newbios" is 8,192 Kb? attached both.
    Sorry if these sound like stupid questions. Thanks for your help!
  • Vesko356
    replied
    Hi! Will this work for my laptop, its a different type? If it does, where do I change the type and serial number?
    IdeaPad 3-15ALC6
    Type: 82ku
    SN: PF2VDQ4T
    MTM: 82KU003NUS
    Mobo: HS461& HS561& HS761 NM-D521 2020-12-11 Rev:2.0
    Thanks!
    Read post #20
  • migreen06
    replied
    Virgin BIOS with your DMI, try it.
    IdeaPad 3-15ALC6
    Type: 82ku
    SN: PF2VDQ4T
    MTM: 82KU003NUS
    Thanks!
  • bladezru
    replied
    still the same address error, i will buy a new chip and try it again. Maybe this will fix it.
  • Vesko356
    replied
    Originally posted by bladezru
    thanks, but still not working.
    Is maybe the chip broken, if i try to verify the chip then i get every time different memory address
    Try NeoProgrammer V2.2.0.10 ---> https://www.badcaps.net/forum/showth...11#post1215111
    Don't use a clip.
  • bladezru
    replied
    HTML Code:
    Verify memory...
    Verification error on address: 00000296
    Execution time: 00:00:00.033
    Current programmer: CH341
    19:53:11
    Verify memory...
    Verification error on address: 000000AE
    Execution time: 00:00:00.031
  • hardware1
    replied
    Hello i already tried all the tutorials to create the bios by my own and also all the bios files which are in this forum, but still have a blackscreen. So i hope someone can create the bios for me and i will try again.
    Its a lenovo ideapad 3 15ACL6
    MO: PF9XB153151
    MTM: 82KU0034GE
    Rev 2.0
  • Marc97
    lenovo hs461&hs561&hs761 nm-d251 rev:2.0 bios bin file
    by Marc97
    hello there,, anyone who can help us to have bios for LENOVO
    HS461 HS561 HS761 NM-D251 REV 2.0
    I have downloaded bios from lenovo website,,, but it is .CAP FILE after my bios creator extract it...
    i attached the .CAP may you can help us also to trim it.....
    12-03-2022, 05:51 PM
  • macabook
    by macabook
    🧩 Initial Issue
    07-24-2025, 02:17 PM
  • Vesko356
    by Vesko356
    08-11-2023, 03:27 AM
  • jbonavita
    by jbonavita
    Some issues
    Things I tried
    04-29-2025, 09:38 PM
  • zenius
    by zenius
    12-08-2024, 06:13 AM
