Fix repair and clean me Lenovo 14s-iml BM5918_Rev1.3A
  • superhache
    • Nov 2018
    • 46
    • Argentina
    hello,
    i need to fix this bios dump with bios.cap
    and clean me region too
    but i dont know if this is he original bios dump. because laptop came from anoher service.
    bios.cap file was extracted from lenovo cqcn35ww.exe, thanks
  • fire1234
    • Dec 2017
    • 77
    • Poland
    Re: Fix repair and clean me Lenovo 14s-iml BM5918_Rev1.3A
    Originally posted by superhache
    hello,
    This is the sn P20A0LEZ number which was in the bios, if it is the same as on the housing, the bios should not be changed by another service, according to this number, this update cqcn35ww.exe should be correct.
    • superhache
      • Nov 2018
      • 46
      • Argentina
      ok, thanks, but laptop is not working , no video , so, i cannot update it trhu software, i need to reprogram the chip, can anybody help me? thanks
        • 22286
        Does the serial number that fire1234 found in the bios match the serial number on the case.Post a picture of the sticker. Do you have an SPI programmer ?
        • superhache
          • Nov 2018
          • 46
          • Argentina
          hi,
          serial does not mach, can be hex edited?
          and yes, i do have a spi programmer
            • 22286
            hi,
            try this one.
            • superhache
              • Nov 2018
              • 46
              • Argentina
              OMG!! thank you so much guys! it worked!!
              i managed to extract bios cap from lenovo exe file, but it was a partial bios,
              where can i learn how to rebuild it? for lenovo or any other else?
              thanks!
              Originally posted by SMDFlea
              try this one.
              • AHmad_Salal
                Need BIOS Dump/ROM for Lenovo Thinkstation p500
                by AHmad_Salal
                Hello all,
                I have a Lenovo Thinkstation P500 that is stuck at post with no display, it happened after I changed the memory timings in bios. I can not clear CMOS using the jumper on the motherboard, also tried re-flashing bios suing a USB stick but it also doesn't work. The only solution that I can think of right now is re-flashing the bios chip using an external programmer but the problem is that I don't have the bios dump of p500 for flashing externally and I don't know the location of bios chip. If someone can provide the bios dump and bios chip location it would be really helpful....
                11-28-2023, 05:28 AM
              • Ahari
                by Ahari
                I...
                08-13-2025, 06:12 AM
              • Habble7
                by Habble7
                Suspected Cause:
                Troubleshooting Attempts:
                05-22-2025, 07:28 AM
              • mkdj
                Lenovo IdeaPad 3 - Hard Disk not recognized in BIOS
                by mkdj
                Dear all,
                I have recently fixed a Lenovo IdeaPad 3 15 ALC6 that was not booting due to a BIOS issue. After flashing the BIOS, the laptop boots up, but hard disk is not recognized in BIOS. Is says "Hard Disk : Not Installed". I have tried with 2 different drives (one that I know is working on another laptop) but I get the same result. I do not know if disks were recognized before I got the laptop and fix it, but I don't see any reason why not. I can boot on USB though.
                Here the steps I have taken to fix the laptop:
                - downloaded latest BIOS from Lenovo Website...
                10-18-2025, 03:43 AM
              • Captaincrap420
                Lenovo Tiny8 triple NVMe IQ6X0IL1 HQ670 NM-D581 Rev 0.5 M90q Gen 3 / P360 Tiny prototype board BIOS dump
                by Captaincrap420
                Hi, I hope this is the right place to post this. This is my first post on this forum.
                A friend helped me get a prototype Lenovo motherboard from China, it's got a hole drilled in it but I'm working on trying to revive it to some degree. I dumped the bios in hopes that it might be useful to someone, since this board is configured with the 3rd NVMe SSD slot and maybe it is useful as a reference for modding another bios to support this function. For example the M90q Gen 2 / P350's unpopulated 3rd NVMe slot footprint maybe.
                This bios dump is straight from the chip, nothing has been...
                11-29-2024, 05:40 PM
