Need LA-E541P io kbc pin connection
  • bilen
    • Aug 2014
    • 637
    • istanbul
    Lenovo yoga 520-14ıkb NPCE388 KBC PİN CONNECTİON
    • 22279
    Re: Need LA-E541P io kbc pin connection
    • bilen
      • Aug 2014
      • 637
      • istanbul
      Originally posted by SMDFlea
      please : sample '' LA-E541P (JKB1) KB_pins=32 SOL 08MM JENK=39 TCK=51 TMS=52 TDI=53 TDO=44''
      can you give form...
      • bilen
        • Aug 2014
        • 637
        • istanbul
        Please help me ....
          • 22279
          What model is your programmer, is it a vertyanov clone, is pin 1 of the keyboard connector on the left or right side,are the pins up or down
          • bilen
            • Aug 2014
            • 637
            • istanbul
            • bilen
              • Aug 2014
              • 637
              • istanbul
              Here is the program interface. is it enough ?
                • 22279
                Check which pin has +5VALW in the 2nd picture at post #2 then you will know if pin 1 matches with both connectors or if its reversed. I can`t help you with the software if some settings are different to the genuine vertyanov .
                • bilen
                  • Aug 2014
                  • 637
                  • istanbul
                  32. pin 5v
                  • bilen
                    • Aug 2014
                    • 637
                    • istanbul
                    our device is the same.
                    I just couldn't write the pin connection line properly.
                      • 22279
                      The pictures at post #2 are taken from the LA-E541P schematic.Mark on your picture which pin you have +5VALW on
                      • bilen
                        • Aug 2014
                        • 637
                        • istanbul
                          • 22279
                          Try the LA-D451P setting.
                          LA-D451P KB_pins=32 LEFT JENK=20 TCK=8 TMS=7 TDI=6 TDO=17
                          • damisure
                            • Jan 2017
                            • 6
                            • Mongolia
                            LA-E541P
                            NPCE388NA1DX
                            Tried this combination of code:
                            (with 30 pin, one side)
                            LA-E541P KB_pins=32 LEFT 08MM JENK=39 TCK=51 TMS=52 TDI=53 TDO=44
                            But it says:
                            "Invalid settings for Nuvoton MB!"
                            (with Read and Write buttons inactive)
                            But when I push "Check connection" it is likely has a connection with MB:
                            (No any error msg)
                            "FTDI driver version 21236
                            Version FW JIG M328_EPM240_v34
                            2F2F7B916B2DBDF165C3C665"
                            With the given configuration, for example:
                            LA-E451P (JKB1) KB_pins=32 LEFT 08MM JENK=20 TCK=8 TMS=7 TDI=6 TDO=17
                            as you offered above, it gives error:
                            (after connection check)
                            4/12/2023 4:23:19 PM
                            2F2F7B91632DBDF165C3C665
                            Read NUVOTON ID FFFFFFFF
                            Wrong ID. Break.
                            Possible reasons:
                            1 No power is connected to the MB
                            2 No power on a chip EC
                            3 Defective chip EC
                            4 Invalid defined first contact
                            5 Invalid settings for MB
                            How to make active Read and Write buttons with non standart configuration, please advice!
                            • budwich
                              Lithium 12v tool battery charger... no negative connection?
                              by budwich
                              I have a drill and battery but no charger so I bought a "universal charger" 120ac in ... 12vdc out (not really universal in lithium world). Anyway it has three contacts, positive, negative and "T" (temperature sensor). I connected those contacts to the contacts on the battery. No charging happened and only the status light is on (green solid) which the label indicates "100% charged".... but the battery isn't near that at around 9v and dying. There doesn't appear to be any difference whether the battery is connected or not. I got suspicious and pulled the...
                              03-18-2025, 09:12 AM
                            • Demetrio87
                              Legion t 5 front audio panel connection problem
                              by Demetrio87
                              Hi everyone, I hope someone can help me solve my problem, I have the case of a legion t5 where I have installed an asus tuf gamig a520m-plus motherboard, the audio connection cable on the case is an F_audio connector with 14 PIN , on my new motherboard the connector is a 10-pin AAFP, I saw that there are adapters on sale but at the moment I have no way of having them available in a short time, I made several attempts and managed to listen from the front headphones, only that there are some problems, the headphones are only detected if the microphone is connected, I definitely got confused with...
                              12-08-2023, 12:06 PM
                            • Nikan.e
                              Inno 3d RTX2070 not detected - no I²C connection
                              by Nikan.e
                              Greetings and Salutations!
                              I have encountered a faulty GPU — an Inno3D RTX 2070 Twin. There was a shorted MOSFET on the Vcore rail.
                              The faulty DrMOS was removed, and the burned PCB area was milled away.
                              All voltages are now good, but the GPU is not being detected.
                              I found that the CS pin of the BIOS (GPU) is not being pulled low, and thus, the GPU isn't detected.
                              I wanted to measure the SM_Data and SM_Clock, but to my surprise, there is no connection at all.
                              I thought these pins were used for communication during startup?!?
                              On all...
                              03-30-2025, 07:21 AM
                            • mafioso3
                              lenovo x13 yoga gen1 EC bios file from (npce388)
                              by mafioso3
                              hello
                              i'm looking for lenovo x13 yoga gen1 EC bios file from (npce388)
                              i have already downloaded the bios file from lenovo website ,but after decompressing the EXE file,i only got FL1,no way to extract EC from it.
                              could someone please upload a unlocked npce388 EC file?
                              thanks in advance
                              SOLVED
                              03-13-2023, 02:20 AM
                            • spleenharvester
                              Synology MR2200ac mesh router, UART connection - login details?
                              by spleenharvester
                              This particular unit powers up, LEDs behave normally, but broadcasts no SSID, will not mesh with any other routers. Plugging in an ethernet cable from a Windows laptop results in "unidentified network" with an autoconfigured IP address and no response to pinging 192.168.1.1.
                              I was able to log into serial/UART by connecting the 6-pin header to the GPIO on a Raspberry Pi Zero W (GND to GND, TxD to RxD, RxD to TxD, no connection between +3.3V as it is supplied on both sides) using Minicom, command:
                              Code:
                              sudo minicom --baudrate 115200 --device /dev/ttyS0
                              09-02-2024, 01:19 PM
