MSI - GE72 6QD Apache Pro - gaming laptop
  • rammstein9910
    • Feb 2019
    • 14
    Hello everyone, I need a dump file for MSI gaming laptop GE72 6QD
    MSI GE72 6QD APACHE PRO ( Skylake)
    MB: MS-1795
    BIOS Version 106
    ec 101
    What I have done: Tried to update BIOS from HDD from inside the BIOS built-in tool, it went succesfull the laptop restarted and had blank black screen no backlight. CPU fan spins after a minute, cpu-gpu warm, keyboard lit.
    Currently waiting for the CH341A programmer to arrive.
    I updated a 2015??? bios to 2018E1795IMS.11D /dont know the old version precisely./
  • peste
    • Dec 2016
    • 12792
    • ROMANIA
    Re: MSI - GE72 6QD Apache Pro - gaming laptop
    MB: MS-1795
    BIOS Version 106
    ec 101
    https://www.msi.com/Laptop/ge72-6qd-...port#down-bios
    • rammstein9910
      • Feb 2019
      • 14
      I used the latest bios from that website and did not check their suggestion so ended up with bricked board.
      • peste
        • Dec 2016
        • 12792
        • ROMANIA
        is the bios on the MSI site, you won't find a better one, what programmer do you have? did you remove the bios chip from the board before writing?
        • rammstein9910
          • Feb 2019
          • 14
          Exactly: KeeYees SOP8 SOIC8 Test Clip for EEPROM 25CXX / 24CXX + CH341A 24 25 Series EEPROM Flash BIOS USB Programmer. ////from amazon
          No, I didnt remove it. I`m planning to use the clip what comes with.
          • peste
            • Dec 2016
            • 12792
            • ROMANIA
            with the clip you may have errors..it would be better to remove the chip from the board, or to glue wires between the programmer and the chip ..
            • rammstein9910
              • Feb 2019
              • 14
              OK, as soon as I receive it, i will update the thread.
              • rammstein9910
                • Feb 2019
                • 14
                I received today the programmer, i did use the file as you linked from the manufacturer website. I was able to write it for the first time, had no issue.
                I was worried about EC chip (Don`t know what is that for yet) but that was fine.
                • death1815
                  • Jul 2022
                  • panama
                  I need the number of the chip set
                  • rammstein9910
                    • Feb 2019
                    • 14
                    What do you mean?
                    • dr.thodt
                      • Apr 2016
                      • 80
                      • Netherlands
                      I've a MSI GE72 which crashed during firmware update, according to the customer.
                      The symptoms are exact like original poster's issue.
                      I did flash a new BIN to the chip (off board). This did not change anything.
                      I do see traffic between bios and cpu when probing pin 2 and 5 of the bios chip, so something is good.
                      The final thing I want to try is reflashing the EC. I did practice on another board with the ENE KB9028Q on it, which succeeded, so I'd like to give it a go on this one.
                      Can somebody help me with an EC dump?
                        SMDFlea commented
                        Editing a comment
                        post the laptop serial number and the EC backup
                    • dr.thodt
                      • Apr 2016
                      • 80
                      • Netherlands
                      I get verification errors while dumping this EC.
                      Serial number is GE72 6QD-016NLK1509000008.
                      So I probably found the smoking gun: corrupt EC chip.
                      I do have spare EC chips, so that shouldn't be a problem. Unless you really need a dump.
                      • peste
                        • Dec 2016
                        • 12792
                        • ROMANIA
                        post full name and model, motherboard model,
                        • dr.thodt
                          • Apr 2016
                          • 80
                          • Netherlands
                          MSI
                          GE72 6QD-016NL
                          PSN: GE72 6QD-016NL-BB7670H16G1T0DS10MH
                          S/N: GE72 6QD-016NLK1509000008
                          Model no: MS-1795
                          Mainboard: MS-16J51 ver 1.0
                          • hoaca388
                            Badcaps
                            • Jan 2022
                            • 11733
                            MSI
                            GE72 6QD-016NL
                            Model no: MS-1795
                            GE72 6QD Apache Pro EC
                            • dr.thodt
                              • Apr 2016
                              • 80
                              • Netherlands
                              Thanks for the quick effort.
                              Unfortunately this did not change the laptop's behavior.
                              From this point on this machine sadly became a brick.
                              • Blasphemous-Troll
                                • May 2025
                                • 7
                                • India
                                Would you by any chance have the ec dump for Kb9028q - C for the MSI GF63 Thin 10SC-838. (i5 10500H, 1650 max q).
                                My laptop is at a repair shop which broke it and is claiming they can't do anything as they don't have the program to flash onto a new chip.
                                  • 20884
                                  Off topic. This thread is for the GE72 6QD
                                  • Blasphemous-Troll
                                    • May 2025
                                    • 7
                                    • India
                                    Hey sorry I don't know how this forum works I think I've posted a message separately as well although I fear there is another post discussing the same topic which I can't find. Apologies from my side.
                                    • Bloodhoundje
                                      HP Pavilion Gaming Laptop 15-ec2523nd - Dimm2 slot disabled after corrupt bios repair? Advice requested.
                                      by Bloodhoundje
                                      I have been doing hardware repair as a hobby for some years now and recently decided to learn about repairing laptops as a fun challenge.
                                      I managed to get my hands on a "HP Pavilion Gaming 15-ec2523nd" notebook that only shows a white power LED and doesnt respond to anything.
                                      After initial testing I concluded the bios seems to be corrupted since all voltages are normal and there are no shorts. HP has a feature for a bios restore from USB with winkey+B for this model. This did not work.
                                      I have desoldered the bios chip (GigaDevice...
                                      03-16-2024, 03:12 PM
                                    • JoWed
                                      Problems with reflashing BIOS Chip on omen by hp laptop 17 an104ng
                                      by JoWed
                                      Hello Community,
                                      I recently tried to change the Batterie on my Omen by HP Laptop 17 an104ng and after putting in the new batterie ([Batterie Link](https://www.amazon.de/7xinbox-17-AN0...&keywords=16%2...
                                      07-01-2025, 09:32 AM
                                    • grimacelord
                                      by grimacelord
                                      07-10-2025, 02:52 PM
                                    • thxd43
                                      Lenovo laptop does not turn on, what does this number mean in a BIOS chip?
                                      by thxd43
                                      Hello, first of all, excuse me, I am using the translator, English is not my native language.
                                      I have a Lenovo ideapad 330S - 14IKB laptop.
                                      The tablet did not recognize me when I connected it, so I checked the device manager and I realized that there were many with the exclamation mark, so one by one I began to update their drivers until the sign disappeared of admiration, I even updated the BIOS, and the laptop rebooted normally and worked, so far so good, but the tablet still did not recognize me, I read on the internet that it could be due to a...
                                      02-23-2023, 08:37 PM
                                    • legendkray
                                      BIOS Help Regarding GM5IX7A-GM6IX7A Origin Laptop
                                      by legendkray
                                      I have OriginPC EON 15SL, however, my laptop starts and shutsdown after 1-2 second. Keyboard leds are coming on then fans spinning then it shutsdown and not turning back on unless I plug out the power cable and plug it in. I had issues with bricked BIOS then I flashed BIOS I got from the vendor to the SPI chip and still it didn’t worked because my EC firmware was newer than the BIOS I have flashed. So I wanted to try flashing the EC chip with the correct firmware that matches with the BIOS also from the vendor and it worked everything was well, and then stupid me wanted to unlock some...
                                      07-05-2025, 09:25 AM
