Where can i find BIOS Cip on motherboard (HP EliteBook 840 G8)
  • HisretD
    • May 2017
    • 8
    • Sweden
    Does anybody now where i can find BIOS Chip on motherboard for HP EliteBook 840 G8? And also, does this modell has one or two chips? becouse sometimes there is 16MB and 32MB chip. Would really appreciate help
  • lleg0
    tuzbiosu'ma-tii
    • Jul 2022
    • 16
    • Romania
    Re: Where can i find BIOS Cip on motherboard (HP EliteBook 840 G8)
    Back of the motherboard - EC chip
    Front of the motherboard - BIOS chip
    You need both for password
    • CammyTier1
      Tier 1 Assets
      • May 2022
      • 43
      hmm i only been dumping 32mb EC chip for password on backside off the board
      dont think the 16mb bios chip is needed for password (could be wrong on that tho)
      • lleg0
        tuzbiosu'ma-tii
        • Jul 2022
        • 16
        • Romania
        I may be wrong as i didn;t manage to unlock mine yet. What IC programmer did you use for G8?
        • Mazorca
          • Jan 2017
          • 463
          Method I know is thru the HEX Editor. Look for 840-G8-Patch in RCUnlocker thread.
          • lleg0
            tuzbiosu'ma-tii
            • Jul 2022
            • 16
            • Romania
            I mean the tool.AM i good with cheap CH341A or do i need a better one?
            • mandrake87
              • Jun 2022
              • 70
              • argentina
              Does anyone know how to remove the HP 840 g8 endpoint security fault? After unlocking I get that error.?
              • acedogblast
                by acedogblast
                11-02-2024, 05:13 PM
              • glovecaps
                Asus ROG Strix Scar G533qm with a G733qm Motherboard, can I modify the Bios to accept G533 Bios
                by glovecaps
                I have a Asus ROG Strix Scar 15 (G533QM) that had a dead motherboard (Graphics card dead) and after trying to fix the motherboard with no success, I bit the bullet on a sale for a new motherboard. I ordered a motherboard for the 15 inch model which is the one that I have, and when the motherboard arrived it wasn't for a little while that I saw it was from the 17 inch model.
                My question is, can I update the Bios on this G733 motherboard to a G533 Bios.
                The reason for wanting to do this is that the keyboard isn't working as it should, and I think this...
                11-25-2024, 04:23 PM
              • hotcrossedbuns999
                M715q Desktop (ThinkCentre) - Type 10M3 - Request bios chip location and useable bios for use with CH341A Programmer.
                by hotcrossedbuns999
                My pc updated bios through Windows Update and I was greeted with BLACK SCREEN WITH CPU FAN MAX SPEED. I don't think there is even a screen signal, because it triggers my monitor for a couple seconds and then the monitor turns off. I tried the other outputs as well.
                1. I tried clearing bios, resetting bios, removed the CMOS battery, removed m.2 ssd, wifi, and ram. Still black screen with CPU fan blasting.
                2. I tried using the Lenovo BIOS CD and BIOS USB, but neither worked. At least I couldn't get anything to work.
                3. I could only locate two chips that look like bios chips. Could someone verify this
                01-03-2025, 12:32 PM
              • inck243
                Acer e15-e5-576g-5762 bricked. Bios chip won't interface in AsProgrammer.
                by inck243
                Thanks for any help. The board version is DAZAARMB6E0 REV: E. The bios chip is winbond 25Q64JVSIQ1736. W25Q64JV is not available in AsProgrammer -- only BV CV FV or FW_1.8c. The chip won't interface with asProgrammer and a CH341A. When I have this chip on the board, the laptop will not post but when I plug it in to power, the blue LED lights up, also the orange when the battery is connected. When I push the power on button, keyboard backlight turns on and the fan starts briefely then turns off. But I can't do anything to program this bios chip so I bought another one.
                The BIOS...
                07-25-2024, 09:17 AM
              • ezenia
                Dell G3 3579 BIOS chip ID
                by ezenia
                I bought a Dell G3 3579 eBay. The fault was not mentioned and it did not come with charger. Before trying to power off battery, I did some basic checks on the coils (in resistance mode) to see if there was any short. None were reading short. Decided to power the board to see if anything happened. The keyboard backlight came on. About 5 seconds later, the fans begin spinning at max speed. The white LED comes on at this time, stays solid for a bit and goes off. Fans continue to spin at max. Display is black (no backlight). If I hold down power button, board goes off. I did give...
                06-16-2025, 08:07 PM
