820-00165-a 2015 - no serial
  • magneh
    • Apr 2014
    • 607
    • Portugal
    Hello guys
    Got this original dump from a 820-00165-A 2015 with no serial
    Everything seems to work fine, except theres no SN
    I tried to look for the "ssn" string but in this dump only one result and its not the Serial string
    It has Big Sur on the SSD, so I suppose something changed on this firmware version
    Anyone knows where to insert the serial?
    SN:CPWS37FDH3QD
    Heres the dump, in case someone has some minutes to help
    Thanks!
  • DanielDacko
    • Mar 2015
    • 326
    • Macedonia
    Re: 820-00165-a 2015 - no serial
    Try this.
    I don't provide help for people using CH341A and a clip.
    • magneh
      • Apr 2014
      • 607
      • Portugal
      thanks but even without trying it, I can check that the file checksum is invalid
      will try to fix it tomorrow and test the file anyways
      Nobody knows where the ssn string is in the original file?
      • magneh
        • Apr 2014
        • 607
        • Portugal
        Originally posted by DanielDacko
        Try this.
        Works after correcting checksum, but its in Chinese
        • reformatt
          • Feb 2020
          • 1480
          Your entire Fsys block is missing/corrupt. Try this one, it's from a 2015 dump with clean ME, SSN updated and checksum corrected. I don't recall what FW revision it is though, so you may need to run the Big Sur installer through to update it.
          • erkko13
            Thinkpad L390 Yoga (type 20NT serial R90VZWLN) BIOS2 dump needed
            by erkko13
            Ho ho ho, badcaps people,
            if this qualifies as bios request, hopefully. Actually BIOS2 for that laptop is second smaller SPI flash (Winbond W25Q80DVSNIG-GP-U), containing supposedly some config for TPS65988 which in turn manages USB-C stuff, including PD. This is possibly flash, where update "Power Delivery Firmware (TI TPS65988)" F407.06.29 -- https://download.lenovo.com/pccbbs/mobiles/r10pd10w.exe does its thing. Previous owner claims that after clean install of Windows 10 he installed thinkvantage tool of sort, which updated everything for that laptop. I did glance over...
            12-25-2024, 06:41 AM
          • yura8
            Need BIOS/EFI dump for MacBook Air A1466 2015 EMC 2925 (8gb)
            by yura8
            Hi there! I have not so usual situation...
            I have 2015 MacBook Air A1466 EMC 2925 with 8Gb of RAM. It seams that I've killed it by bad SSD adapter. It starts, cooler works... But no chime, screen is black. SMC reset seams works, NVRAM reset doesnt works...
            My repair guy has checked all possible. It's all ok with power. The last idea - I could kill EFI firmware... So, I need a firmware of EFI to check it. I have a programmer. But I don't have a similar laptop now to download it and compare
            P.S. If you have else any ideas about repair, or you had a similar...
            12-20-2024, 02:31 PM
          • bruce35
            HP 600 G3 MT serial number change please
            by bruce35
            HP 600 G3 MT
            SERIAL NUMBER MXL8301K1C Serial number in the file in bios
            SERIAL NUMBER CZC72988BY original serial number of the safe original serial number of the safe
            Thank you very much...
            09-24-2025, 02:32 AM
          • Habble7
            by Habble7
            Suspected Cause:
            Troubleshooting Attempts:
            05-22-2025, 07:28 AM
          • grimacelord
            Trying To Find UUID In BIOS Dump - HP 14-dq0055dx
            by grimacelord
            This laptop is the same laptop I was working on in this thread and I wasn't sure if I should post a new topic or post in that thread because I already solved the issue that thread was discussing and this is a completely different issue although it is dealing with the same laptop. I decided to make a new thread since it's a new issue, but please move if I made a mistake.
            Motherboard model number: DA0PAMB46A1 REV: A
            Secondary motherboard model number: 0PAB
            SKU: 685K4UA
            Serial number is: 5CD3223BJP
            Recently reflashed this laptop with latest BIOS and once...
            05-07-2024, 08:06 AM
