macbook pro A1425 emc 2557 bios request
  • ramrk
    • Feb 2019
    • 155
    • India
    bios bin file please
  • peste
    • Dec 2016
    • 13592
    • ROMANIA
    Re: macbook pro A1425 emc 2557 bios request
    post the backup copy of the original laptop bios
    • marce002
      • May 2018
      • 316
      • Argentine
      Desperate need to unlock a1425 emc 2557 firmware very "locked"
      Hi everyone!
      I have bought an used 820-3462 motherboard on an ecommerce site: mercadolibre/.. is like ebay, I replaced my old motherboard (burned SMC) with this one, but realized it was pin locked with 4 codes.. i cant return it so replaced the efi chip with my old motherboard but still not working fine... downloaded a dump replaced my own serial but still no luck... it shows a blinking folder but as soon as i assemble the whole mac it will go to black screen (only chime)... and this is driving me crazy because i did solder and desolder the efi chip 12 times!!! trying different options and dumps ... I do not have raspberry, only a simple ch34a which flashes ok on the dump, that is not the issue. The problem is that whatever firmware I place on it after 2 or 3 restarts or connecting everything, it goes to chime and black screen of death (backlight present though).. WHAT I'M doing wrong?
      Now seems to be black screen only after chime,, no more blinking folder.
      thanks in advance!!
      PD i have original dump (and more that 12 modified versions that i have already tried..) in original the ME ANALYZER shows:
      Firmware: Intel ME
      Version: 8.0.4.1441
      Release: Production
      Type: Region, Extracted
      FD: Unlocked
      SKU: 1.5MB
      VCN: 2
      PV: Yes
      Date: 06/03/2012
      FITC Ver: 8.0.4.1441
      Latest: No
      Marcelo J
      • peste
        • Dec 2016
        • 13592
        • ROMANIA
        Re: Desperate need to unlock a1425 emc 2557 firmware very "locked"
        Originally posted by marce002
        Hi everyone!
        thanks in advance!!
        Firmware: Intel ME
        Version: 8.0.4.1441
        Release: Production
        FD: Unlocked
        SKU: 1.5MB
        VCN: 2
        PV: Yes
        Date: 06/03/2012
        Latest: No
        post the original bios of the motherboard you bought... and the serial number S/N on the case...
        • marce002
          • May 2018
          • 316
          • Argentine
          yes in the last post is the file! and the serial is already on it . thks peste
          Marcelo J
          • peste
            • Dec 2016
            • 13592
            • ROMANIA
            try..
            • marce002
              • May 2018
              • 316
              • Argentine
              thks a lot peste but did not seem to work. the screen is backlight on as expected, DID NOT hear a chime (will try edit and another serial) but nothing goes on, no drive option no folder blinking.... the screen as i have said is ok because when battery goes down it shows this:
              note that with another firmware i can hear a chime at least... would you like me to post the BIN which let me hear the chime or what else can I try... really apreciate your help thks
              PD I will attach below (for comparison maybe) the EFI you have posted , it is being modified by the system, and do not match the one i have flashed after restart (yours)
              I can do it pretty fast because i have wired the efi chip to flash and retrieve instantly.
              Marcelo J
              • marce002
                • May 2018
                • 316
                • Argentine
                with this bin it chimes but agin no image no boot options...
                thnks
                Marcelo J
                • peste
                  • Dec 2016
                  • 13592
                  • ROMANIA
                  thnks
                  post the full name and model of the laptop, EMC, motherboard model, s/n on the case......
                  • marce002
                    • May 2018
                    • 316
                    • Argentine
                    Ok the macbook I own data:
                    Model A1425 EMC2557 2012
                    C02L21JYDR53
                    The mother I have bought has the BIN that i have posted at beggining.
                    The mother was bought from mercadolibre so do not have case. just did a swap
                    motherboards because already explained that had a smc failure and i could not replace it.
                    Marcelo J
                    • reformatt
                      • Feb 2020
                      • 1500
                      Try this one, off a working A1425, clean ME and tested. Updated with your S/N and Fsys checksum corrected.
                      • marce002
                        • May 2018
                        • 316
                        • Argentine
                        Nop, same thing but "no chime"... no logo only backlight... strange.. as soon as i turn it on
                        with the new firmware, it modifies it, comparingboth with winmerge i can see a lot of different zones.... this is so locked that i do not know what to think or learn from this case.
                        i attach the re read efi after power on the mac
                        Marcelo J
                        • peste
                          • Dec 2016
                          • 13592
                          • ROMANIA
                          try..
                          • reformatt
                            • Feb 2020
                            • 1500
                            Can you make sure you are indeed using a 820-3462 motherboard? There was a later variant of the board for the A1425, 820-3190. The part number is hidden under a piece of black tape at the top of the board to the right of L7560.
                            If that is all ok, then I would do a sanity check on the U6100 connections to the rest of the board with a meter (R5021~R5024) as you said you had taken U6100 off the board a number of times.
                            • marce002
                              • May 2018
                              • 316
                              • Argentine
                              yes it says 3462-A... did not know was under that label thks for that. and im going to check traces and my wiring i know only a cap is missing at this time C6100 but the mother is wired and in place , since it is flashing ok and i can read the chip fine, and also is doing chime when i flash a semi good EFI and not chiming in yours or other ones i know that missing GND cap for the moment is not my issue (in diagram is the tiny one arroung the efi chip u6100)....
                              this is like the chipset or mother would be locked after many attemps to try different bios, is this possible? only problem is the no image now vs before (at least the first 3 or 4 tries i had image apple logo and bar forever, or the 4 pin lock number that finally the seller told me to be "1234".... unfortunatelly i cant get to the point to have in screen that 4 pin lock to enter it, since things got worse and now have only a chime when the firmware is semi good)
                              Marcelo J
                              • peste
                                • Dec 2016
                                • 13592
                                • ROMANIA
                                did you try post #13???
                                • marce002
                                  • May 2018
                                  • 316
                                  • Argentine
                                  post 13 chimes ok, but no image at all... only backlight ...at least that sound is fine.. if i wouldnt have seen the low battery indicator in full screen, i would asume a bad screen but i know is a good macbook unit besides this EFI issue... if i had time enough i would try alternate efi like coreboot for example , but unless i find a redy to use BIN file I cant deal with compile and all that nightmare...
                                  Marcelo J
                                  • marce002
                                    • May 2018
                                    • 316
                                    • Argentine
                                    i will take apart the board again, and re check all those lines and place that missing cap again in the board.... thks
                                    Marcelo J
                                    • reformatt
                                      • Feb 2020
                                      • 1500
                                      As I said in the other group, I troubleshoot MAC boards out of the chassis with a Chipmunk and USB ammeter. Once I get the blinking on the USB port I know it's trying to boot an OS. USB ammeter tells me whether the CPU is executing code or not. Chime generally indicates that it's POST'ed.
                                      • marce002
                                        • May 2018
                                        • 316
                                        • Argentine
                                        yes, i see no blinking usb (mouse) activity is zero... but it is 5.02v with usb meter.... i do not have chipmunk but i see that after the chime nothing else happens,
                                        Marcelo J
                                        • jbonavita
                                          by jbonavita
                                          Some issues
                                          Things I tried
                                          04-29-2025, 09:38 PM
                                        • zenius
                                          by zenius
                                          12-08-2024, 06:13 AM
                                        • Wahaz
                                          by Wahaz
                                          10-30-2023, 08:42 PM
                                        • hotcrossedbuns999
                                          M715q Desktop (ThinkCentre) - Type 10M3 - Request bios chip location and useable bios for use with CH341A Programmer.
                                          by hotcrossedbuns999
                                          My pc updated bios through Windows Update and I was greeted with BLACK SCREEN WITH CPU FAN MAX SPEED. I don't think there is even a screen signal, because it triggers my monitor for a couple seconds and then the monitor turns off. I tried the other outputs as well.
                                          1. I tried clearing bios, resetting bios, removed the CMOS battery, removed m.2 ssd, wifi, and ram. Still black screen with CPU fan blasting.
                                          2. I tried using the Lenovo BIOS CD and BIOS USB, but neither worked. At least I couldn't get anything to work.
                                          3. I could only locate two chips that look like bios chips. Could someone verify this
                                          01-03-2025, 12:32 PM
                                        • macabook
                                          by macabook
                                          🧩 Initial Issue
                                          07-24-2025, 02:17 PM
