MacBook Air A1466 (EMC 2559)
  • ultravarialheadspin
    • May 2020
    • 47
    • Česko
    Hi, i have problem with my macbook air
    it was EFI locked, some other men from other forum give me FILE and i was flashed to my BIOS chip. But it was bad bin file. My macbook air not boot and fast spining fann.
    macbook air a1466
    emc 2559
    serial number : C02J56VNDRVD
    820-3437-B board number
    i need bios bin file with clean me region etc.
    i am newbee on flashing bios chips, sorry for my stupidit brean And sorry i am not backed up ORIGINAL BIN FILES please help me i can not solved this problem half year.
    emc 2559
  • skynet85
    • Jul 2015
    • 124
    • Georgia
    Hi gays , please help me, i am need correct dump, laptop turns on slowly. wrote down different firmware versions did not help. there used to be a file, but I lost the image file that the bootloader edited and only the command remained (bless -mount / -firmware "/EFIPayloads/MBA61_0099_B19_LOCKED.scap" --recovery –verbose
    • mferna14
      • Jun 2018
      • 1027
      Re: EFIBIN File MacBook Air A1466 (EMC 2632) 820-3437-B
      macbook air a1466
      emc 2559
      No worries., right now I am not on that computer., will send you the file tomorrow morning, don't worry.
        • May 2020
        • 47
        • Česko
        i am wayting thx you men you save my notebook
        • mferna14
          • Jun 2018
          • 1027
          Here you go EMC 2559 with your serial number & ME region cleaned. Please program & report. Thanks
            • May 2020
            • 47
            • Česko
            macbook air a1466 not boot, no fan spin, nothing happenned where is problem?
              • May 2020
              • 47
              • Česko
              ok so macbbook air start but no image and speed fan is so fast
                • May 2020
                • 47
                • Česko
                is there some tutorial or somethink that i can learn why my 2 macbooks not still not working? i know it is bad data bios or i make somethink wrong when i flash bios chip in the program xgecu pro.
                • dqtech
                  Badcaps
                  • Jul 2018
                  • 630
                  • N/A
                  thanks sir...it work
                  • dzabdou
                    • Sep 2020
                    • Algérie
                    hi friends
                    i have a problem with a Macbook Air A1466 EMC2559
                    the bios chip has been damaged , and i didin't have the bin file , i need a bin file programed with my serial number : C02K16Q3DRVC
                    i tried a bin file with random Serial number , the laptop doesn't turn on ( just the fan keep start and stop )
                    please help Me
                    • dzabdou
                      • Sep 2020
                      • Algérie
                      bump
                      • mferna14
                        • Jun 2018
                        • 1027
                        Dear buddies., can someone please clean this BIOS. I having problems editing this BIOS. I have no reason why, I think I have to reformat my HDD, too much junk. Kindly clean & update for me, thanks in advance. I have uploaded Original BIOS Bin file.
                        MacBook Air A1466
                        EMC 2559
                        S. No: C02J60BHF2FV
                        Logic Board # 820-3209-A
                        • peste
                          • Dec 2016
                          • 12940
                          • ROMANIA
                          MacBook Air A1466
                          EMC 2559
                          S. No: C02J60BHF2FV
                          try,,
                          • mferna14
                            • Jun 2018
                            • 1027
                            Originally posted by peste
                            try,,
                            100% working.. Thank you very much. If you kindly check the photo, what wrong did I do, why did my "Intel CleanMe" program pick up the wrong version??? Right one is which I did & the LHS is the one which you edited.
                            • Daniel Larsson
                              Firmware file for LG SK10Y Soundbar stuck in Please wait loop needed
                              by Daniel Larsson
                              My LG Soundbar, SK10Y, has somehow ended up in an endless "PLEASE WAIT" loop and I am now starting to suspect that the firmware is causing this, and I can't manage to connect via the app to push a new firmware in as it never really starts.
                              I can trick it to start via HDMI ARC and it actually starts up, flashes OPTICAL and then goes to ARC where the sound (including sub) is perfect, but the white led indicator keeps blinking and after 20 seconds it says "GOOD BYE" and shuts down.
                              During these seconds the function button is not working...
                              08-13-2025, 10:29 AM
                            • Daniel Larsson
                              Firmware file for Marantz NR1501 needed
                              by Daniel Larsson
                              I picked up a Marantz NR1501 that the seller said did not produce any audio, but was starting up just like normal. This was indeed the case and the hunt for damaged components started.
                              After confirming all voltages and replacing all caps on this godforsaken HDMI-board I finally got sound from the AUX input, but all digital inputs are still dead.
                              The service menu shows no DSP version so I desoldered IC1604 that should have the serial flash DSP firmware on it and made two dumps that turned out identical.
                              The content of these seems to be useless as far...
                              05-23-2025, 04:11 AM
                            • GeckoGreen
                              Samsung service bulletin: need firmware file for PN63C550 TV
                              by GeckoGreen
                              I'm hoping someone with access to the Samsung GSPN can help me. I need someone with access to download a firmware file for my PN63C550 TV, as it will fix a problem per the Samsung service bulletin.
                              You can reference Samsung bulletin #:ASC20130528001 and I need the [2D63]LOGIC.bin file please.
                              The full service bulletin is linked here: https://www.avsforum.com/attachments...3-pdf.1080602/
                              Will you please help me get the [2D63]LOGIC.bin file for my TV?
                              05-17-2025, 02:47 PM
                            • psdavid65
                              Macbook Air A1466 820-3437-B Booting Problem
                              by psdavid65
                              I received a 2013 Macbook Air A1466 820-3437-B motherboard with serial number C02L6GQ9FSV8 that came in WITHOUT a bios chip. I got a new bios chip and reprogrammed it. Macbook now powers on but doesn't boot the SSD. I've flashed a ton of bios but still same problem. Windows installation works with this Macbook but never a mac installation. Unfortunately, since I didn't receive this macbook with a bios chip, I don't have the original bios. What can I do now?...
                              06-20-2024, 12:27 AM
                            • reformatt
                              Mac BootROM manual update
                              by reformatt
                              So following on from this thread, I've been meaning to work out a way to update these boards manually without either having to pull the PROM or doing a reinstall of MAC OS. If I'm just fixing a board, I should be able to just update like you do on a PC laptop right? Well this is an Apple product......
                              Firmware is well hidden in the installer. But once you've found it, you can just dump it on a memory stick or a spare SSD with Big Sur installed. Many thanks to StarterGo on GitHub for the pointers. I've done this for Macbook Air 820-3437 and 820-00165 boards, but other non T2 machines...
                              03-22-2023, 11:12 PM
