need bios dump dell latitude 5420 (cpu 11th)
  • mouez_by
    • Sep 2013
    • 14
    Originally posted by qayyum786
    Try
    Same problem just when power on small orange led blink Without any activity.
    I have checked all voltages on motherboard and all seems OK
    • rex98
      • Feb 2023
      • 1296
      • Mandaue CEBU, Philippines
      #642
      Originally posted by gungor1981tr
      Hi!Help me, please.Dell latitude 5420 there is a password in the bios, can you help us remove the current password? ST:74R8QN3 Motherboard code:GDF40 LA-K491P REV:2.0
      1st boot, press F2, write service tag, disable Absolute, save (Apply changes), restart. 2nd boot press Alt+F to exit manufacturing mode.
      • biniu1978
        • May 2022
        • 26
        #643
        Hi. Can You Remove Password form my bin file please
        Dell Latitude 5420
        Service Tag : 392H4J3
        Thank You
        • rex98
          • Feb 2023
          • 1296
          #644
          Dell Latitude 5420
          Thank You
          • iori1881
            • Sep 2023
            • 58
            #645
            hello everyone,
            i have dell latitude 5420 11th gen , it was working fine and stopped working ....the cpu getting hot and the light flash red only ones ....i need the original bios file for it or anything can make it work again please because i lost the backup
            motherboard model : LA-K491P , Rev : 2.0 ( A01 )
            THANK YOU
          • dahnking
            • Apr 2018
            • 264
            • kenya
            #646
            Dell Latitude 5420
            Service Tag : 5X87MN3
            was working fine then its now displaying different solid colours
            Anyhelp please?​
            • hoaca388
              Badcaps
              • Jan 2022
              • 12423
              #647
              Originally posted by dahnking
              Dell Latitude 5420
              Anyhelp please?​
              ZZZ
              • OntarioTL
                • Feb 2022
                • 59
                Well this sucks that you can't use the old system of password unlockers for Dell.
                I have 3 of these Lattitude 5420 systems that I'm asking for help with. I will start with one for now and test it out first.
                Dell Latitude 5420 Core i7 11th gen
                Service Tag: G41J2F3
                Early thanks to whom helps out!!!
                Out of curiosity. If one unit has been wiped of the admin pw with the fixed BIOS file, can I use the same BIOS file from the first one on the other 2 since I have to re-enter the service tag anyway?
                • rex98
                  • Feb 2023
                  • 1296
                  #649
                  upload here all you wanted to be unlocked. this unlocked bios cannot be used in other laptop.
                  • OntarioTL
                    • Feb 2022
                    • 59
                    Thanks Rex!! Worked like a charm.
                    Ok it took me a bit to grab the other BIOS images since one was an XMC chip. Now that I figured that out after searching, here they are.
                    Service Tag: 6SJ8HK3 and 6T5K4J3
                    Thanks again for the assistance!!!
                    • rex98
                      • Feb 2023
                      • 1296
                      #651
                      here same procedure.
                      • OntarioTL
                        • Feb 2022
                        • 59
                        Thanks again Rex!
                        Of course I would have another one drop in my lap.
                        Service Tag: 61676J3
                          • 22159
                          Thanks again Rex!
                          How many have you got,don`t you want to learn how to unlock them yourself, a hex editor is all you need.
                          • OntarioTL
                            • Feb 2022
                            • 59
                            I'm hoping it's the last. But you are right, the laziness got the better of me. I just compared the previous fixed files and the original lock file with hex comparator. Is it really that easy? I was worried Dell went all Lenovo on us.
                            I'll try it myself and see.
                            • OntarioTL
                              • Feb 2022
                              • 59
                              Ok, got it to work on the first try. Not as easy as I said. Simple to compare when you have a fixed and original BIOS. Hard to find the same string when address locations are off a little per BIOS image.
                                • 22159
                                Yes its not easy at first,but now you know
                                • thienlaptop
                                  • Mar 2023
                                  • 10
                                  • vn
                                  #657
                                  Dell Latitude 5420
                                  Service Tag : 3ZY43J8
                                  Thank You​
                                  • rex98
                                    • Feb 2023
                                    • 1296
                                    #658
                                    Dell Latitude 5420
                                    Thank You​
                                    • thienlaptop
                                      • Mar 2023
                                      • 10
                                      • vn
                                      #659
                                      very good . Thankyou
                                      • IMLJ
                                        • Jan 2015
                                        • 25
                                        Dell Latitude 5420.
                                        Laptop is stuck at 5V, CPU Fan constantly running when pressing the power button.
                                        It may have corrupted bios. anyone help? thanks.
                                        • mirjana
                                          EC dump request – Dell Latitude 5420, GDF40 LA-K491P Rev 3.0, MEC5107-LJ
                                          by mirjana
                                          I need the EC firmware dump for Dell Latitude 5420, motherboard GDF40 LA-K491P Rev 3.0 (A02).
                                          The embedded controller is MEC5107-LJ (UE1).
                                          The EC flash chip is W25Q80DV, 8Mbit (1MB).
                                          I already have the 32MB BIOS dump (W25Q256JV), but my system is still not powering on — just amber blink. I suspect the EC firmware is missing or corrupted.
                                          If anyone has this board and can share their EC dump from the 25Q80DV, I’d be very grateful.
                                          Thank you in advance!...
                                          07-16-2025, 12:55 AM
                                          DELL Latitude 5420 Notebook Rugged Specification for Upgrade or Repair
                                          This specification for the DELL Latitude 5420 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 5420 boardview and 5420 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL Latitude 5420...
                                          09-06-2024, 03:21 PM
                                          DELL Latitude 5420 Notebook 5000 Specification for Upgrade or Repair
                                          09-06-2024, 09:23 AM
                                          09-06-2024, 08:47 AM
