HP EliteBook 1050 G1
  • Pasha_Lu
    • May 2020
    • 11
    • Ukraine
    Hello. Need a dump BIOS from a working laptop HP EliteBook 1050 G1. Thank you.
  • peste
    • Dec 2016
    • 13701
    • ROMANIA
    Re: HP EliteBook 1050 G1
    post the backup copy of the original laptop bios and the motherboard model.
    • Pasha_Lu
      • May 2020
      • 11
      • Ukraine
      Hello, peste. Motherboard model: DAOXW1MBAI1 REV: I
      • peste
        • Dec 2016
        • 13701
        • ROMANIA
        the bios is corrupt and I can't clean it .. maybe someone who has this bios will post it ..
        • Pasha_Lu
          • May 2020
          • 11
          • Ukraine
          Thanks for trying. I also failed to clean my native firmware, so I need a working one to build my native firmware.
            • 22035
            fixed. try it and give feedback .
            • Pasha_Lu
              • May 2020
              • 11
              • Ukraine
              Hello, SMDFlea. Your firmware is working, everything is fine. Many thanks.
              PS: for those who want to use the firmware data, be careful they have a BIOS password.
              • valerix9898
                • Mar 2018
                • 23
                hp 1050 g1 bios
                hello everyone . i have problem to program bios .
                so i was flashed bios before successful but this time im really struggling with bios chip from hp 1050 g1 . so I reeded it saved backup copy and then was erase the chip but thing is that its doing that so quick and after if check if its empty i get error and i dont know what to do . its read the chip but i think not fully as should be and dont clean it as well as should be !
                and if i try to program it it works but when solder it back now laptop wont turn on .
                sorry if i ask any stupid questions but im not professional just learning by my self .
                chip name is MXIC MX25L25673GZ41 32mbyte
                programmer - ch341a
                software what i used was neoprogrammer v2.2.0.10
                • hoaca388
                  Badcaps
                  • Jan 2022
                  • 12368
                  Re: hp 1050 g1 bios
                  Try with other program such as Colibri, AsProgrammer or Flashrom ( Linux )..
                  • valerix9898
                    • Mar 2018
                    • 23
                    Re: hp 1050 g1 bios
                    Thing is that I tried already with asprogrammer , i never worked with linux flashrom but i tried too with flashrom but thing is that when i install flashrom on linux its show some error so i was think i will do better then from programs which i know and worked before .
                    Can be a problem because of wrong adapter because? im using Sop clip or how it calls . But its detect chip everything looks like it works . Idk maybe its programms a bit different way not like normal bios? Because i saw videos on youtube there guys just read it don't clean and straight away flash new bios
                    • hoaca388
                      Badcaps
                      • Jan 2022
                      • 12368
                      Re: hp 1050 g1 bios
                      With CH341A you should not use clamps.
                      • valerix9898
                        • Mar 2018
                        • 23
                        Guys can you tell me please is ch341a programmer is compatible with 32mb 256bit wson8 chips ? Or i need other programmer to flash bios ?
                        • valerix9898
                          • Mar 2018
                          • 23
                          hp 1050 g1 bios needed
                          hello. can someone give me fully working bios for hp 1050 g1 DA0XW1MBAI1 REV1
                          16MB
                          AND
                          32MB PLEASE !!!!!!!!!!!!!!!!!!
                          • hoaca388
                            Badcaps
                            • Jan 2022
                            • 12368
                            Re: hp 1050 g1 bios needed
                            Post your corrupt bios file and serial number.
                            • valerix9898
                              • Mar 2018
                              • 23
                              thats the 32 mb bios file .
                              serial number 5cd9418fth
                              • hoaca388
                                Badcaps
                                • Jan 2022
                                • 12368
                                HP EliteBook 1050 G1 Base Model Notebook PC
                                • valerix9898
                                  • Mar 2018
                                  • 23
                                  Maybe you know why its show this kinda error ?
                                  • valerix9898
                                    • Mar 2018
                                    • 23
                                    So i sorted out everything. Bios is working . Many thanks . But there is small problem , its takes around 40 sec to turn on , both fans spins and black screen long time and after its show hp logo and then everything is ok
                                      • 22035
                                      Clean the ME firmware https://www.badcaps.net/forum/showpo...41&postcount=3
                                      • bigbadbios
                                        • May 2021
                                        • 8
                                        Elitebook 1050 G1 BIOS Issues
                                        I backed up the main bios from my 1050 G1 with CH341 clip and i believe it's damaged. I was just trying to remove password from BIOS. Now every time I try a file it just blinks caps lock and power button LED
                                        If someone can try to clean the crashed BIN I will be forever grateful.
                                        Thanks so much
                                        Serial # is 5CD9251STV
                                        Last edited by Vesko356; 04-30-2023, 03:57 PM. Reason: Merging posts. AGAIN! It looks like the EDIT button has become invisible!!
                                          HP EliteBook EliteBook 1050 G1 Notebook PC Notebook 1000 Specification for Upgrade or Repair
                                          This specification for the HP EliteBook EliteBook 1050 G1 Notebook PC Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the EliteBook 1050 G1 Notebook PC boardview and EliteBook 1050 G1 Notebook PC schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                                          09-06-2024, 06:51 AM
                                        • Ahari
                                          by Ahari
                                          I...
                                          08-13-2025, 06:12 AM
                                        • mkdj
                                          by mkdj
                                          Dear all,
                                          10-19-2025, 04:41 AM
                                        • Habble7
                                          by Habble7
                                          Suspected Cause:
                                          Troubleshooting Attempts:
                                          05-22-2025, 07:28 AM
                                        • haitham sharabati
                                          [Request] Clean BIOS dump for HP 15-da2007ne (8XF55EA#ABV) - N4000 - BIOS Lock
                                          by haitham sharabati
                                          Hello engineers 😀,
                                          I’m kindly requesting a clean and unlocked BIOS dump for the following HP laptop, as it’s bricked after flashing SP152727. The system now keeps rebooting, and the original issue was an Administrator / Power-On Password that I can no longer access.😏
                                          🔧 Device Info:
                                          - Model: HP 15-da2007ne
                                          - Product Number: 8XF55EA#ABV
                                          - Serial Number: CND0338P0D
                                          - CPU: Intel Celeron N4000
                                          - EC/BIOS Chip: [Add chip number from the motherboard or BIOS chip]
                                          💀 Problem:😅
                                          - Device shows “Administrator Password”...
                                          08-07-2025, 04:54 AM
