Try our *UPDATED* boardview, bios, & schematic search. Over 2.3 million files for download!
HP EliteBook 1050 G1
  • natic
    replied
    Hello!
    I also need a BIOS dump for the laptop HP EliteBook 1050 G1.
    Motherboard: Quanta XW1, DA0XW1MBAI0, Rev: I (board with a dedicated Nvidia GPU)
    Serial number: 5CD8313GML
    Product ID: 3ZH22EA#BED
    Fault: Does not respond to pressing the power button. The "VCCSA" (CPU Intel graphics) power rail is activated even when the laptop is turned off. I suspect a BIOS related failure.
    BIOS and EC BIOS dumps attached.
    Please, help.
    Premium supporters get full download access and other benefits.
  • danito
    replied
    Originally posted by didoupimpon
    hi can you provide me the hp ElitBook 1051 G1 Bios bin with the password reset thanks
    try
    commented on 's reply
    Thread merged with 1050 G1 topic.
  • didoupimpon
    replied
    hi sorry , the serial number is 5CD8310YKO and the mother board model number is L31550-601 / HK1951 data near datamatrix: XW10360I3A / PHNAC01 8JAT009
  • danito
    replied
    You MUST:
    Provide the full machine model number, serial number (or Service tag, SNID) and the board model number (see https://www.badcaps.net/forum/showthread.php?t=88758 ) ,The serial number, make, full model number, motherboard model and revision (except QR codes) must be written/typed at your request as per the rules. Not as a picture, part of the file name and so on.
  • didoupimpon
    replied
  • alas3376
    replied
    hello bro, you were right the password is on 16mb. it works for me.
    thank you very much.
  • fauzanmint
    replied
    Originally posted by alas3376
    Thank you very for your help, here is my 16mb dump
    try and provide a report
  • alas3376
    replied
  • fauzanmint
    replied
    yes, i think the password is on 36mb. if somebody can share the offset adress i could with hxd
    it looks like the password is in the 16mb bios, post it here
  • alas3376
    replied
  • fauzanmint
    replied
    Hello everybody
    I need your help to remove bios password on this :
    Brand: Hp elitebook 1050 G1
    S/N:5CD8522WP9
    Here is my dump
    thanks
    do you have 16mb bios
  • peste
    merged post..
  • alas3376
    replied
    Hello everybody
    S/N:5CD8522WP9
    Here is my dump
    thanks
  • bigbadbios
    replied
    Elitebook 1050 G1 BIOS Issues
    I backed up the main bios from my 1050 G1 with CH341 clip and i believe it's damaged. I was just trying to remove password from BIOS. Now every time I try a file it just blinks caps lock and power button LED
    If someone can try to clean the crashed BIN I will be forever grateful.
    Thanks so much
    Serial # is 5CD9251STV
    Last edited by Vesko356; 04-30-2023, 03:57 PM. Reason: Merging posts. AGAIN! It looks like the EDIT button has become invisible!!
    replied
    Re: HP EliteBook 1050 G1
    Originally posted by valerix9898
    So i sorted out everything. Bios is working . Many thanks . But there is small problem , its takes around 40 sec to turn on , both fans spins and black screen long time and after its show hp logo and then everything is ok
    Clean the ME firmware https://www.badcaps.net/forum/showpo...41&postcount=3
  • valerix9898
    replied
  • valerix9898
    replied
    Re: hp 1050 g1 bios needed
    Maybe you know why its show this kinda error ?
  • hoaca388
    replied
    thats the 32 mb bios file .
    serial number 5cd9418fth
    HP EliteBook 1050 G1 Base Model Notebook PC
  • valerix9898
    replied
  • Darksands
    Need clean BIOS dump: Dell Pro 14 Plus PB14250 (CMF34 Rev: A00) - Freezes on Dell logo
    by Darksands
    [SOLVED]
    Laptop: Dell Pro 14 Plus, PB14250
    Motherboard: PWB CMF34, Rev (A00).
    Service Tag: 3YLQ8F4.
    CPU: Intel® Core™ Ultra 5 processor 238V (8M Cache, up to 4.70 GHz) FCBGAEXX, Tray. Ordering Code: QQ8076606106. Spec Code: SRPN5.
    BIOS Flash Chip: Winbond 25R512NWEQ.
    BIOS version (via ME Analyzer by TechNoDev): 20.0.11.1815_COR, FITC 20.0.0.1329, SKU Corporate.
    Symptoms & History: Initially, a black screen appeared, then the laptop rebooted, entered BIOS Recovery, and the flashing process started. After the flash and a reboot, it freezes...
    09-13-2026, 03:15 AM
  • Trademark
    Acer Predator Triton 16 PT16-51-99GL (DA0ZQDMB8AE Rev. E) - Looking for original 32MB BIOS dump (Winbond W25Q256JVEN)
    by Trademark
    I’m hoping someone can help me locate a verified original BIOS dump for my Acer laptop.
    This is NOT a BIOS password removal request.
    I’m looking for an original 32MB SPI BIOS dump to use as a reference in case my BIOS firmware is corrupted. My plan is to first dump and back up my own BIOS as soon as my programmer arrives. I am not planning to blindly flash someone else’s BIOS.
    Laptop Information
    • Model: Acer Predator Triton 16 PT16-51-99GL
    • Motherboard: DA0ZQDMB8AE Rev. E
    • Main SPI flash: Winbond W25Q256JVEN (32MB)
    • Secondary
    07-22-2026, 08:57 AM
  • wrinex
    bios request/fixing dump HP elitebook 840 G6
    by wrinex
    Hi i received a HP elitebook G6 that had a The HP Endpoint Security Controller error when booted but 3 enters later you could use it in windows, i thought maybe a bios update helps...... i used the HP tool (it did not want to update from device manager,,, someting i did not even knew worked) after the update it bricked the laptop.
    i get 7 blinks on the capslock and thats it. i desoldered the chips front and back. and made a dump. i tried one bios posted here for the 16M and the 32Mb bios.. but it would not turn on or give an error code. so now i reflashed it back in its failed state...
    04-09-2026, 12:39 PM
  • Remskiy228
    BIOS Dump Request — Lenovo ThinkPad P14s Gen 5 Intel (21G2) (21G3)
    by Remskiy228
    Hello everyone!
    I'm looking for a BIOS dump or assistance with BIOS recovery for my Lenovo ThinkPad P14s Gen 5 Intel.
    Laptop specifications:
    - Model: Lenovo ThinkPad P14s Gen 5 Intel
    - Machine Type: 21G2
    - CPU: Intel Core Ultra 5 135H
    - GPU: NVIDIA RTX 500 Ada Generation
    Problem:
    My laptop stopped booting after a firmware update through Lenovo Vantage. It powers on but does not POST or display anything.
    What I'm looking for:
    Either of the following...
    Yesterday, 09:48 AM
  • Ahari
    by Ahari
    I...
    08-13-2025, 06:12 AM
