Sorry not working😥
need bios dump for Latitude 5591
YOUR SERVICE TAG IS : D2N8ST2
TRY....Attached FilesLeave a comment:
You MUST:- Provide the full machine model number, serial number (or Service tag, SNID) and the board model number (see https://www.badcaps.net/forum/showthread.php?t=88758 ) ,The serial number, make, full model number, motherboard model and revision (except QR codes) must be written/typed at your request as per the rules. Not as a picture, part of the file name and so on.
i need bios for LA-F712P
DDP80 LA-F712P
REV: 1.0(A00)
and I have another problem
I can't fined the service tag
It was removed from the chassis
this is the old biosAttached FilesLeave a comment:
Hello, maybe someone can fix corrupted bios?
Service Tag: JLT8YT2Attached FilesLeave a comment:
Re: Dell Latitude 5591 - Disable ME via HAP bit only
BIOS package from Dell: https://dl.dell.com/FOLDER10054153M/...530_1.27.1.exe
I have experience with using flashrom and SOIC clip, but I couldn't find the BIOS chip on this motherboard. There was one 8-pin chip that was 1 MB in size but it wasn't a valid image according to me_cleaner, although I almost wonder if flashrom needed updated or something. Does anyone know specifically where the BIOS chips is on the 5591?
Is it possible to flash only what is needed to set the HAP bit for ME without needing a hardware flasher? In the past I did --soft-disable-only with me_cleaner.
I'm not sure if I have Boot Guard. I believe I disabled Boot Guard via setup_var variable or something because it caused a BIOS update to repeatedly fail a flashing step, but I'm not sure if it was BG or something else.
I managed to get my SOIC clip onto the BIOS chip, dumped it, me_clean'd the BIOS, and flashed it back. I did soft-disable-only and descriptor flags, but it doesn't seem like the descriptor flag on ME allows writing. There's no HECI PCI device, and ME is reported disabled from FPT and MEInfo CSME tools.
The BIOS chip (at least mine) was near the PCH chip, and I had to remove the plastic covering holding the wifi wires, battery, and covering the touchpad to reach it comfortably.Last edited by Espionage724; 06-27-2023, 03:39 AM.Leave a comment:
I'm not sure if I have Boot Guard. I believe I disabled Boot Guard via setup_var variable or something because it caused a BIOS update to repeatedly fail a flashing step, but I'm not sure if it was BG or something else.Leave a comment:
Re: need bios dump for Latitude 5591
Many thanks ! But how do I set Service Tag ?Hello Salmus666
I had to choose the right CSME version, I only got it on the fourth attempt.
There are several CSME versions, it is important that no errors are displayed with MEAnalyzer.
https://winraid.level1techs.com/t/in...ols-2-15/30719Leave a comment:
Hello Salmus666
Try ...Attached FilesLeave a comment:
Hello
Can somebody clear ME ?
I cant figure it out.Attached FilesLeave a comment:
Re: BIOS Unlock Dell 5591 LA-F711P
yes it work. you must fill Svtag then ok.Sorry at first it didn't work. Fan spins at full speed. Then press Alt + F Press F2 still window with unlock
Solved the problem.
Thank you very much.
https://beta.bios-pw.org/
62Jy4Ra2NGzyQ[xMLeave a comment:
Solved the problem.
62Jy4Ra2NGzyQ[xMLast edited by Markus1741; 03-16-2022, 09:27 AM.Leave a comment:
try and let me know
good luckAttached FilesLeave a comment:
by AhariHi all,
I...-
by mkdjDear all,
I would appreciate if someone could take time to explain the issue, so that I can learn. But I would...-
Channel: BIOS Requests ONLY!
by Habble7The Samsung S49CG934SU monitor does not power on - no LED indicator activity and no response to power button. However, when 21V power is connected, it immediately draws 0.8A of current with no display output. The motherboard processor gets warm, and there is continuous reading activity from the W25Q128BV BIOS chip.
Suspected Cause:
Troubleshooting Attempts:
Hello engineers 😀,
I’m kindly requesting a clean and unlocked BIOS dump for the following HP laptop, as it’s bricked after flashing SP152727. The system now keeps rebooting, and the original issue was an Administrator / Power-On Password that I can no longer access.😏
🔧 Device Info:
- Model: HP 15-da2007ne
- Product Number: 8XF55EA#ABV
- Serial Number: CND0338P0D
- CPU: Intel Celeron N4000
- EC/BIOS Chip: [Add chip number from the motherboard or BIOS chip]
💀 Problem:😅
- Device shows “Administrator Password”...2 Photos-
by CityminHi all,
S/N : 5RNK9FFT70...-
- Loading...
