Hi everybody. i also need bios dump for 5591. If you have that file please send it to me. Thank you very much
need bios dump for Latitude 5591
Tags: None
Re: need bios dump for Latitude 5591
this is bios dump
Absolute is enable. is there any way to turn it off?
thanks
Attached FilesComment
Re: BIOS Unlock Dell 5591 LA-F711P
good luckAttached FilesComment
Sorry at first it didn't work. Fan spins at full speed. Then press Alt + F Press F2 still window with unlock
Solved the problem.
Thank you very much.
https://beta.bios-pw.org/
62Jy4Ra2NGzyQ[xMLast edited by Markus1741; 03-16-2022, 09:27 AM.Comment
Solved the problem.
62Jy4Ra2NGzyQ[xMComment
Hello
Can somebody clear ME ?
I cant figure it out.Attached FilesComment
Try ...Attached FilesComment
Hello Salmus666
I had to choose the right CSME version, I only got it on the fourth attempt.
There are several CSME versions, it is important that no errors are displayed with MEAnalyzer.
https://winraid.level1techs.com/t/in...ols-2-15/30719Comment
Hello Salmus666
Dell Latitude 5591 - Disable ME via HAP bit only
BIOS package from Dell: https://dl.dell.com/FOLDER10054153M/...530_1.27.1.exe
I have experience with using flashrom and SOIC clip, but I couldn't find the BIOS chip on this motherboard. There was one 8-pin chip that was 1 MB in size but it wasn't a valid image according to me_cleaner, although I almost wonder if flashrom needed updated or something. Does anyone know specifically where the BIOS chips is on the 5591?
Is it possible to flash only what is needed to set the HAP bit for ME without needing a hardware flasher? In the past I did --soft-disable-only with me_cleaner.
I'm not sure if I have Boot Guard. I believe I disabled Boot Guard via setup_var variable or something because it caused a BIOS update to repeatedly fail a flashing step, but I'm not sure if it was BG or something else.Comment
Re: Dell Latitude 5591 - Disable ME via HAP bit only
I managed to get my SOIC clip onto the BIOS chip, dumped it, me_clean'd the BIOS, and flashed it back. I did soft-disable-only and descriptor flags, but it doesn't seem like the descriptor flag on ME allows writing. There's no HECI PCI device, and ME is reported disabled from FPT and MEInfo CSME tools.
The BIOS chip (at least mine) was near the PCH chip, and I had to remove the plastic covering holding the wifi wires, battery, and covering the touchpad to reach it comfortably.Last edited by Espionage724; 06-27-2023, 03:39 AM.Comment
Hello, maybe someone can fix corrupted bios?
Service Tag: JLT8YT2Attached FilesComment
i need bios for LA-F712P
DDP80 LA-F712P
REV: 1.0(A00)
and I have another problem
I can't fined the service tag
It was removed from the chassis
this is the old biosAttached FilesComment
You MUST:- Provide the full machine model number, serial number (or Service tag, SNID) and the board model number (see https://www.badcaps.net/forum/showthread.php?t=88758 ) ,The serial number, make, full model number, motherboard model and revision (except QR codes) must be written/typed at your request as per the rules. Not as a picture, part of the file name and so on.
by Habble7The Samsung S49CG934SU monitor does not power on - no LED indicator activity and no response to power button. However, when 21V power is connected, it immediately draws 0.8A of current with no display output. The motherboard processor gets warm, and there is continuous reading activity from the W25Q128BV BIOS chip.
Suspected Cause:
Troubleshooting Attempts:
This specification for the DELL Latitude 5591 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 5591 boardview and 5591 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL Latitude 5591...09-06-2024, 12:36 PM
This specification for the DELL Latitude 5591 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 5591 boardview and 5591 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL Latitude 5591...09-06-2024, 11:17 AM
by TripTopHi
i have dell latitude E7270 with following symptoms:
- takes long time to restart.
- sometimes powers on and then off
- sometimes while working it just dies,
From googling online bios clean could possible resolve this?
i was able to save bios and was going to try bios clean myself but get an below error when i drop it in ME analyzer.(unsure whether this sometimes occurs or could be due to bad/corrupt bios)
As ME analyzer gave me an error i just decided to write bios with a cleaned bios from E7270 bios post.
I reinstall...-
Channel: BIOS Requests ONLY!
by DynaxSCHi, I have an MSI PRO B660M-G DDR4 board with damaged BIOS and i need a bios dump from a real board, along with MAC, UUID and Serial Number info (eg. a BIOS screenshot and pictures from the board stickers).
I need to reconstruct the bios on my board, based on another bios image form a real board - meaning a bios image containing MAC address, UUID and Serial number. A stock BIOS is not suffiecient, as it is impossible to discover where the MAC, UUID and SerialNumber are stored. Tried with a similar board, but there are too much differences, and the stock BIOS is missing a lot of...11-17-2023, 10:56 AM - Loading...
