need bios dump for Latitude 5591
    Hi everybody. i also need bios dump for 5591. If you have that file please send it to me. Thank you very much
    Re: need bios dump for Latitude 5591
    post your old dump
      Originally posted by sunbabu369 View Post
      post your old dump
      this is bios dump
      Absolute is enable. is there any way to turn it off?
      thanks
        Can anyone help me ?
          BIOS Unlock Dell 5591 LA-F711P
          Hello, maybe someone can help me.
          I have a Dell 5591 with a BIOS password can someone unlock this please.
          The motherboard is an LA-F711P
            Re: BIOS Unlock Dell 5591 LA-F711P
            try and let me know
            good luck
              Originally posted by black0hackers View Post
              try and let me know
              good luck
              Sorry at first it didn't work. Fan spins at full speed. Then press Alt + F Press F2 still window with unlock
              Solved the problem.
              Thank you very much.
              https://beta.bios-pw.org/
              62Jy4Ra2NGzyQ[xM
                Solved the problem.
                62Jy4Ra2NGzyQ[xM
                yes it work. you must fill Svtag then ok.
                  Hello
                  Can somebody clear ME ?
                  I cant figure it out.
                    Originally posted by Salmus666 View Post
                    Hello
                    Try ...
                      Try ...
                      Thank You.
                      It works.
                      What did you do?
                      Salmus666
                        Thank You.
                        It works.
                        What did you do?
                        Salmus666
                        Hello Salmus666
                        I had to choose the right CSME version, I only got it on the fourth attempt.
                        There are several CSME versions, it is important that no errors are displayed with MEAnalyzer.
                        https://winraid.level1techs.com/t/in...ols-2-15/30719
                          Hello Salmus666
                          Many thanks ! But how do I set Service Tag ?
                            Try ...
                            work for me bro, thanks
                              Dell Latitude 5591 - Disable ME via HAP bit only
                              BIOS package from Dell: https://dl.dell.com/FOLDER10054153M/...530_1.27.1.exe
                              I have experience with using flashrom and SOIC clip, but I couldn't find the BIOS chip on this motherboard. There was one 8-pin chip that was 1 MB in size but it wasn't a valid image according to me_cleaner, although I almost wonder if flashrom needed updated or something. Does anyone know specifically where the BIOS chips is on the 5591?
                              Is it possible to flash only what is needed to set the HAP bit for ME without needing a hardware flasher? In the past I did --soft-disable-only with me_cleaner.
                              I'm not sure if I have Boot Guard. I believe I disabled Boot Guard via setup_var variable or something because it caused a BIOS update to repeatedly fail a flashing step, but I'm not sure if it was BG or something else.
                                Re: Dell Latitude 5591 - Disable ME via HAP bit only
                                I managed to get my SOIC clip onto the BIOS chip, dumped it, me_clean'd the BIOS, and flashed it back. I did soft-disable-only and descriptor flags, but it doesn't seem like the descriptor flag on ME allows writing. There's no HECI PCI device, and ME is reported disabled from FPT and MEInfo CSME tools.
                                The BIOS chip (at least mine) was near the PCH chip, and I had to remove the plastic covering holding the wifi wires, battery, and covering the touchpad to reach it comfortably.
                                  Hello, maybe someone can fix corrupted bios?
                                  Service Tag: JLT8YT2
                                    Try
                                      Originally posted by qayyum786 View Post
                                      Try
                                      Not working...
