Xmc 25rh256cxiq bios chip
  • lavie
    • Aug 2015
    • 85
    • southafrica
    Morning guys have anyone come across dis bios chip XMC 25RH256CXIQ it's not listed in the programmer and i hve the latest software and is not found cant be detected
  • Zickko10
    • Sep 2021
    • 81
    • Nigeria
    Re: Xmc 25rh256cxiq bios chip
    Try and replace the bios chip with another
    Make sure you use the one that have the same storage (mb) like the previous one
    • lavie
      • Aug 2015
      • 85
      • southafrica
      morning sir thanks for ur feedback how can i check de chip when i dont hve the bios bin to programmed it with
        • 20334
        And your programmer model is what ?
        • lavie
          • Aug 2015
          • 85
          • southafrica
          is TL866II programmer and i have downloaded the latest software but is still not found in it
            • 20334
            Choose a different chip instead and untick the Check-ID box .You might have to untick verify as well
            W25Q256FV @SOIC8
            If you want full support adding send them an email - http://www.autoelectric.cn/en/ContactUs.html
            EDIT: Support was added on Date : 3.05th.2022 http://www.autoelectric.cn/MiniPro/TL866II_List.txt
            • i4mm3
              Banned
              • Sep 2020
              • 21
              • Philippines
              Did anyone get a successful unlock with this chip or replaced it with another chip? My laptop was awarded by company and I got everything even it's own box
              • Kodza
                • Jun 2016
                • 173
                • South Africa
                Hello guys I also got a laptop with the XMC 25RH256CXIQ and the chip is not supported my programmer is RT809H. I have tried to add the chip manually but it can't read the firmware from the chip
                • Aditya11ttt
                  Adi
                  • Feb 2019
                  • 177
                  • India
                  if try to replace with another chip display will come but along with diffrent kind of issue we have seen this in dell 5420 model only xmc chip works fine try any other brand not work proper.
                  • takura
                    • Sep 2016
                    • 4
                    • Zimbabwe
                    I have read the xmc 25rh256cxiq on my RT809H with no problems and wrote on it as well
                    • abdelilahocs
                      • Nov 2018
                      • 119
                      • morroco
                      i cant read it on RT809H and TL866II
                      • DZ-Developer
                        • Nov 2022
                        • 28
                        • Algeria
                        Same problem with XGecu T56
                        all donations are welcome,
                        see the donate button below, at the bottom of the page, or
                        >>>>> click on this link to donate via PayPal. <<<<<
                        Doctrina est fructus dulcis, radicis amarae
                        • krystian666
                          • Jun 2020
                          • 9
                          • Ecuador
                          Rt809f reads and writes without problem
                          enter correct id and it works ok
                          • codex16
                            • Jan 2023
                            • morocco
                            hi i have RT809F with last update 20221212 i cant read XMC25RH256CXIQ not in list i use MX25L25635E but dump is not working can you help mais plz
                            • codex16
                              • Jan 2023
                              • morocco
                              can you plz share Rt809f upload full software ?
                                • 20334
                                https://www.badcaps.net/forum/showpo...40&postcount=2
                                1.1.1.3. RT809F
                                Supports I2C, SPI, LPC, FWH, VGA ISP.
                                Parallel interfaces support requires PEB-1 extension board and can be troublesome.
                                Support list: https://www.hklrf.com/24download/img/RT809F-List2.txt
                                Software: http://doc.ifix.net.cn/@rt809/ENGLISH.html
                                See post #13 to change the chip ID .
                                • feherhollo
                                  • Nov 2019
                                  • 110
                                  • Hungary
                                  I'm also unable to read out this chip using RT809F
                                  Can somebody tell how can you read out this chip?
                                  These are getting very common in Dell 11th gen laptops...
                                    • 20334
                                    Did you read post #13 ,maybe that will work.
                                    • Ismael Shah
                                      • Jul 2021
                                      • 7
                                      • india
                                      Thanks for help
                                      • bachir2004
                                        • Feb 2015
                                        • 437
                                        • maroc
                                        Confirmed.software needs to be restarted.
                                          by SMDFlea
                                          Bad...
                                          09-02-2021, 04:40 PM
                                        • BMCappelletti
                                          Asus Chromebox CN62 - wrong chip put on BIOS reader
                                          by BMCappelletti
                                          Long story short:
                                          - dad converted Asus Chromebox CN62 into Windows compatible, with mrchromebox BIOS, years and years ago
                                          - gave the computer to his son a couple years later
                                          - son now decided to revert it to Chrome OS, to sell it as original (re-writing BIOS with the backup one created by his dad)
                                          - too lazy to remove the board from the case, thought a voltage regulator was the BIOS chip (you know... it has 8 legs)
                                          (seems like the story was not that short)
                                          He used alligator clips to read the chip. No luck reading it. Removed chip and placed on a SOC-8...
                                          01-08-2025, 07:27 PM
                                        • thxd43
                                          Lenovo laptop does not turn on, what does this number mean in a BIOS chip?
                                          by thxd43
                                          Hello, first of all, excuse me, I am using the translator, English is not my native language.
                                          I have a Lenovo ideapad 330S - 14IKB laptop.
                                          The tablet did not recognize me when I connected it, so I checked the device manager and I realized that there were many with the exclamation mark, so one by one I began to update their drivers until the sign disappeared of admiration, I even updated the BIOS, and the laptop rebooted normally and worked, so far so good, but the tablet still did not recognize me, I read on the internet that it could be due to a...
                                          02-23-2023, 08:37 PM
                                        • hotcrossedbuns999
                                          M715q Desktop (ThinkCentre) - Type 10M3 - Request bios chip location and useable bios for use with CH341A Programmer.
                                          by hotcrossedbuns999
                                          My pc updated bios through Windows Update and I was greeted with BLACK SCREEN WITH CPU FAN MAX SPEED. I don't think there is even a screen signal, because it triggers my monitor for a couple seconds and then the monitor turns off. I tried the other outputs as well.
                                          1. I tried clearing bios, resetting bios, removed the CMOS battery, removed m.2 ssd, wifi, and ram. Still black screen with CPU fan blasting.
                                          2. I tried using the Lenovo BIOS CD and BIOS USB, but neither worked. At least I couldn't get anything to work.
                                          3. I could only locate two chips that look like bios chips. Could someone verify this
                                          01-03-2025, 12:32 PM
                                        • inck243
                                          Acer e15-e5-576g-5762 bricked. Bios chip won't interface in AsProgrammer.
                                          by inck243
                                          Thanks for any help. The board version is DAZAARMB6E0 REV: E. The bios chip is winbond 25Q64JVSIQ1736. W25Q64JV is not available in AsProgrammer -- only BV CV FV or FW_1.8c. The chip won't interface with asProgrammer and a CH341A. When I have this chip on the board, the laptop will not post but when I plug it in to power, the blue LED lights up, also the orange when the battery is connected. When I push the power on button, keyboard backlight turns on and the fan starts briefely then turns off. But I can't do anything to program this bios chip so I bought another one.
                                          The BIOS...
                                          07-25-2024, 09:17 AM
